vga ali dvi-razlika
vga ali dvi-razlika
afroangel123 ::
zdravo. imam sledeče vprašanje.. imam grafično kartico z DVi izhodom ter vga. monitor je nov se pravi da ima dvi,vga ter hdmi izhod. zanima me, (jaz osebno sem vedno uporabljal vga) v čem je dejanska razlika med kabli DVI ter VGA v čem je razlika. kje je to najbolj opazi? pri čem?
hvala za odogovore...
ST-777 ::
DVI priklop omogoča bolj kvalitetno sliko.
" I'd go with a DVI cable. That'll give you a pure digital signal (VGA is analog) and a much sharper picture at higher resolutions." http://www.pcworld.com/article/196618/D...
afroangel123 ::
to razumem da omogoča boljšo kvaliteto.toda zanima me, pri čem se ta razlika najbolj opazi?
ST-777 ::
DVI priklop omogoča bolj ostro sliko pri višjih resolucijah. Slika se lahko še izboljša z uporabo Clear Type.
"ClearType is a software technology developed by Microsoft that improves the readability of text on existing LCDs (Liquid Crystal Displays), such as laptop screens, Pocket PC screens and flat panel monitors. With ClearType font technology, the words on your computer screen look almost as sharp and clear as those printed on a piece of paper.
ClearType works by accessing the individual vertical color stripe elements in every pixel of an LCD screen. Before ClearType, the smallest level of detail that a computer could display was a single pixel, but with ClearType running on an LCD monitor, we can now display features of text as small as a fraction of a pixel in width. The extra resolution increases the sharpness of the tiny details in text display, making it much easier to read over long durations." http://www.microsoft.com/typography/Wha...
afroangel123 ::
hvala za podatek
Na svojega Eizota (1600x1200) sem priklopil zdele se en racunalniik preko vga prikljucka.
Razlika med DVI in VGA je OGROMNA. Najbolj opazna je mnogo manjsa ostrina, pa tudi barve so malo cudne pri enakih nastavitvah, kot na DVI.
Nevem zakaj bi sploh za lcd uporabljal analogni signal, ce imas moznost digitalnega.
Niso to vinilke. :))
dottor ::
Je pa še vedno na trgu ogromno LCD in LED LCD ki imajo samo VGA vhod...;((
M-XXXX ::
dottor je izjavil:
Daj ga pokaži...
dottor ::
Eden med mnogimi:
http://www.mimovrste.com/artikel/265001...
21,5" LED LCD Samsung... da nebo kdo reku da sem iskal neznane proizvajalce :)
Ce imas kaj rad svoje oci, ne bos kupil takega monitorja.
Robi :P ::
dottor je izjavil:
Eden med mnogimi:
tale je mal fail moj ma hdmi in vga podobna serija kot ta ki si ga linkal
dottor ::
Jaz sem linkal dokaz da obstajajo, ker je M-XXXX dvomil v mojo izjavo.
Je pa tudi za moje pojme malo fail, sam sem uzel neki podobnega teti od LGja, ker je mela plošča samo VGA izhod...
techfreak :) ::
Zanimivo, poleti sem kupil 22" za 130€ in ima VGA, DVI in HDMI.
Gregor5816 ::
Kakšna pa je prednost/slabost HDMI v primerjavi z DVI?
Gregor5816 je izjavil:
Gre za enak signal, torej nobene razlike.
Edina razlika je, da ima HDMI moznost zvoka, ampak nevem ce ti pri monitorju to kaj pomaga.
Za slabost jaz stejem konektor, ki se zlahka iztakne, DVI pa ne. :)
denabiker ::
to je stara zaloga, ki se pri nas prodaja kot top end. Kaj ne veš, da smo banana republika? :)
blackbfm ::
to je kvečjem prednost
Robi :P ::
jop če ne paziš lahk fajn kej zlomiš ko je kabl fixno not
alexa-lol ::
afroangel123 je izjavil:
To se najbolj opazi npr. ko gledaš film in kr take črte potujejo preko zaslona, kot nekakšni med seboj vzporedni valovi oz. pri WIn 8 kjer imaš metro in dokaj enobarvno ozadje vidiš da slika mal prsketa.. ni veliko ampak se opazi.
Yohan del Sud ::
Definitivno DVI, če je ena na ena, bo slika boljša, če sta napravi kompatibilni. No brainer. AMPAK:
So razlogi da imajo monitorji več tipov priklopov, pa ne gre samo za združljivost za nazaj. V mojem primeru. Dell 2405 (prvi primerek 24inčarja tega proizvajalca) ima pet možnih priklopov (vga, dvi, s-video, kompozit in komponent) in imam tri naprave gor priklopljene: mašino na dvi, server na vga in analogni tv sprejemnik na s-video. Preklapljam s prstom na knof.
www.strancar.com
blackbfm je izjavil:
Se pravi, moznost nenadzarovanega izpuljenja kabla je prednost.
Svasta.
marvin42 ::
Dr_M je izjavil:
Svasta.
Da, ker je možnost nenadzorovanega lomljenja konektorja slabost.
Mostly Harmless
blackbfm ::
a tebi komp leti po sobi s 5 m/s da ga moraš imeti z dvi kablom privezanega? ker v normalnih okoliščinah do izklopa pač ne more prit, pa tudi če, ni problema ker je hotpluggable
Sej je dovolj, da kisto premaknes za 20cm. Meni je se konstantno to dogajalo, dokler sem imel monitor na hdmi priklopljen.
Z dvi nobenih problemov.
Ce je tebi uspelo zlomit dvi konektor, potem se raje drzi stran od racunalnika.
usoban ::
hdmi je manjsi, kar je win :D
Mas tako majhno sobo, da ti dvi zasede prevec prostora?
Rec matki, da ti odpre pticjo kletko.
6151 ::
Displayport doublewin 8-)
7900X3D | 32GB | 6800 | 4 TB
Nepopolna slika na LCD monitorju
91304 (1169) miranpozar
Windows OneCare Live Beta (strani: 1 2 )
6510176 (6381) MrStein
Hanns g
161877 (1625) ender
ClearType in mavrica
Oddelek: Operacijski sistemi
302652 (2160) darkolord
Topel LCD zaslon in pekoče oči
404162 (2757) Hux
