Diagnostično orodje za WD
clovk ::
Pozdrav!
Sumim, d je vgrajen disk WD2500ks malo že slab in bi ga s kšnim orodjem pregledov, sam problem je ker mam Visto 64bitno in WD nima orodja za 64bitn OS, DOS verzija mi pa ne dela, ker nimam disketnika vgrajenga (sm dal DOS vezijo za CD na CD in se boota, sam u končni fazi napiše A:\... not acessible). Iščem po netu in ne najdm konkretnega orodja, ki bi mi loh v wins ali DOSu delal... Ve kdo za kakšnega?
Asus P5KC//8Gb//Q6700//Radeon 4870 1Gb
LuGi ::
NTFS4DOS.. in potem pozenes to aplikacijo preko tvojga diska.. should work.
Sale_One0 ::
Hiren`s BootCD 9.8 si poberi, zapeči na CD in bootaj z njim.
Spisek vseh utilitijev na njemu:
All in One Bootable CD which has all these utilities
Partition Tools
Partition Magic Pro 8.05
Best software to partition hard drive
Acronis Disk Director 10.0.2160
Popular disk management functions in a single suite
Paragon Partition Manager 7.0.1274
Universal tool for partitions
Partition Commander 9.01
The safe way to partition your hard drive,with undo feature
Ranish Partition Manager 2.44
a boot manager and hard disk partitioner.
The Partition Resizer 1.3.4
move and resize your partitions in one step and more.
Smart Fdisk 2.05
a simple harddisk partition manager
SPecial Fdisk 2000.03t
SPFDISK a partition tool.
eXtended Fdisk 0.9.3
XFDISK allows easy partition creation and edition
GDisk 1.1.1
Complete replacement for the DOS FDISK utility and more.
Super Fdisk 1.0
Create, delete, format partitions drives without destroying data.
Partition Table Editor 8.0
Partition Table and Boot Record Editor
Backup Tools
ImageCenter 5.6 (Drive Image 2002)
Best software to clone hard drive
Norton Ghost 11.5
Similar to Drive Image (with usb/scsi support)
Acronis True Image 8.1.945
Create an exact disk image for complete system backup and disk cloning.
Partition Saving 3.71
A tool to backup/restore partitions. (SavePart.exe)
COPYR.DMA Build013
A Tool for making copies of hard disks with bad sectors
DriveImageXML 2.02
backup any drive/partition to an image file, even if the drive is currently in use
Drive SnapShot 1.39
creates an exact Disk Image of your system into a file while windows is running.
Ghost Image Explorer 11.5
to add/remove/extract files from Ghost image file
DriveImage Explorer 5.0
to add/remove/extract files from Drive image file
WhitSoft File Splitter 4.5a
a Small File Split-Join Tool
Express Burn 4.25
CD/DVD Burner Program to create and record CDs/DVDs, also create/burn .iso and .nrg images
Smart Driver Backup 2.12
Easy backup of your Windows device drivers (also works from PE)
Double Driver 1.0
Driver Backup and Restore tool
DriverBackup! 1.0.3
Another handy tool to backup drivers
Recovery Tools
Active Partition Recovery 3.0
To Recover a Deleted partition.
Active Uneraser 3.0
To recover deleted files and folders on FAT and NTFS systems.
Ontrack Easy Recovery Pro 6.10
To Recover data that has been deleted/virus attack
Winternals Disk Commander 1.1
more than just a standard deleted-file recovery utility
TestDisk 6.10
Tool to check and undelete partition.
Lost & Found 1.06
a good old data recovery software.
DiyDataRecovery Diskpatch 2.1.100
An excellent data recovery software.
Prosoft Media Tools 5.0 v1.1.2.64
Another excellent data recovery software with many other options.
PhotoRec 6.10
File and pictures recovery Tool.
Winsock 2 Fix for 9x
to fix corrupted Winsock2 information by poorly written Internet programs
XP TCP/IP Repair 1.0
Repair your Windows XP Winsock and TCP/IP registry errors
Active Undelete 5.5
a tool to recover deleted files
Restoration 3.2.13
GetDataBack for FAT 2.31
Data recovery software for FAT file systems
GetDataBack for NTFS 2.31
Data recovery software for NTFS file systems
Recuva 1.24.399
Restore deleted files from Hard Drive, Digital Camera Memory Card, usb mp3 player...
