Forum » Pomoč in nasveti » Tiskalnik EPSON Stylus SX515W - ne prepozna originalne kartuše
Magician ::
Imam tiskalnik EPSON Stylus SX515W.
Pred kratkim sem kupil nov original paket kartuš in ko sem jih vstavil je nekaj časa za tem napisal (Ink cartridge cannot be recognized), da ne prepozna najprej rumene kartuše, nato pa še črne.
Ima kdo podobne izkušnje?
Hayabusa ::
http://www.inkjet-cartridges.co.uk/epso...
http://www.justanswer.com/printers/5ucm...
Expert: Bernie replied550 days and 15 hours ago.
Ok thanks, XXXXX XXXXX printer and remove all cartridges > Sharply unplug the printer from the wall outlet while it is still on, and disconnect it from the pc if connected there
Use a q-tip dampened with warm water to clean the copper contacts on the cartridges and in the printer > Keep cleaning until no ink comes off on the q-tip
Dry for ten minutes, then reinsert cartridges firmly > While the printer is still off, press and hold the power button for 1 minute
Finally, while holding down the stop/cancel button, plug the printer back in, and power on the printer if it doesn't do so automatically, then try a test page, click here to see how.
After taking these steps, if you still face the same issue, it means either the cartridges are defected and need to be exchanged, or the printhead has failed and will need to be replaced. First, exchange the cartridges, if that doesn't work, then unfortunately, if the warranty is out, it may be more cost effective to buy a new printer, but you may certainly call the parts store at 0871(NNN) NNN-NNNNfirst to get a quote and make a final decision.
//brez vode
//brez vode
- spremenilo: Hayabusa ()
| » | Tiskalnik Canon MG2150 megleno tiskaOddelek: Pomoč in nasveti | 2714 (2380) | francek1 |
| » | Nakup tiskalnikaOddelek: Kaj kupiti | 4510 (4008) | mat xxl |
| » | Kateri tiskalnik za tiskanje CD/DVD? (strani: 1 2 )Oddelek: Kaj kupiti | 16600 (13523) | s1m0n |
| » | nujna pomoč - problem s tiskalnikomOddelek: Pomoč in nasveti | 1217 (1148) | Highlag |
| » | HPjevi inkjeti so crap...Oddelek: Strojna oprema | 3210 (2593) | Brane2 |
