Forum » Omrežja in internet » [P2P]eMule , eDonkey, Overnet, DC++ & co.
e-marko ::
Sem imel razčiščeno dokler nisi napisal prejšnjega odgovora...
Saj če je torej imel P|P| odprta tista dva porta, zakaj bi torej moral odpirati vseh 2000, da bi bolje delalo??? To je tisto kar me moti. Tega ne razumem.
...somebody, somewhere...
PrimozR ::
Ej ne vem. K sm predpisana porta odpru, je bil vsxak, ampk res vsak server nedosegljiv. Zdej mi leti čez 30 kilo skos. Prej skor nikol ni. 2 dni nazaj je šlo čez 50 kilo. To je moj osebn rekord.
e-marko ::
Odvisno kaj dol vlečeš... Pa koliko stvari naenkrat.
Če meni dl z manj kot 30 kilo sem že nejevoljen.
Mi pa sedaj nekaj serje z Kad network. Sicer sem povezan, ampak mi piše tam pri statusu Firewalled.
dela ::
Mislim da eMule za dobro delovanje potrebuje odprtih več kot tista 2 porta... naj me kdo popravi če se motim. Kopirano iz eMule help:
1) Local Port: 4662
Remote Port: any
Protocol: TCP
Direction: incoming
Purpose: Client Port / Connections from other clients, Client to Client Source Exchange
Note: You can change this port in Preferences -> Connection -> Client Port
This port has to be forwarded in a router. Changing this port in Preferences you must also change the forwarding in the router
2) Local Port: any
Remote Port: 4662
Protocol: TCP
Direction: outgoing
Purpose: Client Port / Connections to other clients, Client to Client Source Exchange
Note: 4662 is the default port, but other clients may have different settings. Change the remote port to any when configuring a firewall
3) Local Port: 4672
Remote Port: any
Protocol: UDP
Direction: incoming
Purpose: Clients source asking / extended eMule protocol, Queue Rating, File Reask Ping
Note: This port has to be forwarded in a router. Changing this port in Preferences you must also change the forwarding in the router.
If you are not able to forward this port check the disable box in Preferences -> Connection -> UDP Port
4) Local Port: any
Remote Port: 4672
Protocol: UDP
Direction: outgoing
Note: 4672 is the default port, but other clients may have different settings. Change the remote port to any when configuring a firewall
5) Local Port: any
Remote Port: 4661
Protocol: TCP
Direction: outgoing
Purpose: Connection to server
Note: 4661 is the default port of a server. Many server use different ports. Configuring a firewall the remote port again changes to any.
6) Local Port: any
Remote Port: 4665
Protocol: UDP
Direction: outgoing
Purpose: Source asking on servers
Note: Servers using the default port 4661 TCP (see #5) automatically set their port for source asking to 4665 UDP. If a server uses a different port in #5 the corresponding UDP port is set to [Connection Port + 4]. For firewalls the remote port here is any.
7) Local Port: 4711
Remote Port: any
Protocol: TCP
Direction: incoming
Purpose: Webserver
Note: This is the default port for the web interface. When using a router this port has to be forwarded or no connection to the webserver will be possible.
ostalih 1995 mislim da ni potrebno met odprtih.
1) Local Port: 4662
Remote Port: any
Protocol: TCP
Direction: incoming
2) Local Port: any
Remote Port: 4662
Protocol: TCP
Direction: outgoing
3) Local Port: 4672
Remote Port: any
Protocol: UDP
Direction: incoming
4) Local Port: any
Remote Port: 4672
Protocol: UDP
Direction: outgoing
5) Local Port: any
Remote Port: 4661
Protocol: TCP
Direction: outgoing
6) Local Port: any
Remote Port: 4665
Protocol: UDP
Direction: outgoing
7) Local Port: 4711
Remote Port: any
Protocol: TCP
Direction: incoming
Purpose: Webserver
- spremenil: dela ()
2nemesis ::
FaLcOn3y3:
1) Moraš imeti forwardiran port 4662 na mašino na kateri teče emule.
2) Kernel sam izbere port na tvoji mašini, NAT od routerja avtomatsko forwardira povezavo na internet.
3)Podobno kot pod 1).
4)Podobno kot pod 2).
