How Do I Change The Silent Store Mode Guide: Maxtor diski
kuglvinkl ::
Odličen guide: This new Silent Store technology, as was revealed to me, enables the PC manufacturers (as well as the end-user) to configure the hard disk to run silently or at maximum performance.
Vodič
http://www.maxtor.com/en/support/downlo...
Acoustic Management adjusts the speed of the head seeks, reducing the ambient sound level during normal operation. This does not affect sound levels for power on operations. Drive performance can be affected when Acoustic Management is enabled.
* File Name: setacm.exe
* File Download Size: 156 KB
* File Version: 1.0
* Revision Date: 07/01/02
* Compatible Operating Systems: Windows NT, Windows XP, Windows 2000, Windows ME, Windows 98, Windows 95A, Windows 95B, DOS
The AMSET.EXE utility enables, disables, and sets levels for the Acoustic Management (operating sound levels) for the following hard drive families only:
-DiamondMax Plus 40 UDMA/100
-DiamondMax 60 UDMA/100
-DiamondMax VL 30 UDMA/100
-D540X
-D740X
NOTE: All Maxtor hard drives conform to the appropriate agency requirements for operating sound levels.
AMSET.EXE is contained in the file named SETACM.EXE. SETACM.EXE is a self-extracting file containing:
* AMSET.EXE - Utility for changing Acoustic Management on the DiamondMax VL 30, DiamondMax Plus 40 and DiamondMax 60 UDMA/66 ,UDMA/100 and UDMA/133) hard drives. This utility will function with all future products as well.
* CHIPSET.DRV - Driver Database File
* AMSET.TXT - This file
Maxtor recommends that you copy SETACM.EXE to a formatted, 3.5-inch floppy diskette. SETACM.EXE can be extracted either from a DOS Command prompt, by double clicking on the file from a Windows 95/98 or Windows NT environment. The files must be extracted in order to execute AMSET.EXE.
The AMSET utility (AMSET.EXE) can turn Acoustic Management off, or on (two on levels). The command flags (DOS-Based, command line switches) are:
/off - Turns Acoustic Management off, the drive operates at normal acoustic levels
/quiet - Quietest seeks, the speed of the seek operation is reduced to its lowest level to provide the quietest operations, this level has the most impact on drive performance.
/fast - Fastest seeks, the speed of the seek operation is reduced to provide quieter operation with the least amount of impact on the drive performance.
NOTE: AMSET.EXE is a DOS-Based, command line utility. It cannot be properly executed from a Windows 95/98/ME or Windows NT/2000/XP environment.
PROCEDURE FOR USING AMSET.EXE:
1. Using a system boot diskette clean-boot the system to an A: prompt.
2. Remove the system boot diskette and insert the diskette containing the AMSET.EXE and CHIPSET.DRV files.
3. From the A: prompt, type AMSET and press [Enter]. The following will be displayed:
Set Acoustic Management Mode -- Version x.x (x values vary pending on the version)
USAGE:
COMMAND LINE FLAGS
/off - Acoustic Management Off
EXAMPLE COMMAND LINE INPUTS
AMSET /fast
Press any key to continue
To this point, no changes have been made to the hard drive. After pressing a key you will be returned to the A: prompt.
4. From the A: prompt, type in AMSET /OFF (to disable Acoustic Management) and press [Enter]; or type in AMSET /FAST or type in AMSET /QUIET (to enable Acoustic Management) and press [Enter]. The switches are described above. For example, if you want fast hard drive seeks with the least impact on hard drive performance, you would type:
AMSET /FAST
Information will be displayed on the monitor indicating if drives are found and the action taken by the utility. In the example below "(Chip Set)" is the identifying information obtained from the IDE controller card (if installed) and/or the motherboard of the computer system.
Chipset.drv Version x.xx (x values vary pending on the version)
Searching for Maxtor Drives on (Chip Set) Primary . . . . .
Searching for Drive 0 . . . . .
Maxtor Drive 0 Found . . . . .
****** Acoustic Management Turned on (off) in the Maxtor Drive ******
Searching for Drive 1 . . . . .
Non-Maxtor Drive 1 Found . . . . .
Searching for Maxtor Drives on (Chip Set) Secondary . . . . .
No Drive Found . . . . .
NOTE: At least one set of information shown above is displayed. If there is, an IDE controller card installed in the computer system then a second set of information is displayed. The first set displayed is for the installed IDE Controller Card and the second for the motherboard. If a controller card is installed that utilizes a chipset not found in the CHIPSET.DRV file, the card and all devices attached will not be seen by this utility. Information for the motherboard will be displayed. If all IDE devices are connected to an unknown card the utility will report that no drives were found in the system. If this occurs contact Maxtor Technical Support and provide information about the controller card so that it can be investigated and the utility updated as appropriate.
5. Upon the completion of this utility, the system returns to the A: prompt. Remove the floppy diskette and power-cycle (shutdown/restart) the System.
The Maxtor hard drive remains set to the Acoustic Management level until reset by this utility. Repeat steps 1-5 if you wish to change the Acoustic Management level to a different setting.
PhotoBlaz ::
A je tole kdo sprobal??
Kaj je pa po defaultu nastavlen??
Ma punca en disk(nov 120Gb, 7200 2Mb, Diamond Max 9), k se mi zdi da vseen mal prevec naglas dela glede na ostale nove diske od maxtorja.
Tko da bi tole stvar sprobal....bi pa se prej rad zvedel, ce je kdo to kaj stimal in ce je varno( glede podatkov).
nodes ::
sprobal? poglej datum
dela dokler dela, privzeto je na fast
Disk Seagate st31000340as 1TB barracuda
424102 (2340) KTr1sk
Western Digital prehitel Seagate
Oddelek: Novice / Rezultati
3411697 (10710) Garibaldi
Diagnostično orodje za WD
Oddelek: Programska oprema
145049 (4909) clovk
NVRAID + Maxtor DiamodMax 10 trdi disk = BAD IDEA!!
112137 (1826) Jux
OK kateri SATA DISK ?
272259 (1913) Caligula
