Forum » Pomoč in nasveti » monitor težave
monitor težave
milenkoo ::
Prosim vas za pomoč težava z monitorjem.
Pojavlja se mi OSD lockout in nikakor ne morem urediti zadevo ali ima kdo kakšen predlog oziroma rešitev. gre se za monitor HP Li940T.
Hvala in lep pozdrav
ST-777 ::
Morda ti bo koristilo:
"Try a monitor reset. Unplug the monitor’s power cord and hold down the monitor’s power button for 30-60 seconds. Plug the monitor back in and power it up. If that doesn’t work then go into the monitor’s menu and do a factory reset.
Check your monitor and cable on another PC as a double check to make sure that the issue is not the PC. I am fairly sure that this is a monitor issue. Try a "feel" test of the monitor buttons to make sure that the buttons aer not faulty." http://h30434.www3.hp.com/t5/Desktop-Ha...
| » | Dishonored 2: Darkness of Tyvia (strani: 1 2 3 )Oddelek: Igre | 27046 (16950) | ahac |
| » | apple+autocadOddelek: Pomoč in nasveti | 931 (901) | jype |
| » | Acer AL2216WOddelek: Novice / Zasloni / projektorji / ... | 6000 (4622) | zcetrt |
| » | monitorji Sun MicrosystemsOddelek: Strojna oprema | 1841 (1563) | ax3K |
| » | Dead Monitors from ATI Catalyst 3.8Oddelek: Strojna oprema | 1959 (1594) | boštjan |