5) Samo za tiste, ki poganjajo Edonkey server. Emule se pa poveže nanj tako kot piše pod 2).
6) Samo za tiste, ki poganjajo Edonkey server. Emule se pa poveže nanj tako kot piše pod 2).
7) Lahko forwardiraš port, če hočeš dostopati do web vmesnika preko interneta.
Za normalno delovanje Emule rabiš imeti odprta/forwardirana samo dva porta (en tcp in en UDP), lahko pa dodatno še en tcp port za web vmesnik.
Za poganjanje Edonkey serverja (Efarm) pa rabiš odpreti druga dva porta pod 5) in 6). Priporočjivo za tistega, ki hočeš postaviti aka Razorback server.
ross|e20 ::
lep pozdrav
ko se konektam na emule preko routerja mi napiše naslednje:
7.2.2005 12:41:33: WARNING Razorback 2 (195.245.244.243:4661) - You have a lowid. Please review your network config and/or your settings.
kk se znebim tega?
hvala
kk se znebim tega?
hvala
Prenosik Acer Aspire 5101: AMD Turion 64 Mobile
Technology (2.0GH), 15,4' TFT LCD, ATI Radeon
Xpress 1100, 60GB HDD, 1GB DDR2 ram, DVD pekač,...
Paramedic ::
kk se znebim tega?Tako kot ostalih 5000 ljudi, ki so to že vprašali v tej temi...pa ti je ni treba cele prebrati. Če pa nočeš brati te strani, pa uporabi Emule pomoč v programu.
End transmission.
ross|e20 ::
ok... sem odprla porte pa ne vem ka še vse, sam jst mam še vedn lowid!
ross|e20 ::
v windovsih sem izklučla firewall, v routerju tut, v antivirusnem programu tudi in ni nič bolš. a obstaja še kk firewall?
Matej_K ::
Sm downloadu to najnovejšo emule 0.45a in mi več ne dela,tko kt prej, dam TEST PORTS in mi jav napako...
TCP:4662
UDP:4672
TCP test failed! UDP test will not be performed.
Nimam nbenih routerjev,pr prejšni verziji mi je delal vse kulll...
WINDOWS firewall ugasnn!!
Kaj je problem??
TCP:4662
UDP:4672
Kaj je problem??
- spremenil: Matej_K ()
legy ::
men tut jebe ta nova mula 0.45a ne dela tako kot 0.44d vse gre bol pocas dol
Zakaj?
Zakaj?
Predstavljajte si omrezje v katerwm bi lahko poganjali World v New Yorku, svoje dokumente pa shranili na strezniku v Los Angelesu.....tudi to bo 1x mogoce.
povoj ::
lep pozdrav. men je pa nekej časa e-mule kr dober delov, e zdej pa ne več.dl enih75 stvari ke majo pop 300sourcou, vleče mi pa 30kb.včasih je pa 80-100.recimo ke se konektam, grem lahk na razorback pa visok ID pa vse v redu, čez kšen dan al pa še prej, pa dl pade, pa probam še enkrat na razorbacka it mi pa napiše da port 4662 ni dostopn.tko mi zmeri nardi?
je kej narobe ker sm spremenu da mam limiti sourcov 700??je to dober al ne?
se mi splača novo verzijo začet uporabljat al je ta še neki časa čist dobra?
hvala pa lep dan
hvala pa lep dan
Mene zanima nekaj glede compajlanja modov za emule.
Sedaj imam sivko mod.
Morph mod ima funkcijo, da ti prikaže državo iz katere je uporabnik, glede na IP. To funkcijo bi rad namestil v sivko. A je to sploh mogoče? A kdo sploh compajla izvorno kodo mule tule? Bi bil zelo vesel kakega linka v angleščini, ker nemških forumov o muli je polno, pa jih bolj malo zastopim.
CaqKa ::
ker sem se na betanews naročil na nekatere sveže downloade vam tukaj podajam link do nove mule:
http://fileforum.betanews.com/detail/eM...
bigbug ::
Imam isti problem kot Matej_K in legy,porti so odprti mula ima pa vedno lowID.Nalozil sem preko nove staro verzijo ampak je isto(prej je delalo vse ok) kaksna resitev???
