[c#] LinkedList branje poljubnega elementa
KernelPanic ::
Spostovani!
V LinkedList imam 10 elementov in sedaj imam zelo butastvo vprasanje, kako dobim iz LinkedList-a, naprimer, 3ji ali 5i element?
Iskal sem po googlu, vendar nisem nicesar nasel, z navadnim List-om znam delati, v osnovi je to eno in isto, samo, da je LinkedList dvojno povezan (ima pointer na prejsnjega in naslednjega).
Lp,
M.
genesiss ::
Sprehodit se boš moral čez list. Ker je double-linked lahko malo optimiziraš in greš iskat s tiste strani, ki je bližja elementu (od zadaj ali od spredaj).
FrEaKmAn ::
LinkedList.ElementAt(3|5)? - http://msdn.microsoft.com/en-us/library...
KernelPanic ::
FrEaKmAn je izjavil:
To sem videl, vendar ko probam skompajlat sledeco kodo:
        public Advertisement currentAdvertisement
            get { return this.m_listAdvertisements.ElementAt(this.m_iCurrentIndex); }
, dobim napako:
Error	1	'System.Collections.Generic.LinkedList<FrontOffice.Elements.Advertisement>' does not contain a definition for 'ElementAt' and no extension method 'ElementAt' accepting a first argument of type 'System.Collections.Generic.LinkedList<FrontOffice.Elements.Advertisement>' could be found (are you missing a using directive or an assembly reference?)	D:\Projects\BarAdvetiser\FrontOffice\ViewModels\PresentationViewModel.cs	60	52	FrontOffice
FrEaKmAn ::
kako dobiš m_listAdvertisements in m_iCurrentIndex
KernelPanic ::
V istem classu (fajlu) je deklariran seznam:
        #region Input Advertisements
        private LinkedList<Advertisement> _listAdvertisements;
        internal LinkedList<Advertisement> m_listAdvertisements
            get { return _listAdvertisements; }
            private set { _listAdvertisements = value; }
        #endregion Input Advertisements
in tudi m_iCurrentIndex:
        #region Advertisement Index
        private long _iCurrentIndex = 0;
        public long m_iCurrentIndex
          get { return _iCurrentIndex; }
          private set
              if (this.m_iCurrentIndex != value)
                  this.m_iCurrentIndex = value;
                  OnPropertyChanged("CurrentSlide");
                  OnPropertyChanged("CurrentIndex");
        #endregion Advertisement Index
FrEaKmAn ::
ElementAt sprejema int in ne long?
moj primer deluje brez problema
LinkedList<String> LinkedList = new LinkedList<String>();
LinkedList.AddFirst("Ana");
LinkedList.AddFirst("Banana");
MessageBox.Show(LinkedList.ElementAt<String>(0));
KernelPanic ::
Sm spremenu long v int, isti drek, katere references pa imas v projektu?
FrEaKmAn ::
celotna koda
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
namespace TestsCSharp
    public partial class Form1 : Form
        public Form1()
            InitializeComponent();
        private void Form1_Load(object sender, EventArgs e)
            MessageBox.Show(LinkedList.ElementAt(0));
KernelPanic ::
Matr, zdej sm pa dodal tvoje using stavke, pa kr dela ... 8-O
FrEaKmAn ::
zanimivo :)
KernelPanic ::
u cem je fora, mogoce ves?
FrEaKmAn ::
lahko pastaš tvoje stare usinge?
KernelPanic ::
using System.Windows;
using System.Windows.Input;
using TestFull8229.Commands;
FrEaKmAn ::
manjka ti
samo če nisi nič brisal, bi ti moral to dodati avtomatsko. Občutek imam da je problem nekje drugje...
  • spremenil: FrEaKmAn ()
fiction ::
Fora je pomoje v tem, da ni bilo "using System.Linq". ElementAt() je namreč definirana kot extension metoda od IEnumerable(T), kar implementira tudi LinkedList(T)), ampak nahaja se pa "v System.Linq.Enumerable".
Je pa to O(n) metoda, ne tako kot index based dostop v List(T), ki je O(1).
FrEaKmAn ::
makes sense...
[C#] Razširitev Linked List-a
Oddelek: Programiranje
51428 (1094) Ciklamen
[c#] Sklad
92146 (2006) Spura
[c#] Ustvarjanje objekta v drugem razredu
82035 (1980) Cvenemir
c sharp LinkedList - Naloga
92579 (2530) Msatir
Povezani seznam
132599 (2196) pohano