Partition Find and Mount 2.3.1
Partition Find and Mount software is designed to find lost or deleted partitions
Unstoppable Copier 4b
Allows you to copy files from disks with problems such as bad sectors,
scratches or that just give errors when reading data.
Testing Tools
System Speed Test 4.78
it tests CPU, harddrive, ect.
PC-Check 6.5
Easy to use hardware tests
Ontrack Data Advisor 5.0
Powerful diagnostic tool for assessing the condition of your computer
The Troubleshooter 7.02
all kind of hardware testing tool
PC Doctor 2004
a benchmarking and information tool
CPU/Video/Disk Performance Test 5.7
a tool to test cpu, video, and disk
Test Hard Disk Drive 1.0
a tool to test Hard Disk Drive
Disk Speed1.0
Hard Disk Drive Speed Testing Tool
S&M Stress Test 1.9.1
cpu/hdd/memory benchmarking and information tool, including temperatures/fan speeds/voltages
Monitor Tester 1.0
Allows you to test CRT/LCD/TFT screens for dead pixels and diffective screens
RAM (Memory) Testing Tools
GoldMemory 5.07
RAM Test utility
Memtest86+ 2.11
PC Memory Test
MemTest 1.0
a Memory Testing Tool
Hard Disk Tools
Hard Disk Diagnostic Utilities
Seagate Seatools Graphical v2.13b
SeaTools for Dos 1.10
Western Digital Data Lifeguard Tools 11.2
Western Digital Diagnostics (DLGDIAG) 5.04f
Maxtor PowerMax 4.23
Maxtor amset utility 4.0
Maxtor(or any Hdd) Low Level Formatter 1.1
Fujitsu HDD Diagnostic Tool 7.00
Fujitsu IDE Low Level Format 1.0
Samsung HDD Utility(HUTIL) 2.10
Samsung Disk Diagnose (SHDIAG) 1.28
Samsung The Drive Diagnostic Utility (ESTOOL) 2.11
IBM/Hitachi Drive Fitness Test 4.14
IBM/Hitachi Feature Tool 2.11
Gateway GwScan 5.12
ExcelStor's ESTest 4.50
MHDD 4.6
WDClear 1.30
Toshiba Hard Disk Diagnostic 2.00b
HDD Regenerator 1.51
to recover a bad hard drive
HDAT2 4.53
main function is testing and repair (regenerates) bad sectors for detected devices
Ontrack Disk Manager 9.57
Disk Test/Format/Maintenance tool.
Norton Disk Doctor 2002
a tool to repair a damaged disk, or to diagnose your hard drive.
Norton Disk Editor 2002
a powerful disk editing, manual data recovery tool.
Hard Disk Sentinel 0.04
Hard Disk health, performance and temperature monitoring tool.
Active Kill Disk 4.1
Securely overwrites and destroys all data on physical drive.
SmartUDM 2.00
Hard Disk Drive S.M.A.R.T. Viewer.
Victoria 3.33e and 3.52rus
a freeware program for low-level HDD diagnostics
HDD Erase 4.0
Secure erase using a special feature built into most newer hard drives
HDD Scan 3.1
This is a Low-level HDD diagnostic tool, it scans surface find bad sectors etc.
HDTune 2.55
Hard disk benchmarking and information tool.
Data Shredder 1.0
A tool to Erase disk and files (also wipe free space) securely
System Information Tools
Aida16 2.14
a system information tool, extracts details of all components of the PC
PCI and AGP info Tool (0903)
The PCI System information & Exploration tool.
