Forum » Znanost in tehnologija » Vsi Kepplerjevi planeti
gzibret ::
Sonce z Zemljo in Jupitrom je prikazana na desni strani, po prvi vrstici. Hi-res dobite tukaj:
klik
Komentarji? A res obstaja tako majhna verjetnost, da imamo samo eno Zemeljo?
Vse je za neki dobr!
- zavarovalo slike: gzibret ()
The findings increase the number of planet candidates identified by Kepler to-date to 1,235. Of these, 68 are approximately Earth-size; 288 are super-Earth-size; 662 are Neptune-size; 165 are the size of Jupiter and 19 are larger than Jupiter. Of the 54 new planet candidates found in the habitable zone, five are near Earth-sized.
Če misliš na podobno orbito in velikost, potem jih zna biti tudi kak milijonček, in to samo v naši galaksiji. Če pa ciljaš še na podobno atmosfero, potem pa lahko rečeš samo eno stvar - Your guess is as good as anyone`s.
- spremenil: DarwiN ()
| » | Kepler najdu planet podoben zemlji! (strani: 1 2 3 4 )Oddelek: Znanost in tehnologija | 39450 (3573) | BigWhale |
| » | Jupiter AscendingOddelek: Sedem umetnosti | 4485 (3306) | Netrunner |
| » | 22% soncu podobnih zvezd gosti Zemlji podobne planeteOddelek: Znanost in tehnologija | 2873 (1889) | jest10 |
| » | Apokalipsa: April 2014 - Marec 2015Oddelek: Loža | 8352 (6797) | Janac |
| » | Earth almost put on impact alert (strani: 1 2 )Oddelek: Znanost in tehnologija | 9775 (8156) | keber |
