Novice » NWO » Danes opaženo na Internetih
redo ::
WarpedGone je izjavil:
10 najbojl iskanih poklicev leta 2010, leta 2004 sploh še ni obstajalo.
Odgovori sam sebi, kako se naj bi leta 2004 učilo za te poklice?
Katerih 10 poklicev pa je bilo najbolj iskanih?
WarpedGone ::
Vpraš Turka, sm potegnu iz te njegove predstavitve.
Lahko oporekaš resničnost, ne moreš oporekat nekonsistentnost predstavitve.
Zbogom in hvala za vse ribe
alphasaphir ::
_Enterprise_ ::
slotech haterji bodo hejtal. pa tudi če zaradi izgleda slajdov, hejtat je treba! kulture ne damo, patrijo damo!
OK, po ogledu videa sem spremenil svoje mnenje. Če so to kulturniki in je njihovo obnašanje "kulturno", me je zelo sram.
Žiga, imate mojo podporo.
- spremenil: opeter ()
alphasaphir ::
alphasaphir ::
_Enterprise_ je izjavil:
angleščino iz kompjuterjev, obvezni izpiti is slovenjščine! Sovražim hejtanje.
Papa štrumf a je še daleč?
- spremenil: alphasaphir ()
modicr ::
Fact or Fiction?
http://www.rila.org/news/newsletters/as...
"original comments from former Secretary of Education Richard Riley. It turns out that he did say this and was quoted in a book titled: The Jobs Revolution: Changing How America Works. But, here is the important fact that solves the mystery – the book was published in 2004. If you go back and look at the quote, it now seems clear what has happened.
In 2004, Riley was making a prediction that he likely intended to make a point about how the pace of change would continue in the upcoming years. That is far different that reporting his prediction as a fact in 2009 when it has clearly not come true.
Now, I don’t think the owner of the original news ticker that I read was trying to mislead anyone. They simply picked up a widely circulated item and phrased it as a fact. But, it certainly would make me question the credibility of other facts that I read on that ticker in the future. Perhaps there is a lesson for all of us in this example."
(c) nisem patentiran
WarpedGone ::
Domet desnice je cca 90 cm, glih ene tolk kot domet levice.
borisk ::
Kar se prosojnic tiče, je zadeva všečna, glede na to, kar so kazali predhodnjiki.
Se mi pa zdi ogromna napaka združevati ministrstvo za kulturo in znanost. TO so 2 popolnoma različni zadevi, ki nista kompatibilni.
alphasaphir ::
enadvatri ::
mikimisek ::
Tale Ziga Turk je bil moj profesor na faksu 6 ali 7 let nazaj. Tip ima nekaj pojma o racunalnistvu (vec kot vsi ministri skupaj) in zna povedat kaksen vic da debata lazje tece. Je ze takrat imel nekako napredne ideje glede solstva in ostalega. Zdaj je prisel h koritu in upam da bo lahko uveljavil ideje pa ceprav bodo mogoce katere mimo. Vendar je bil v solstvu in ve v cem je problem... upam.
_Enterprise_ ::
hruske ::
@x800xt Gre za mantro SDS, ki vidi izhod iz krize v usmerjanju gospodarstva v proizvajanje izdelkov za bogate. Torej, Akrapovičevi auspuhi, Seawayeve jahte, itn.
alphasaphir ::
Tole je zajebancija ali dejanski domet desnice?obrazloži, kaj te toliko moti, ker drugače boš pač hater ki hejta
Od zagovornika akte je pričakovati, da se je bo držal. Forma v predstavitvi je kot že večkrat navedeno pomanjkljiva, sploh če je avtor minister in profesor na univerzi. Umakniti angleščino in tujke iz kompjuterjev je več kot očitno ironično mišljeno ali pa neumnost. Če je predstavitev brez spremljevalnega audio mateirala pomanjkljiva in se avtor želi na to zgovarjati, jo pa naj objavi kot je objavil vizualen del predstavitve. Tisti citat o 10 delovnih mestih je tudi uporabljen izven konteksta in očitno tudi narobe. Par populističnih v smislu "rdeče" kave napram pošteni kavi, primerjanje podatkov, ki so verjetno pridobljeni z wavelet in fourierjevo transformacijo brez povdarka na znanstveni metodi, je za znanstvenika diskreditacija, trditev, da je problem preveč informacij pri tem pa v celoti pozabi na metapodatke, izpostavljanje glave kot moškega aspekta in žensko prikazat kot...
eh ja. Kritiki bodo kritizirali in ostali trololololo
Bellatrix ::
alphasaphir je izjavil:
Problem vas levih je, da ste ravno dovolj učeni, da znate obrnit besede sebi v korist. To je pa nažalost vse kar premorete.
People are quick to judge and slow to correct themselves.