BlackHole ::
Pomoč rabim!!
Tisti Microsoftov Antispyware program mi je po pomoti zbrisal (quarantine, unqurantine ni pomagal) celo Emule mapo z vsemi part datotekami. In to ob ponovnem zagonu, ko sem zagnal Emulo, mi je seveda javilo "no part files found". Nato sem z enim recovery programčkom dobil celo to mapo nazaj, vendar zdaj ko Emulo poženem, mi teh prejšnjih datotek, ki so bile v download listi, ne naloži. Kaj moram storit, da dobim to listo nazaj. Datoteke se nahajajo v isti mapi kot prej, tako da mi ni jasno zakaj jih ne najde.
LP Marko
- spremenil: BlackHole ()
BlackHole ::
Pozabte, problem rešen. Očitno mi je spremenilo mapo za temp datoteke na default, ko sem zagnal po restartu.
LP Marko
promocija ::
No fantje, a ste zaspali?
Tut kaz imam podobno težave kot Matej K in ostali, pa se ne bi branil če bi kdo uspel ugotovit, zakaj tak počas dol vleče? Kolk vam vleče dol? Men na ADSLu komi 3, 4kb/s ?!
Aja, pa zakaj mi pri datoteki ko jo vlečem dol, piše 5 minut waiting in nič ne dela?
Ajd mejte se!
Ajd mejte se!
ni podpisa
- spremenil: promocija ()
Miran2005 ::
hmm ... imel sem vse naštete težave (loW ID, zavračanje Razorbacka, hitrosti podobne 0,...) ... forwardiral (linija prek routerja) ... nastavljal virtual server ... izklapljal firewall... odpiral več portov.... VSE ZASTONJ!
Nato sem nekje na teh straneh prebral debato o grozilnem pismu ki ga je nekdo dobil (če se ne motim od UNIVERSALA ali PARAMOUNTA) glede nalaganja filmov iz mreže. Pismo je bilo posredovano prek ISPja in se je seveda nanašalo na mulo. Nekdo se je prav lepo potrudil in opisal sistem tega početja, meni pa se je začelo dozdevati, da bi si ISP morda rad prihranil kakšne težave, in morda malce pomaga pri .....
Da se razumemo - to je čista špekulacija, blef ali karkoli že ampak odkar sem odprl dva porta v območju nad 30000 več ni težav (oz. hitrosti so
Še malo pa F1...
BaRtMaN ::
To ni nič novega - ISPji večinoma blokirajo provzete porte, zato jih je pametno spremeniti na nekaj povsem naključnega, kar seveda naredi tako omejevanje prometa (skoraj) nemogoče.
Poldy ::
Hm, čudno, odprl sm privzete porte na routeriju in vsi testi povejo da sta porta odprta. Tudi ko se povežem mi piše high id. Upload imam pač toliko na kolikor ga omejim, download pa 0, največ 8kb. Pa imam recimo 480 sourcev, pa nič...
V kakšnih mejah pa lahko nastavim porta tcp in udp?
Aja, pa kaj je to proxy?
mojedekle ::
uporabljam emule
in nikakor ne morem prit na server, hocem pa it na rasorbacka ki je baje najboljsi
pa mi napise sledeče :
Povezan z: rasorback (195.245.244.243:4661), pošiljam željo za vstop
21.2.2005 18:23:45: Opozorilo rasorback (195.245.244.243:4661) - You have a lowid. Please review your network config and/or your settings.
21.2.2005 18:23:45: rasorback (195.245.244.243:4661) je poln.
da ki je LOW id?
in polno!!
tako že 3 dni
je to možno, kako nja popravim??????????
da ki je LOW id?
in polno!!
tako že 3 dni
koša moša?
mojedekle ::
ok isklopu sem firewall in zdej se lahko povežem, samo kaj zdej moram imeti nonstop izklopljen firewall, s tem raskiram varnost!
al lahko pol vklopim al kak?
al se da da je firewall izklopljen samo za emule?
koša moša?
