CD problem v domeni
CD problem v domeni
Mercier ::
Kateri policy naj nastavim, da bo domain user lahko ripal ali pekel.
Poblem je z nero-om in dbpoweramp-om. S prvim se ne da zapeč, z drugim ne ripat glasbe CDja.
Server je w2k, mašine pa w2k in XP. Nikjer ne dela.
BTW, snemanje datotek na CD v XP pa dela. (ono v explorerju)
|GrEgOr| ::
mislim da so to problemi s samimi programi, kateri ne omogočajo dela z več uporabniki, oz. z njimi lahko delajo samo administratorji.
V nerotu nisem nikjer ugotovil, da bi lahko kje nastavil kateri useri ali skupine imajo pravice peči.
Mercier ::
Danes sem izvedel, da brezplačne podpore za w2k server ni. Sem htel tole microsofte vprašat...
Mercier ::
Takole so ahead-i opisali problem (ki je enostavno rešljiv z namestitvijo Nero BurnRights programčka):
Under Windows 2000 and Windows XP there must be a way to handle the security aspects of CD/DVD recording. CD/DVD pre-mastering software like Nero must be able to send SCSI/IDE commands to CD-ROM/DVD-ROM drives or CD/DVD recorders. However, from the operating system's point of view, being able to send SCSI/IDE commands to devices is a huge security problem, because software could use the SCSI/IDE commands to format the hard disk, read other user's data or create other severe problems. That is why Microsoft decided to allow low level driver access only for programs running with administrator rights.
Now, let's assume the situation of a Windows 2000 or Windows XP PC in a network environment and with many different users. Security considerations make it absolutely impossible to grant administrator rights to all users. So firstly, there must be a way to allow CD/DVD recording for non-administrators and being able to decide which users may record CD's/DVD's and which users may not.
The way to solve this situation is to install Nero BurnRights. After Nero BurnRights has been installed, the system administrator can assign a specific group the rights to record CD's/DVD's on the system. If an administrator wants to allow or disallow CD/DVD recording rights for certain users, it is enough to make the user a member of this group or to remove the user from the group. If everybody should have the right to record CD's/DVD's, the recording rights can be assigned to everybody.
win srv 2003 - file sharing
Oddelek: Operacijski sistemi
192580 (1745) Eureka
Zaščita DVD diska
Oddelek: Programska oprema
312799 (2209) bosmla
Kako varen je Microsoftov požarni zid? (strani: 1 2 )
Oddelek: Novice / Varnost
537272 (7272) gumby
Nero-Burning Rom in Win2000?
131506 (1294) Lime
Nero + teacW516EB
91281 (1194) PupaSuchen