System Analyser 5.3u
View extensive information about your hardware
Navratil Software System Information 0.60.32
High-end professional system information tool
Astra 5.41
Advanced System info Tool and Reporting Assistant
HWiNFO 5.2.5
a powerful system information utility
PC-Config 9.33
Complete hardware detection of your computer
SysChk 2.46
Find out exactly what is under the hood of your PC
CPU Identification utility 1.16
Detailed information on CPU (CHKCPU.EXE)
CTIA CPU Information 2.7
another CPU information tool
Drive Temperature 1.0
Hard Disk Drive temperature meter
PC Wizard 2008.1.871
Powerful system information/benchmark utility designed especially for detection of hardware.
SIW 2009-02-24
Gathers detailed information about your system properties and settings.
CPU-Z 1.50
It gathers information on some of the main devices of your system
PCI 32 Sniffer 1.4 (0903)
device information tool (similar to unknown devices)
Unknown Devices 1.2 (0903)
helps you find what those unknown devices in Device Manager really are
MBR (Master Boot Record) Tools
MBRWork 1.07b
a utility to perform some common and uncommon MBR functions
MBR Tool 2.2.100
backup, verify, restore, edit, refresh, remove, display, re-write...
DiskMan4
all in one tool for cmos, bios, bootrecord and more
BootFix Utility
Run this utility if you get 'Invalid system disk'
MBR SAVE / RESTORE 2.1
BootSave and BootRest tools to save / restore MBR
Boot Partition 2.60
add Partition in the Windows NT/2000/XP Multi-boot loader
Partition Table Doctor 3.5
a tool to repair/modify mbr, bootsector, partition table
Smart Boot Manager 3.7.1
a multi boot manager
Bootmagic 8.0
This tool is for multi boot operating systems
MBRWizard 2.0b
Directly update and modify the MBR (Master Boot Record)
BIOS / CMOS Tools
CMOS 0.93
CMOS Save / Restore Tool
BIOS Cracker 4.8
BIOS password remover (cmospwd)
BIOS Cracker 1.4
BIOS password remover (cmospwc)
BIOS Utility 1.35.0
BIOS Informations, password, beep codes and more.
!BIOS 3.20
a powerfull utility for bios and cmos
DISKMAN4
a powerful all in one utility
UniFlash 1.40
bios flash utility
Kill CMOS
a tiny utility to wipe cmos
Award DMI Configuration Utility 2.43
DMI Configuration utility for modifying/viewing the MIDF contents.
MultiMedia Tools
Picture Viewer 1.94
Picture viewer for dos, supports more then 40 filetypes.
QuickView Pro 2.58
movie viewer for dos, supports many format including divx.
MpxPlay 1.56
a small Music Player for dos
Password Tools
Active Password Changer 3.0.420
To Reset User Password on windows NT/2000/XP/2003/Vista (FAT/NTFS)
Offline NT/2K/XP Password Changer
utility to reset windows nt/2000/xp administrator/user password.
Registry Reanimator 1.02
Check and Restore structure of the Damaged Registry files of NT/2K/XP
NTPWD
Registry Viewer 4.2
Registry Viewer/Editor for Win9x/Me/NT/2K/XP
ATAPWD 1.2
Hard Disk Password Utility
Content Advisor Password Remover 1.0
It Removes Content Advisor Password from Internet Explorer
Password Renew 1.1
Utility to (re)set windows passwords
WindowsGate 1.1
Enables/Disables Windows logon password validation
WinKeyFinder 1.73
Allows you to View and Change Windows XP/2003 Product Keys, backup and restore
activation related files, backup Microsoft Office 97, 2000 SP2, XP/2003 keys etc.
XP Key Reader 2.7
Can decode the XP-key on Local or Remote systems
ProduKey 1.35
Recovers lost the product key of your Windows/Office
Wireless Key View 1.20
Recovers all wireless network keys (WEP/WPA) stored in your computer by WZC
NTFS (FileSystems) Tools
NTFS Dos Pro 5.0
To access ntfs partitions from Dos
NTFS 4 Dos 1.9
Paragon Mount Everything 3.0
To access NTFS, Ext2FS, Ext3FS partitions from dos
NTFS Dos 3.02
EditBINI 1.01
to Edit boot.ini on NTFS Partition
Browsers / File Managers
Volkov Commander 4.99
Dos File Manager with LongFileName/ntfs support
(Similar to Norton Commander)
Dos Command Center 5.1
Classic dos-based file manager.