- spremenil: Bellatrix ()
alphasaphir ::
Da, ker sem levi in imam kakršnokoli korist od tega, da izrazim mnenje. Res pa je, da se izobražujem! Tudi to je res, da je znanje poleg ljubezni vse kar premorem. Sem prepričan, da mi bo osebno šlo ekonomsko boljše pod to vlado, kot pod prejšnjo. To pa nikakor ne pomeni, da nimam večjih pričakovanj. Ti, ki so bili prej na oblasti so bili še bolj nesposobni. Upam namreč, da bodo ti sposobni kritiko sprejet in se naDgradit.
Še to: minister zelo dobro ve, da smo ljudje predvsem vizualna bitja. Eni se ne in zato gladko nasedajo populizmu.
Pa še ta odgovor @Bellatrix: "haters gonna hate" :P
_Enterprise_ ::
Od zagovornika akte je pričakovati, da se je bo držal. Forma v predstavitvi je kot že večkrat navedeno pomanjkljiva, sploh če je avtor minister in profesor na univerzi. Umakniti angleščino in tujke iz kompjuterjev je več kot očitno ironično mišljeno ali pa neumnost. Če je predstavitev brez spremljevalnega audio mateirala pomanjkljiva in se avtor želi na to zgovarjati, jo pa naj objavi kot je objavil vizualen del predstavitve. Tisti citat o 10 delovnih mestih je tudi uporabljen izven konteksta in očitno tudi narobe. Par populističnih v smislu "rdeče" kave napram pošteni kavi, primerjanje podatkov, ki so verjetno pridobljeni z wavelet in fourierjevo transformacijo brez povdarka na znanstveni metodi, je za znanstvenika diskreditacija, trditev, da je problem preveč informacij pri tem pa v celoti pozabi na metapodatke, izpostavljanje glave kot moškega aspekta in žensko prikazat kot...model, to ni znanstvena raziskava, ampak poljudna populistična predstavitev. mogoče una o neobstoječih poklicih 6 let prej ni čisto točna, ampak tukej zgolj opozarja na bistvo. v tistem primerjanju kave ne izraža svojega mnenja o tem, katera kava je boljša, ampak na nove družbene trende; zato tudi omenja apple, prodajanje motorjev tistim ki že imajo avto itd. in "če je predstavitev brez spremljevalnega audio materiala pomanjkljiva" verjetno ni vprašanje, ker JE pomanjkljiva brez spremljevalnega audio materiala. še enkrat, ni to znanstvena raziskava, tudi pretirava kdaj, ampak osnovno bistvo je zadel. obešati se na "umikanje angleščine iz kompjuterjev" je pa tudi primitivno in, kot je zgoraj nekdo napisal, obračanje besed sebi v korist. pač populistična izjava, ki ni nič slabega, niti ni jasno, koliko jo bo mogoče izpeljati, je pa vsaj težnja v pravo smer.
@x800xt Gre za mantro SDS, ki vidi izhod iz krize v usmerjanju gospodarstva v proizvajanje izdelkov za bogate. Torej, Akrapovičevi auspuhi, Seawayeve jahte, itn.bolj kot za "mantro SDS" gre za principe sodobnega kapitalizma uspešnih (ameriških, zahodnoevropskih) podjetij. poudarek na uspešnih
WarpedGone ::
Gre še več kot za kake posebne principe - gre za osnovno logiko.
Če greš proizvajat poceni izdelke pričakuj plačo kot jo imajo drugi proizvajalci poceni izdelkov - npr kitajci, dolar na dan.
Če hočeš višjo plačo, boš moral pač proizvajat tisto, kar proizvajajo ljudje z višjo plačo.
Nazadnje ko sm gledal izdelkov za bogate (še) ne (vse) proivajajo Kitajci.
alphasaphir ::
@ Enterprise : Model pa saj zato pravim, da je populistično. In zato ali zajebancija ali prikaz omejenosti, glede na to, da se je s pomočjo tega predstavil in šel v igro za ministra (ki bi naj bil tudi strokovnjak, ne samo "diplomat brez listnice" ali po novem celo "poljuden populist"). Bistvo je pa zadel, ja. Z eno od slikic za katero nima urejenih pravic. Ko je govora o rdeči kavi, je govora o vrednotah ne o trendih. Poglej si slikco.
Če od voditeljev pričakujete populizem in vam je to dovolj potem pa smo FUUUUUUUkt. big time.
In glede na to, da zlorablja izsledke, predvidevam da korektnih znanstvenih raziskav, cilj ne more biti samo poljudna populistična predstavitev. Ali hoče podajat informacije s pomočjo katerih se bo lažje pametno odločat ali pa trololololola. Saj mu je nekdo na blogu napisal, da parafraziram: "boj se prijateljev/podpornikov, ker so butli"
Bistvo "dodane vrednosti" je znanje! Strokovnost in ne populizem!