PrimozR ::
odpret moš mu7line porte na Firewallu (4662 ča 4672, en je UDP, en pa TCP, poglej v muli). Če je pa Razorback polhn, ti pa noben ne more pomagat, bo treba na drug server. Sicer sm se jest zjutri komot povezu.
mojedekle ::
ja saj pravim, da se zdej lahko tudi jaz povežem, ampak samo če imam cel firewall isklopljen !
kar se pa portou tiče imam tako naštimano kot praviš,
zanima me samo kako lahko naštimam da se lahko povežem tudi z firewallom vklopljenim-varnost je pomenbna ne!
koša moša?
mojedekle ::
ok , samo imam kerio firewall!
pa res ne vem kje se naštima ta porte-sem šol že vse skozi, pa ne vem :(
ve kdo?
ve kdo?
koša moša?
CaqKa ::
ponavadi gugl
kolkor se pa spomnim se na kerio štela exe fajle in ne portov.. oziroma porte lahko tudi.
croco ::
Jaz imam pa eno drugo težavo. Imam doma 2 računalnika povezana preko mreže. Na prvemu laufa WIndows 2003 ki je kao server na drugem pa windows xp. Tu imam mulo in mi lufa na lowid in
IP:Port: Unknown.
Na obeh kompih sm sklopu firewalle (čeprav ta ne mojem mi ni delal nikoli težav). Ko nardim test portov mi tudi naredi error. Nato sem dal mulo gor na server in dela vse lepo in prav, torej je težava nekje v prenosu preko mreže. A bi mi kdo znal povedat kako naj odprem te porte al karkoli je treba naredit?
IP:Port: Unknown.
Bakunin ::
>kaj bi pa sploh pomenlo low id?
"lowid" v emule je podoben "pasive mode" v DC++.
Za oba to pomeni da vsa iskanja/komunikacijo/ipd. delas preko emule streznika oz. dc huba in ga s tem dodatno obremenjujes.
"high id" oz. "active mode" pa pomeni, da iskanja/ipd. delas SAM, ker imas odprte "porte" in lahko poteka komunikacija sveta s teboj "direktno".
Tako kot emule tudi DC++ potrebuje odprtih DVOJE vrat - eno s TCP ter eno s UDP protokolom.
> in kaj da popravim v nastavitvah?
recimo da si izberemo vrata emule_tcp_udp ter dc_tcp_udp (to je lahko cifra karkoli med 1024 ter 65535).
V pozarnem zidu odpres tcp IN udp vrata emule_tcp_udp ter dc_tcp_udp.
Ce imas "router" potem preusmeri (port forward) vrata emule_tcp_udp ter dc_tcp_udp na IP racunalnika na LANu, kjer imas DC++/emule.
V DC++ moras storiti se eno stvar - v nastavitve za IP naslov moras vpisati INTERNET IP naslov in ne tistega iz omrezja (192.168.*.*, 10.*.*.*).
To je naceloma to.
Vec informacija najdete na http://www.dslreports.com/faq/6517
DC++ slikanica
PS: LDCPP odjemalec za DC++
To je naceloma to.
DC++ slikanica
- spremenil: Bakunin ()
Bakunin ::
Pri emule je naceloma vseeno na kmateri streznik se povezes. Ognite se streznikov s starimi verzijami emule streznika.
roli ::
Zdaj imam pa dovolj.
Ta prekleti lowID.
V winsih mam porte odprte sam to mi ni nikdar delalo težav.
V bitdefenderju imam dovoljeno vse od mule.
Vendar če dam test ports mi javi error.
Kaj naj storim?
Mam pa mulo v 44.b unicode.
LP!
Ta prekleti lowID.
Kaj naj storim?
LP!
http://www.r00li.com
romancretnik ::
LP!
Mam problem. Kabelski internet, router Planet (sej vem, ne me kritizirat, smo pac studenti brez dnarja) in 2 PCja. En je nov, z XPji in oh in sploh, drugi je pa stara kista z win98. Do nedavnega nismo imeli problemov, zdej se pa dogaja tole: na novem PCju DLamo z emule, ki so omejene na polovico sirine (imamo 768/128, omejeno na 384/64), na drugem PCju pa vseeno fuul slaba povezava (okol 33 kb/s). Z drugimi besedami: ko na novem PCju mule vlecejo s hitrostjo okrog 50k, js na drugem PCju umiram od dolgcasa, ce rabim net. Sm testiral z Cnet conection speed in 33kbps.