File Wizard 1.35
a file manager - colored files, drag and drop copy, move, delete etc.
File Maven 3.5
an advanced Dos file manager with high speed PC-to-PC file
transfers via serial or parallel cable
FastLynx 2.0
Dos file manager with Pc to Pc file transfer capability
LapLink 5.0
the smart way to transfer files and directories between PCs.
Dos Navigator 6.4.0
Dos File Manager, Norton Commander clone but has much more features.
Mini Windows 98
Can run from Ram Drive, with ntfs support,
Added 7-Zip, Disk Defragmenter, Notepad / RichText Editor,
Image Viewer, .avi .mpg .divx .xvid Movie Player, etc...
Mini Windows Xp
Portable Windows Xp that runs from CD/USB/Ram Drive, with Network and SATA support
7-Zip 4.65
File Manager/Archiver Supports 7z, ZIP, GZIP, BZIP2, TAR, RAR, CAB, ISO, ARJ, LZH, CHM, MSI, WIM, Z, CPIO, RPM, DEB and NSIS formats
Off By One Browser 3.5d
an independent web browser that runs completely self- contained
Other Tools
Ghost Walker 11.5
utility that changes the security ID (SID) for Windows NT, 2000 and XP
DosCDroast beta 2
Dos CD Burning Tools
Universal TCP/IP Network 6.4
MSDOS Network Client to connect via TCP/IP to a Microsoft based
network. The network can either be a peer-to-peer or a server based
network, it contains 91 different network card drivers
NewSID 4.10
Registry Editor PE 0.9c
Easy editing of remote registry hives and user profiles
Dos Tools
USB CD-Rom Driver 1
Standard usb_cd.sys driver for cd drive
Universal USB Driver 2
Panasonic v2.20 ASPI Manager for USB mass storage
ASUSTeK USB Driver 3
ASUS USB CD-ROM Device Driver Version 1.00
SCSI Support
SCSI Drivers for Dos
SATA Support
SATA Driver (gcdrom.sys) and JMicron JMB361 (xcdrom.sys) for Dos
1394 Firewire Support
1394 Firewire Drivers for Dos
Interlnk support at COM1
To access another computer from COM port
Interlnk support at LPT1
To access another computer from LPT port
and too many great dos tools
very good collection of dos utilities
extract.exe pkzip.exe pkunzip.exe unrar.exe rar.exe
ace.exe lha.exe gzip.exe uharcd.exe mouse.com
attrib.com deltree.exe xcopy.exe diskcopy.com imgExtrc.exe
undelete.com edit.com fdisk.exe fdisk2.exe fdisk3.exe
lf.exe delpart.exe wipe.com zap.com format.com
move.exe more.com find.exe hex.exe debug.exe
split.exe mem.exe mi.com sys.com smartdrv.exe
xmsdsk.exe killer.exe share.exe scandisk.exe scanreg.exe
guest.exe doskey.exe duse.exe biosdtct.exe setver.exe
intersvr.exe interlnk.exe loadlin.exe lfndos.exe doslfn.com
Cleaners
SpaceMonger 1.4
keeping track of the free space on your computer
WinDirStat 1.1.2.80
a disk usage statistics viewer and cleanup tool for Windows.
CCleaner 2.17.853
Crap Cleaner is a freeware system optimization and privacy tool
Optimizers
PageDfrg 2.32
System file Defragmenter For NT/2k/XP
NT Registry Optimizer 1.1j
Registry Optimization for Windows NT/2000/2003/XP/Vista
DefragNT 1.9
This tool presents the user with many options for disk defragmenting
JkDefrag 3.36
Free disk defragment and optimize utility for Windows 2000/2003/XP/Vista
Process Tools
IB Process Manager 1.04
a little process manager for 9x/2k, shows dll info etc.
Process Explorer 11.33
shows you information about which handles and DLLs processes have opened or loaded
Pocket KillBox 2.0.0.978
can be used to get rid of files that stubbornly refuse to allow you to delete them
Unlocker 1.8.7
This tool can delete file/folder when you get this message - Cannot delete file:
Access is denied, The file is in use by another program etc.