73837 ::
Osebno me najbolj fascinira novorek, ki ga uporablja prihodnji minister pa tudi njegova stranka, iz katere so pravzaprav prišle ideje o novih mimistrstvih. Vse skupaj močno spominja na preroški Orwellov 1984.
V romanu je državni aparat zreduciran na samo štiri ministrstva:
- Ministrstvo ljubezni (iskanje, zasledovanje in prevzgoja prestopnikov)
- Ministrstvo resnice (propaganda)
- Ministrstvo miru (vojna)
- Ministrstvo obilja (preskrba s hrano in drugimi potrebščinami)
Seveda ni težko najti vzorcev in potegniti vzporednic z današnjim časom ter dogodki tako na lokalni ravni kot globalno. Branje romana toplo priporočam vsakomur, ki si želi razširiti obzorja, razumeti svetovne dogodke od 1945 pa do danes, razumeti globalizacijo in tehnološko revolucijo ter nenazadnje videti obrise prihodnosti.
Je naključje, da si minister za izobraževanje želi glav in src svojih državljanov?
Če naredimo politično nekorektno izpeljavo, bi lahko sklepali, da si novi minister želi ozko razgledane, visoko specializirane, projektno naučene, poslušne in lojalne nove državljane.
Živela prihodnost!
Živela prihodnost!
Vpraš Turka, sm potegnu iz te njegove predstavitve.Oporekaš lahko zdravi pameti tistega, ki trdi, da 10 sedaj najbolj iskanih poklicev pred šestimi leti še ni obstajalo. Ker bi moralo biti vsakomur jasno, da te ne more biti res. Ali je Turk tako lahkoveren, da verjame vsaki floskuli, ki jo sname z neta, ali je tako odmaknjen od resničnega sveta, da pojma nima, kateri so najbolj iskani poklici, ali pa namenoma zavaja z lažnimi podatki.
O.
Samo dramatičen je hotu bit, pa "Shift Happens" video je gledu in ga je fasciniral. Sej un "The Last of the Mohicans" soundtrack je res kul.
Kakšna je resnična statistika se mu ni ljubilo niti zguglat.
smash ::
1. Bloggers
2. Community managers or content managers
3. Green funeral directors
4. Interior redesigners
5. Patient advocates
6. Senior move management
7. Social media strategists
8. User experience analyst
9. Video journalists
10. Virtual business service providers
alphasaphir ::
11. večni študent
da prehitim zagovornike: "haters gonna hate!"
Kaj ima pa knjiga s tem veze. Znanstvena fantastika, kultura pa taka!
sarcasm off: obstaja tudi film za vse, ki nimate kindlov.
Živela prihodnost!
1. BloggersKaj je že to? Nekaj se spomnim, da se je pred leti dosti govorilo o tem, potem je pa vse potihnilo.
O.
modicr ::
No, saj po definiciji so novi poklici najbolj iskani
Povpraševanje je statistično glede na prejšnje leto (ko novega poklica še ni bilo) naraslo za neskončno procentov ...
Tule je še eno sveže poročilo: http://www.theatlantic.com/business/arc...
The Top 10 Growing Occupations: 2010 - 2020
01: Registered nurses
02: Retail salespersons
03: Home health aides
04: Personal care aides
05: Office clerks, general
06: Combined food preparation and serving workers, including fast food
07: Customer service representatives
08: Heavy and tractor-trailer truck drivers
09: Laborers and freight, stock, and material movers
10: Post-secondary teachers
The Top 10 Shrinking Occupations: 2010 - 2020
01: Farmers, ranchers, and other agricultural managers
02: Postal Service mail sorters, processors, and sorting machine operators
03: Sewing machine operators
04: Postal Service mail carriers
05: Switchboard operators, including answering service
06: Postal Service clerks
07? Fast food cooks (In their last published employment outlook, the BLS predicted there would be more fast food cooks in the coming years, so their appearance on the list is a bit of a mystery.)
08: Miscellaneous agricultural workers
09: Data-entry keyers
10: Word processors and typists
- spremenil: modicr ()
alphasaphir ::
No, saj po definiciji so novi poklici najbolj iskani![]()
najbolj BOLJ iskani :D
Fast food cooks-->cooks-->nutritionists
madmitch ::
Dejte se zdaj na vejce, ki jih sicer dosti manjka ali pa so narobe uporabljene, obešat s temi desetimi poklici. A ni nekje tut sonce omenjal in na eni fotki ga bejba v roki drži (sonce namreč). A boste tukaj tudi tulili, da to pa ne gre. A za figurativno izražanje še niste slišal al se skregate z vsakim, ki vam reče, da se že sto let nista videla?