Ce mule zaprem, imam povezavo (po Cnet meritvah) okol 400 kbps.
Kako naj posteno razdelim linijo med 2 PCja?
Ali lahko to naredim na routerju?
l.r.
BlackHole ::
In kateri strežniki so to?
LP Marko
Bakunin ::
V listi streznikov imas kolono, kjer so navadene verzije ( npr. 17.*). Izberes tistega, ki ni "predpotopen".
BlackHole ::
Aha, nisem še opazil tega. Kaj pa milijon tistih, ki verzije sploh nimajo navedene? In katera verzija so novi strežniki?
LP Marko
wolftrix ::
Prekopirano na zeljo moderatorja OmegaBlue sem.
Veliko je že bilo govorjenja o temu. Toda vsak trdi po svoje, kaj je dobro in kaj ne. Pri meni je preteklo kar nekaj časa, da sem izvedel optimalne nastavitve za normalno delovanje. Od odpiranja portov, požarnega zida, do nastavitev v Emul.
Začetek
Nastavitve požarnega zida in odpiranje portov:
Požarni zid.
Seveda je požarni zid (Firewall) zelo pomemben del programske opreme, brez katerega si žal dan danes ne moremo zagotoviti varnosti na internetu. Najboljša rešitev je seveda namestitev internet vmesnika ROUTER, kjer je že vgrajen požarni zid. Z ustrezno zaščito dobimo tovrstni vmesnik že za približno 8.000 sit. Zame osebno najboljša rešitev in edina zanesljiva. Seveda pa si vi lahko naložite na svoj PC tudi software firewall zaščito (programski požarni zid). V večini, je le ta že v Windows XP sp1 in sp2, toda jaz osebno ne podpiram tovrstnega požarnega zida. Zato le tega izklopite:
- pri sp1: odprete NETWORK CONNECTION --> kliknete na LOCAL AREA CONNECTION --> PROPERTIES --> zavihek ADVANCED in odkljukate INTERNET CONNECTON FIREWALL
- pri sp2: dodatno: SECURITY CENTER --> odkljukate FIREWALL
Aktiviranje požarnega zida in odpiranje portov (vrat) v Routerju.
Ker je na tržišču že toliko ponudnikov Routerjev, se bom tu omejil le na nekatere. Prednost ima router Planet.
Povežemo se z Routerjem preko internet brskalnika. V večini je to http://192.168.0.1, drugače pa imate IP Routerja priložen, ko kupite le tega. Če vam IP ne prime, resetirajte Router. Če to še vedno ne zaleže, odnesite Router nazaj v trgovino in ga zamenjajte za novega.
Ko se končno povežemo z Routerjem gremo v meni FIREWALL. Tu damo kljukico na ENABLE (uporabi). In potrdimo z APPLY . Tako smo izvedli operacijo požarnega zida in sedaj smo zaščiteni.
Odpiranje portov, se nekaterim zdi zelo zahtevna stvar, toda ni. To storimo tako da se ponovno povežemo z Routerjem in odpremo mapo NAT ? Port Forwarding (odpiranje portov). Nekateri trdijo, da uporabimo za odpiranje portov Virtual Server, toda največkrat temu ni tako. Se pravi v mapi Port Forwarding naletimo na prazna okenca za vpisovanje podatkov. Tu moramo vpisati: Private IP (Ta IP dobimo v COMAND PORT programu tako da vpišemo: ipconfig. Ko se nam izpišejo IPji, je tisti ki ga iščemo za odpiranje portov IP Address). V večini je to 192.168.0.100. Obvezno pa morajo biti 2 nuli na koncu. Potem je pomembna stvar tu okence TYPE, kjer izbiramo med TCP in UDP protokoli. O razlikah ne mislim govorit, toda glavna razlika pa je le v tem da je TCP protokol bolj zanesljiv, saj pošilja manjše kose podatkov, medtem ko UDP pa je ustvarjen za prenašanje večjih kosov podatkov in je bolj dovzeten za napake. Se pravi tu lahko izbiramo med TCP, UDP ali obema hkrati. Naslednje okence je PORT RANGE. Tu določimo numerične vrednosti. Najboljše nastavitve za Emule so: TCP: 4661,4662, 4711; UDP: 4671, 4672, 4665. To velja za večino primerov in so že samodejno nastavljene v Emule. Če pa boste imeli še vedno LOW ID v Emuli, obstaja možnost, ki jo bom omenil podrobneje malo kasneje. Samo za utrinek: ena od lažjih možnosti je, da porte spremenimo tako da dodamo pred številko še 1 (npr.: namesto TCP 4661 odpremo port 14661). Tako smo odprli potrebne porte za normalno delovanje Emule. Odpremo pa lahko tudi porte (vrata) za ostale programe kot so MSN Messenger za normalno delovanje, a o numeričnih vrednostih teh portov (vrat) si preberite na internetu.