CurrPorts 1.60
displays the list of all currently opened TCP and UDP ports on your computer
Startup Tools
Autoruns 9.39
Displays All the entries from startup folder, Run, RunOnce, and other Registry keys,
Explorer shell extensions,toolbars, browser helper objects, Winlogon notifications,
auto-start services, Scheduled Tasks, Winsock, LSA Providers, Remove Drivers
and much more which helps to remove nasty spyware/adware and viruses.
Silent Runners Revision 59
A free script that helps detect spyware, malware and adware in the startup process
Startup Control Panel 2.8
a tool to edit startup programs
Startup Monitor 1.02
it notifies you when any program registers itself to run at system startup
HijackThis 2.0.2
a general homepage hijackers detector and remover and more
Tweakers
Dial a Fix 0.60.0.24
Fix errors and problems with COM/ActiveX object errors and missing registry entries,
Automatic Updates, SSL, HTTPS, and Cryptography service (signing/verification)
issues, Reinstall internet explorer etc. comes with the policy scanner
Ultimate Windows Tweaker 1.0
A TweakUI Utility for tweaking and optimizing Windows Vista
TweakUI 2.10
This PowerToy gives you access to system settings that are not exposed in the Windows Xp
Xp-AntiSpy 3.97.2
it tweaks some Windows XP functions, and disables some unneeded Windows services quickly
Shell Extensions Manager (ShellExView) 1.36
An excellent tool to View and Manage all installed Context-menu/Shell extensions
EzPcFix 1.0.0.16
Helpful tool when trying to remove viruses, spyware, and malware
Antivirus Tools
ClamWin Antivirus 0.94.1 (0903)
a free antivirus, GNU GPL Open Source Virus Scanner
Spybot - Search & Destroy 1.6.2 (0903)
Application to scan for spyware, adware, hijackers and other malicious software.
Malwarebytes' Anti-Malware 1.34 (0903)
anti-malware application that can thoroughly remove even the most advanced malware.
SpywareBlaster 4.1 (0903)
Prevent the installation of spyware and other potentially unwanted software.
SmitFraudFix 2.400
This removes Some of the popular Desktop Hijack malware
ComboFix (0903)
Designed to cleanup malware infections and restore settings modified by malware
CWShredder 2.19
Popular CoolWebSearch Trojan Remover tool
RootkitRevealer 1.7.1
Rootkit Revealer is an advanced patent-pending root kit detection utility.
Ad-Aware SE Personal 1.06 (0903)
find and remove spyware, adware, dialers etc. (a must have tool)
Hiren's Bootcd 9.8 (158MB)
Si vis pacem, para bellum.
clovk ::
Hm... Ok vem, da od tega posta naprej tema spada drugam, ampak jo bom tu nadaljevov...
Zadeva je taka, da ko je bil disk še v zunanjem ohišju mi je pred parimi dnevi padu na tla, neki cajta delov bp, pol pa kr naekrat ga comp ni več prpoznov oz disk bi bilo treba formatirati skos ponavljov. Zato so ga vgradu direkt notr in dela, sam vsake tok časa (2min-1h) nrdi: "klik-psssssss" se prav neki preskoč, se odvrti, ustav in zažene nazaj. Torej je nekaj narobe... Vsi programi mi pravjo, d je zdrav (Winsi, O&O...), par stvari s Hiren's CDja mi tudi nič ne najde. Kaj zdej čakam d crkne al kaj?
fosil ::
Na uradni strani, na www.wdc.com ti ni uspelo najti?
Tako je!
clovk ::
Aha, se opravičujem, mogu bi bit bol jasn:
Data Lifeguard Tools 11.2 for Windows (http://support.wdc.com/product/download...) mi ne dela, ker mam 64bitni OS
Supported Operating Systems:
* Windows 2000
* Windows XP
* Windows ME
* Windows 98SE
* Windows 98
Data Lifeguard Tools 11.2 for DOS (CD) mi pa ne dela, ker nimam Floppy
Z Hiren's boot CD-ja mi dela DLT 11.2, samo ne najde napak.