Mene dejansko bolj skrbi to, da bo naravoslovni tehnofil z zameti ezoterike odločal o kulturi. Pa še tisti protest v pasaži, men se je zdel čist kulturen, razen tistega dežurnega na koncu. Taki so pa itak pri vsaki pasji procesiji zraven, ker a) majo majhne lulčke in se morajo duvat, saj ste videli, kako jo je hitro ucvrl, ko je opravil svoje junaško dejanje, b) so plačani.
murmur ::
alphasaphir ::
gre če si the real kekec in imaš v drugi še smeh.
Ampak bi znal pa bit tak profil zanimiv za učitelja računalništva na SŠ.
Osebno ga imam rahlo v želodcu, ker se je plehko izrazil za akto. Možno, da je med plevom eno izmed redkih zrn, ampak saj ga bodo prijatelji zahodili.
Upam, da je tole cinizem?
Če ni, potem mora biti ironija. Tista poanta v tragikomediji, ki se je junak zgodbe ne zaveda.
ps: lep praznik kulture vsem, da spet ne pozabim.
modicr ::
Mogoče je bilo bolj mišljeno v smislu "deset najbolj 'jaz-si-želim-biti' poklicev ... ni obstajalo", kar je pričakovano za mladega in radovednega človeka. Se pa seveda želje bodočih delojemalcev dostikrat ne skladajo z željami delodajalcev ...
madmitch ::
modicr, saj vidiš da so takoj privlekli ameriške raziskave ven, ki nimajo z nami popolnoma nič, razne picopeke in podobne znanstvenike. Človek je dal pač primer, malo ga je priredil svojemu trenutnemu dojemalju, ker je kot politik prešel z desetiškega ali binarnega dojemanja na 4 letke (ok, malo raztegnjene) in to je to. Dejstvo je, da ogromno poklicev, ki so danes zelo zaželeni, še ne tako dolgo nazaj ni obstajalo niti v romanih, tako kot ogromno poklicev, ki so takrat bili, danes niti ne vemo za njih, kdo še ve, da je bil, kaj šele kje, nekoč nogavičar v Ljubljani, ki je babje najlonke popravljal.
Tudi ti si falil, mislil je točno to, kar piše, marsikaterega trenutno top poklica še ne tako dolgo nazaj ni bilo. Nimata ne želja ne delodajalec nič s tem.
Tudi meni ni najljubši, ker vem da je poniglav in bo sledil delu in liku Velikega Vodje, vseeno mu pa ni treba očitat ravno tistega, kar je povsem nepomembno in iztrgano iz konteksta. Kot je nekdo napisal, tole PP skrpucalo, povsem neprimerno kandidatu za ministra za šolstvo in kulturo je samo in nič drugega kot EPP blok za prepričevanje prepričanih.
- spremenil: madmitch ()
Mogoče je bilo bolj mišljeno v smisluMišljeno je bilo v smislu "tule je en šokanten podatek, za katerega sigurno niste vedeli (jaz pa vem, ker sem pameten in berem internete)". Večkrat videno pri pisanju recimo Mišota Alkalaja.
O.
- spremenil: Okapi ()
madmitch ::
Okapi, žalit pa ni treba in ga primerjat z Alkalajem.
Da bere internetE...
modicr ::
Saj na slajdu #51 on omenja ZDA
Tudi meni ni najljubši, ker vem da je poniglav in bo sledil delu in liku Velikega Vodje,Kako pa drugače?
Ne?
Pri Pahorju smo pogrešali, da ni znal nastavit takšnih, ki bi opravili delo. Pri JJ bomo, se mi zdi, isto.
Samo če lahko vsak dela po svoje, zakaj bi potem recimo Janša nosil kakršnokoli odgovornost za njihovo delo? Po tej logiki on pač izbere ministre in gre na Karibe za štiri leta, ali kako?
- spremenil: Gregor P ()
Gregor P> Samo če lahko vsak dela po svoje, zakaj bi potem recimo Janša nosil kakršnokoli odgovornost za njihovo delo? Po tej logiki on pač izbere ministre in gre na Karibe za štiri leta, ali kako?
Kolikor jaz razumem je delo ministrov omejeno s cilji, ne pa z implementacijo.
| » | Mednarodna delavnica in okrogla miza: "Soobstoj z umetno inteligenco" (strani: 1 2 )Oddelek: Novice / Znanost in tehnologija | 27049 (24741) | Timurlenk |
| » | Danes opaženo na Internetih (strani: 1 2 3 )Oddelek: Novice / NWO | 55180 (48091) | enadvatri |
| » | Netko 2005Oddelek: Novice / Omrežja / internet | 4364 (3702) | comet |
| » | Tudi v Sloveniji razvijajo procesorjeOddelek: Novice / Procesorji | 3285 (3285) | Red_Mamba |
