Interbase backdoor!
Interbase backdoor!
poweroff ::
Mene pa zanima kako funkcionira Borland Interbase database...
Nekje sem namrec prebral tole:
Versions of Interbase before 1994 didn't have any access-control
mechanisms. This was fixed in version 4.0 using a peculiar system. Since
they had a database, the engineers created a special database within
Interbase for account names and encrypted passwords. This solution had a
problem: in order to authenticate a user, the program had to access the
database, but before the program could access the database, it had to
authenticate a user.
No, potem so pa naredili tako, da je po defaultu uername "politically" in password "correct". Citat: "Anyone using
that username and password can access any Interbase database."
A mi lahko nekdo razlozi kaj vec o teh bazah?
Thomas ::
Po mojem skromnem mnenju, so baze podatkov zastarela zadeva. Vsaj te, ki so zdaj.
Jest bi rad bazo podatkov z naslednjimi lastnostmi:
Ena velika datoteka, v katero se zapisuje vse, kar pač pride v zapis. Data input stream se skoz beleži in zraven ura.
Stvar enega executabla pa je, da daje interpretacije na request in na set prefrences.
Poglavitno pa je, da executable stalno vrši data mining.
DB2, access, oracle ... so pa lepo za v prejšnje stoletje. :D
[Some1Else] ::
Poleg tega je interbase freeware...8-O, Borland ma pac prevec licenc in isce nacine da se jih znebi :), podobno ko c++compiler
Loki ::
Sam za internet so pa se zmerej nepogresljive, ane Thomas?
I left my wallet in El Segundo
[Some1Else] ::
8-) ]FlasH[ se strinja
Accsess tabele delajo full hitr na aspju, pa se zravn offica so:D.
Skripal (strani: 1 2 3 )
13142094 (27843) Pac-Man
PlayStation Network še vedno izključen, vložena tožba zoper Sony
Oddelek: Novice / Varnost
3011597 (9822) XsenO
Pomoč pri prevodu [Slo - Ang]
162043 (1712) ZdravkoČolič
php skripta za registracijo uporabnikov
Oddelek: Izdelava spletišč
162566 (2147) skorpio
Firebird 1.5
Oddelek: Novice / Brskalniki
83341 (3341) tiborrr