Inštalacija Emule in nastavitve le te
Poberite zadnjo inštalacijsko različico Emule Installer v0.45b na tem naslovu:
http://prdownloads.sourceforge.net/emul...
Ko jo inšalirate poberite še predelano upgrate različico (saj meni najljubšo) MorphXT v6.1:
in vse file prekopirajte (v večini povozite stare) v mapo kjer ste inštalirali predhodni Emule.
Po opravljeni inštalaciji Emule le tega odpremo. Če se nam niso naložili stežniki le te naložimo iz te strani:
http://ed2k.2x4u.de/index.html
Ko se nam prikaže strežniška lista, se poskušajmo povezati na enega od njih. Če se nam pokaže HIGH ID je stvar uspela. HIGH ID pomeni, da so odprta vsa potrebna vrata za normalno delovanje. Če se nam kljub omenjenim odrtim portom pokaže LOW ID, spremenimo porte na omenjene vrednosti. Lahko pa tudi na poljubne. Presegajo pa naj število 10000. Ko odpremo poljubna porta TCP in UDP le ta vpišemo v Emule nastavitvah in sicer v zavihku OPTIONS --> CONNECTIONS in tu kjer imamo napisan TCP in UDP vpišemo poljubno porta, ki smo jih odprli na Routerju. Tu je navedena tudi možnost TEST PORTS, toda večkrat se izkaže za neuspešen test. Ko smo nastavili porte je pametno tu nastaviti še to, da v isti mapi OPTIONS kliknemo še na SERVER. Tu izbrišemo kljukico na USE SMART LOW ID. Tako obstaja večja verjetnost da bomo imeli HIGH ID, saj je večina strežnikov podprta le v tem načinu. Ko smo porte le uspešno nastavili (tu ni več dileme), preverimo še hitrost UPLOAD in DOWNLOAD. Za povezavo 1Mbit, nastavimo download na 1000Kb/s (pa če prav nimamo take hitrosti) in upload v območju od 10-12Kb/s (ponavadi na polovico celotnega). Tako bomo imeli najboljši izkoristek. Priporočljivo je tudi to, da se povežemo na KAD (že od znanih odjemalcev). To storimo tako da poberemo še dodatek MOD:
http://www.emule-web.de/board/files/mod...
in ga prekopiramo v Emule inštalacijsko mapo CONFIG.
To bi bilo glede nastavitev Emule trenutno vse. Vedeti pa je potrebo še nekaj: za hitrejši prenos se povežemo na hitrejše strežnike kot je DonkeyServer No.x. Razorback 2 je teoretično najboljši, a je včasih preobremenjen in ima slabši PING. Zato se povezujmo na hitre strežnike z boljšim PINGom, saj bomo le tako povečali hitrost prenosa. Ker smo povezani v Kad odjemamo podatke tudi od tistih ki so na ostalih servejih. Zato vas naj število oseb na serverjih ne zmoti pretirano. Gledati je treba predvsem na boljši PING.
Dodatna zaščita pred lovci na ilegalno
V zadnjem času se veliko govori o tem, da se je začelo nadzirati ed2k in da če pobiraš ilegalne stvari na Emule te zlahka izsledijo. Stvari so res da pripeljale do te mere, da je to res. Tudi sam sem dobil elektronsko sporočilo, da naj nemudoma neham z pobiranjem ilegalnih filmov in le te nemudoma zbrišem. Toda v Sloveniji velja le ta zakon: stvar ni prepovedana, če jo imamo za lastno uporabo. Ko jo enkrat začnemo prodajati (Piratstvo) lahko že govorimo o zlorabi. Toda zakon se bo kmalu spremenil in bo kmalu veljalo ilegalno tudi pobiranje filmov preko ed2k. Zato se je že zdaj potrebno zaščititi pred tovrstnim nadzorom.
