Zaposlitev freelancerja
kilobajt ::
Pozdravljeni,
ali mogoče kdo ve, kako je v sloveniji z zakoni, če vzameš freelancerja (ne vem niti kako bi se tole točno prevedlo). Na internetu jih je na tisoče. Zanima me, ali je legalno, če dobiš nek posel, ga daš njemu, da ga naredi, ti pa obdržiš razliko? Ali mogoče kdo pozna, kje bi našel prav zakone kjer je to napisano? Našel sem samo na wikipediji (spodaj), ampak ni nič kaj jasno napisano kaj ja in kaj ne.. še posebej kako je s tem v Sloveniji? Ali pa kam naj se obrnem?
In Europe, the perceived disadvantages of being freelance have led the European Union to research the area, producing draft papers that would, if enforced, make it illegal for companies or organizations to employ freelancers directly, unless the freelancer was entitled to benefits such as pension contributions and holiday pay. In the UK, where the terms of integration into the EU have and are being hotly debated, this would lead to a significant reshaping of the way freelance work is dealt with and have a major impact on industry; employers would be required either to give freelances the contractual rights of employees or employ only freelancers already being employed by agencies or other organizations granting them these rights. However, the White Papers that recommend such moves have not yet been adopted in the EU, and the potential impact on UK employment laws is being opposed by key UK organizations lobbying the government to negotiate over the acceptance of EU legislation in such areas.[citation needed] The legal definition of a sole trader requires that he/she must have more than one client or customer which promotes the freelancing ethos,
Za vsak dober nasvet se že v naprej najpelše zahvaljujem.
Isotropic ::
temu se rece, da ga vzames prek sp, avtorske, podjemne pogodbe...
kilobajt ::
Ali je tole legalno v sloveniji? Ali mogoče veš kje bi lahko našel kaj več na tole temo?
Gladi ::
Seveda je legalno, na načine ki jih je omenil loki
kilobajt ::
Kaj pa je potem s tem?
..draft papers that would, if enforced, make it illegal for companies or organizations to employ freelancers directly, unless the freelancer was entitled to benefits such as pension contributions and holiday pay.
Ali je treba upoštevati tudi kašne EU zakone, ki so višji od naših?
St235 ::
V bistvu EU zakoni niso nad našimi in to kar bereš je wikipedia in ne nek EU zakon.
Zate je edino relevantna slo zakonodaja. Zaposlitev freelancerja kot takega je možnana načine, ki jih predvideva slovenska zakonodaja. Sklepam, da te redno delovno razmerje ne zanima, torej ti ostane avtorska pogodba, podjemna poogdba, študentski servis ali plačilo preko računa.
Če gre za tujca je slednje daleč najlažje, samo to pomeni, da mora on imet neko obliko pravne osebe.
  • spremenil: St235 ()
kilobajt ::
Kaj pa to pomeni "obliko pravne osebe"?
overlord_tm ::
kilobajt je izjavil:
d.o.o., s.p., d.d, d.n.o so pravne osebe (poleg tega pomoje tudi drustva, zdruzenja itd ...)
kilobajt ::
Saj pravna oseba vem kaj je, samo ne razumem pa, kako bi se tole skladalo s freelancerjem. Ali niso tole ravno ljudje, kot so študenti in ostali, ki delajo pač zraven drugega še to? Ali potem njih ne smeš najeti?
Ali je tako, da vsak, ki kaj dela, ima itaq prijavljen sp. ali pa kaj podobnega.. drugače sploh ne smejo delati?
Skatey ::
Če hočeš biti freelancer legalno v sloveniji je najlažje:
- najamejo te preko avtorske pogodbe
- odpreš popoldanski s.p. / navadni s.p.
- imaš dno, doo itd.
Če si delodajalec boš freelancerja vzel:
- preko avtorske (kjer bosta napisala kaj vse delaš, koliko denarja dobiš itd.)
- ti bo freelancer izdal račun preko svojega s.p/d.o.o/d.n.o
- izdal študentsko napotnico.
To so metode za najem freelancerjev. In ja, če nimaš ene od teh variant oz. podpisane avtorske pogodbe in dobiš denar na roko je to delo na črno.
Design, elephants and stuff... www.yukaii.com/blog
kilobajt ::
Uuuu full vam hvala za vse odgovore :)
Samo še eno vprašanje.. Saj, če prav razumem, je s tujino isto.. samo, da tam ni študentske napotnice... Se pravi avtorska pogodba in račun preko njegovega s.p. itd.. Ali za avtorsko pogodbo mora biti on tudi pravna oseba?
IceIceBaby ::
Načeloma tistega, ki najame človeka zanima samo to, ali ti lahko ta človek izda račun. Če od njega dobiš papir z zneskom in tvojo davčno številko si pokrit. Jaz se nikoli ne vtikam v to, kako imajo ti ljudje naprej urejeno v svoji državi.
Ne. Avtor (tisti, ki ga ti najameš) je vedno fizična oseba. Podjetje ne more delati preko avtorske pogodbe.
Freelancer je nekdo, ki ni redno zaposlen v podjetju, ampak svoje delo opravlja samostojno. Pravna oblika oz. način na katerega deluje ni pomemben. Freelancer je lahko tudi nekdo z enoosebnim d.o.o. v končni fazi.
Prijava dohodkov, zasluženih preko freelance dela
102532 (1869) Invictus
Avtorska pogodba, naročnik iz tujine (ZDA)
123504 (3001) Invictus
Ce se odlocite postati freelancer
Oddelek: Izdelava spletišč
4917198 (11163) Isotropic
Fleksibilnejša oblika samozaposlitve (strani: 1 2 3 4 5 )
21554671 (49508) kkk7
Kdo lahko koristi avtorsko pogodbo?
258955 (7952) fosil
