Forum » Pomoč in nasveti » win 7 bsod - okvara matične ?
vander ::
Računalnik mi je delal brez problemov nekaj mesecev - pri istih nastavitvah, brez navijanja. Sedaj pa mi, največkrat v igrah (orginal) vse skupaj zašteka, pojavi se bsod, vendar samo kadar imam vstavljena dva ram modula 2x2 gb, z enim pa dela. Neglede z katerim ramom od teh dveh in ne glede v katero režo sta vstavljena. Rama sta v redu, preiskusil tudi drugi nov komplet drugega proizvajalca, ista zadeva.Preiskusil z drugim napajalnikom, drugo grafično, disk je v redu, posodobil bios in vse gonilnike. Naložil zadnje gonilnike za grafično. Sistem se ne pregreva. Prosim za pomoč, kajti na servisu niso ugotovili nič.
windows 7 64 bit
AMD Phenom IIx4 955
M4A79XTD EVO - matična
A-DATA DDR3 1600+ (cl 8-8-8-24;1,65-1,85 v)-ram
LC6600 600W - napajalnik
SAPPHIRE HD 4890 -grafična
V minidumpu mi napiše:
A problem has been detected and Windows has been shut down to prevent damage
to your computer.
The problem seems to be caused by the following file: ntoskrnl.exe
PAGE_FAULT_IN_NONPAGED_AREA
to your computer.
IRQL_NOT_LESS_OR_EQUAL
If this is the first time you've seen this stop error screen,
restart your computer. If this screen appears again, follow
these steps:
Check to make sure any new hardware or software is properly installed.
If this is a new installation, ask your hardware or software manufacturer
for any Windows updates you might need.
If problems continue, disable or remove any newly installed hardware
or software. Disable BIOS memory options such as caching or shadowing.
If you need to use safe mode to remove or disable components, restart
your computer, press F8 to select Advanced Startup Options, and then
select Safe Mode.
Technical Information:
*** STOP: 0x0000000a (0xfffffa7ffff9ffe0, 0x0000000000000002, 0x0000000000000001,
0xfffff80002ae6e7e)
*** ntoskrnl.exe - Address 0xfffff80002ac1600 base at 0xfffff80002a51000 DateStamp
0x4b88cfeb
these steps:
select Safe Mode.
*** STOP: 0x00000050 (0xfffff8a00fa1d000, 0x0000000000000000, 0xfffff8800401c42d,
0x0000000000000002)
*** ntoskrnl.exe - Address 0xfffff80002ac9600 base at 0xfffff80002a59000 DateStamp
0x4b88cfeb
windows 7 64 bit
AMD Phenom IIx4 955
to your computer.
to your computer.
these steps:
select Safe Mode.
0xfffff80002ae6e7e)
0x4b88cfeb
these steps:
select Safe Mode.
0x0000000000000002)
0x4b88cfeb
- spremenil: vander ()
vander ::
Odločil sem se, da bom zamenjal matično. Ali bo tale uredu ?
http://www.mimovrste.com/artikel/238007...
IvoJan ::
v dinokompu poglej za plate z 890GX chipsetom. Tale 770 je ze dokaj star.
BALAST ::
meni je take errorje dajalo ker je bil zanič ena palčka od ramov. (corsair ddr2 2x2Gb).
Pri meni se je sicer takoj pokazalo katera palčka je okvarjena, ker sem dobil BSOD, v prvih dveh minutah prime95 ali OCCT linpak testiranja. Pomagalo je en mesec stabilnosti, da sem dvignil napetost iz priporočene na +0.1V, ampak potem sem ga pa dal v garancijo.
vander ::
Če vstavim eno palčko rama - katerokoli od dveh, mi dela v redu, v kolikor pa vstavim dve se mi sesuje. V biosu sem nastavil voltažo na 1.66v, kar je priporočeno, vendar ne pomaga. Poiskusil tudi z drugimi rami (Patriot) isto sranje.
Xserces ::
na koncu bos drugo plato kupu in ti bo isto delal...
Xserces ::
procesor ima memory controller ze integreran kaj pa ce je to?
vander ::
Xserces ::
kaj bolj natacno memory controller je integreran v procesorju... torej procesor z ramom kontrolera... kaj pa ce je kaj t tem delom procesorja??
vander ::
Kako naj pa to ugotovim; niser ravno ekspert. Ampak, meni je zadeva delala nekaj mesecev brez problema.
vander ::
Oba rama (vsakega posebej) sem še enkrat preveril z memtestom in ni bilo najdenih napak. Z enim ramom računalnik dela, z dvema pa se sesuje. Dobrodošel vsak nasvet.
vander ::
Jast se še kar matram. Flešal sem bios, ročno nastavi tajminge in voltažo. Če vstavim palčki v različno obarvane reže, mi zadeva dela, seveda v single channel, v kolikor, pa jih vstavim v dual channel, pa mi sistem pri zagonu zamrzne pri windows logu.
| » | SSD intel 330 win7 instalacijaOddelek: Strojna oprema | 1278 (1157) | klemen1972 |
| » | Kako ugotoviti kaj mi serje? Bluescreeni...Oddelek: Pomoč in nasveti | 3366 (2757) | Cold1 |
| » | Win 7 blue screen in restartOddelek: Operacijski sistemi | 2926 (2665) | Duhec |
| » | Sesuvanje računalnikaOddelek: Pomoč in nasveti | 1716 (1512) | Mitch |
| » | Blue screen problem / windows crashOddelek: Pomoč in nasveti | 1192 (1104) | Xserces |
