Uredi po abecedi v OpenOffice Writerju
hmm23 ::
Je to sploh mogoče naresti? Nimam te tipke v orodni vrstici s F1 pa ne dobim nič uporabnega: tole:
Text fields are sorted alphabetically, numerical fields are sorted by number.
Sort Ascending
Data of the currently selected field are always sorted. A field is always selected as soon as you place the cursor in the field. To sort within tables, you can also click the corresponding column header.
To sort more than one data field, choose Data - Sort, then choose the Sort Criteria tab, where you can combine several sort criteria.
Hvala
Icematxyz ::
[Java] Podatkovni tip
Oddelek: Programiranje
235239 (4891) piki12
[Python] učenje
373032 (2329) Isotropic
Phenom II TWKR navit na 7 GHz
Oddelek: Novice / Procesorji
294596 (2855) squngy
Kater program je najboljsi za izdelavo spletisc?
Oddelek: Izdelava spletišč
101771 (1570) Ziga Dolhar
[Turbo Pascal] Pomoč...
131830 (1732) Grey