Dovolj jasno?
  • spremenil: clovk ()
misek ::
Zakaj ti Data Lifeguard Tools 11.2 for DOS (CD) ne dela? Pa zakaj omenjaš flopy? Saj je ta namenjen za peko na CD in boot iz njega, če prav razumem navodila tukaj:
Instructions
Download the DLG_V11_2.zip file to your desktop.
Extract the contents of the DLG_V11_2.zip file to your desktop with a file extraction utility.
You will see a new file named DLG_V11_2.iso on your desktop.
You must use a CD burning program (such as Nero Burning Rom or EZ-CD Creator) to burn a CD from the .ISO image.
You can now boot the computer to the CD or run the CD from Windows. Make sure your boot order in your BIOS is set to boot to the CD-ROM drive first.
Once installed, you will be prompted to run the program or may run the program manually from either the programs menu or from the shortcut on your desktop.
You will see the following options:
VIEW INSTALLATION TUTORIAL - Instructions on how to connect your new hard drive to the computer.
SETUP YOUR HARD DRIVE - Setup a hard drive already connected to your computer.
DRIVE-TO-DRIVE COPY - Copy all the files or a specific folder from one drive to another.
HARD DRIVE INFORMATION - Jumper Settings and other technical information about your hard drive.
Select the task you wish to perform.
clovk ::
Sm prebral navodila, sm si jih tudi stiskal, sam ko boota s CD-ja mi najprej neki melje, nato napiše da manka Licence.txt in je ne more izpisat in vprašat, če se strinjam, pol še neki cajta melje in na koncu izpljune, da A:\neki neki ni dostopen vstavite pravi disk... Nism si js kr zmislu neki o Floppy-ju, ampak si je comp :P
No karkol, Hiren's CD (in stem LDT) dela odlično :D tisočkrat hvala!!! :D
bi mi loh zdej kdo odgovoril kaj je narobe s trdim diskom?
subby ::
najboljš da downloadaš UBCD. to je bootable cd, kjer maš vsa različna diag orodja.. za dost različnih diskov(med njimi tudi wd), rame pa še marsikaj
terryww ::
In kaj je narobe s SpinRite?
http://www.grc.com/srreviews.htm
Sale_One0 ::
Glede na to da disk spušča čudne zvoke vsake tolko, bi bilo dobro da si narediš backup vseh stvari katere imaš gor. Odvisno iz kake višine je padel, na kako podlago, pod kakim kotom...., lahko da umira. Mogoče reklamacija, če se mu ne pozna da je padel po tleh(kar bi bila tvoja krivda in se ne upošteva pod garancijo) če je še v garancijskem roku.
Glede diagnostičnih programov pa takole, lahko da bodo zaznali napako samo tisti moment ko se disk začne čudno oglašati oz. "praskati".
LP,
Sale
ender ::
A si ga sprobal? Ker če bi ga, bi videl, da dela na Visti x64 brez kakršnih koli problemov.
Ker gre za bootable CD, ne vidim, kakšno vezo ima pri tem floppy.
grc.com je narobe.
clovk ::
Sm sprobal in se noče inštalirat...
Js tud ne vidim, kaj, kako in zakaj, ampak samo da ne dela...
ender ::
Mimogrede, povezava, ki si jo dal v prvem sporočilu je napačna - ti rabiš Data LifeGuard Diagnostic.
clovk ::
Evo opravil extended test s LifeGuardom, ugotovitve: disk čudne zvoke spušča SAMO kadar je idle ;) torej, ko kakršnkol test teče - dela, kuj ko neha začne "praskat"
učasih se mi zdi d me prov zanalašč jebe u glavo :D
Windows 95 dve desetletji pozneje (strani: 1 2 3 )
11743586 (37057) Spajky
Pomoč pri HP prenosniku
213089 (2904) Gutjerez
seatools
202388 (2233) StratOS
od 160gb diska prikaže le 32, prvo mi je v partition magic prikazalo 160...
202512 (2188) sirotka
trdi disk hitachi
282531 (2166) kerrigh
