Prenos iz kamere na PC
bambina ::
ok, sem totalni butelj za tehniko. Imam kamero Praktica DVC 5.4. Ne znam prenest videov na PC. Včasih je to že delalo, potem se mi je sesula mašina in so mi morali ponovno instalirati. Za to kamero najdem samo en CD z neko programsko opremo (VideoWorks, Mr. Photo in QuickTime). Vse sem si že naložila na mašino, pa mi računalni ne najde kamere. Oz. ko jo priklopim na USB, mi najde F in H, katerokoli particijo kliknem samo išče, išče in ničesar ne najde. Ko iščem driverje na netu, za to kamero nič ne najdem. Kaj moram narediti? Prosim lepo za pomoč :-(
Hayabusa ::
Imaš priključneno na pc direktno, brez vmesnih hubov ?
Kateri winsi ?
manualz
http://www.praktica.de/index.php?id=452...
driverji za 98-ME-2000-XP:
http://www.praktica.de/index.php?id=173...
http://www.praktica.de/index.php?id=32&...
There is no driver for Windows XP on my CD? Where do I get one?
You do not need a driver file for most of our cameras. The needed driver will be provided by the operating system itself. Simply connect your camera as suggested in the manual.
My camera does not accept memory cards.
Most of the time this problem is caused by an incompatibility of SD card and camera controller. Since there are many manufacturers of SD cards on the market it is almost impossible to get them all in line with our products. Therefore we recommend to use SD cards either from Praktica or from Panasonic.
Our cameras are operating on a high security standard. This way a serious damage of the electronics caused by a malfunctioning SD card will be avoided. However, some manufacturers of SD cards are not complying to the standards of the International SD Card Association. Therefore these products won't work with our products. It is even a misapprehension to think the camera might be faulty although the card is working in other devices.
If the card has still warranty you might try to replace it with one of the above mentioned products.
Kamera (strani: 1 2 )
628635 (5799) surewood
Nakup VIDEOKAMERE - z zapisovanjem na...?
274221 (3532) franci
Katero KAMERO naj vzamem?
173806 (2657) Luciano
Nakup digitalne video kamere
353833 (3080) Calligula
Imam probleme z brezplačno telefonijo Detel
212274 (1788) UzzI