Načinov je kar nekaj, toda najbolj priljubljena in uporabna, ter zanesljiva je uporaba programa PeerGuardian 2.0. Ta programček blokira IP naslove vohljačev, ki sicer lahko vidijo imena datotek, ki se pretakajo, ne morejo pa jih pretočiti v svoj računalnik in tako ugotoviti ali gre za vsebino, ki je zaščitena z avtorskimi pravicami ali ne.
Program snamete tu:
http://prdownloads.sourceforge.net/peer...
Lahko pa to isto funkcijo nastavimo že v samem Emule. To storimo tako, da v zavihku OPTIONS --> SECURITY, damo kljukico na FILTER SERVERS in v spodnji kvadratek za URL vpišemo ta naslov:
http://www.morph-mod.de/morph/ipfilter/...
in pritisnemo LOAD. To počnemo vsak dan ali vsak 2 dan, da na novo osvežimo IPje.
To bi bili teoretično vsi osnovni napotki za normalno in varno uporabo Emule. Seveda obstaja verjetnost da se kdo z mano ne bo strinjal. Toda jaz vam podajam moje izkušnje in trenutno nastavitve z katerimi sem zelo zadovoljen, saj poberem želen film tik tak čez noč in ga drug dan že lepo gledam. Tko da odločitev je vaša, za posledice ne odgovarjam. ;-)
LP in veselo Emuliranje še naprej
Začetek
Požarni zid.
Program snamete tu:
pro549 ::
imam mldonkey-ja inštaliranega na serverju in preko sancho GUI-ja dostopam prek mojga PC-a gor. Vse lepo in prav, samo ena stvar me moti in to je da ne podpira Direc Connect protokola. Ali je kakšen tak program, ki laufa na linuxu in preko kakšnega GUI vmesnika dostopaš na daljavo gor, kakor je pri navezi mldonkey-sancho GUI?
johnny90 ::
Imam zelo velik problem. Emule ima low-id. Vem da je bilo o tem napisanih že ogromno postov, ampak vseeno:
Pred kratkim so doma vzpostavili mrežo (ruter: planet) in problemi so tu. Mula ima low-id!! Odprl sem potrebne porte (tudi nad 10000) na ruterju, izklopil firewalle... ampak še vedno low-id. Nekajkrat mi je celo napisalo da nima dostopa do tcp porta!? ampak ta problem sem rešil... zanima me zakaj potem low-id? ali ima s tem kaj veze PeerGuardin2 in antivirusni program (NOD32, avast!)? Pozabil sem omeniti da prej ko ni bilo ruterja in je bil računalnik direktno povezan, ni bilo teh težav. Mula je imela hi-id. Prosim za kak nasvet
wolftrix ::
Cau če imaš PeerGuardin2 se prepričaj, da nimaš morda na Block listi IPjev tudi IPje srežnikov od Emule. Tiste antivirusne programe k pa maš pa nimajo veze z Emule. Probi izlopt PeerGuardin2 in nanovo zažent Mulo. Pojdi tudi v Emule direktori in iz mape Config izbriši IPfilters file. Če se ti bo normalno povezu pol je problem v tem. Če pa boš mel še zmerom problem povej, ker pol boš mogu še mal Router nastavt. LP ;-)
| » | eMule FAQOddelek: Omrežja in internet | 7697 (6123) | Spc |
| » | težave z mulo in routerjemOddelek: Omrežja in internet | 2544 (2326) | Goldee |
| » | eDonkey kralj P2P omrežij (strani: 1 2 )Oddelek: Novice / Avtorsko pravo | 11639 (10109) | Eru |
| » | ADSL visoka hitrost??Oddelek: Omrežja in internet | 2239 (1605) | BaRtMaN |
| » | Kateri je poleg Kazaa 2.0 najboljsi?Oddelek: Programska oprema | 3084 (2358) | cybermedo |
