Katero grafično kartico kupiti 6870 ali 6950?
2 3 4
Cicek1 ::
Sem u dvomih glede teh dveh kartic ki sta naveden zgoraj! kaj mislte katero bi se bolj splačal kupit! Kot smo vidl se da 6950 celo odklent... Cena je približno ista zato me zanima (40 evrov je razlike)! Pomagite prosim...
69charger ::
6950 ker je razlika med tem dvema karticama premajhna za 40EUR.
in ker se HD 6950 odklene v HD 6970:D
69charger ::
In imaš v bistvu isto grafično z minimalnimi razlikami,Radeon bljah(vsaj zame).
jazbec ::
poglej še gtx470
če jo naviješ se pripliža hd6950 in jo celo prehiti v nekaterih igrah
pa še physx in cudo dobiš zraven
Tako je, physx in čudo, da ti ne bo treba it na sekret nepripravljen.
IvoJan ::
Kaj vsi bluzite s tem odklepom? Parim ljudem je ratal zdej pa mislite da se lahko vse odklene? Dej bodite realni.
5er--> ::
Še nobenemu ni ne-ratalo.
49106 ::
In zaradi tega gre garancija :D Taka stvar ni vredna 100eu več, temveč 150 eu manj.
IvoJan ::
5er--> je izjavil:
Dej ne govori neumnosti.
jazbec ::
D3m je izjavil:
če pa ti nisi amd fan nevem kdo je
poglej metro2033 in pa bbc2 z physx pa potem govori
IvoJan ::
Pa poglej se just cause 2,nfs shift. Na 5870 mi je shift laufal na 50 fpsjih, na gtx460 pa na 120 fpsjih.
Machiavelli ::
5er--> je izjavil:
Hate to burst the bubble here guys....
Got 2 Sapphire 6950's and i flashed one of them only.
When i set the flashed 6970 to 6950 speeds, i see no difference in performance whatsoever... infact, there is a slight decrease compared to the untouched 6950... with the unlocked SP's, there should still be an increase over the untouched card.
The BIOS flashing most definitely worked as the stock speeds have increased.
Also, i have noticed that the flashed card is a lot hotter to the touch then the stock (untouched ) 6950.
Make what you will of this, but i for one see no advantage or improvement in doing this.
I am somewhat skeptical that AMD would allow this to happen... and if they did, i am certain they will put a stop to this in future cards...
do some stress test, like furmark or smth for 30 min
First bad 6950 reported over at XS
still cant run anything since the 3D artifacts a lot.
Well it seems not every card out there is able to unlock correctly. Same as with CPUs. This was to be expected, too...:)
couldnt make winflash to work in windows for some reason.
flashed and tested, with atiflash one card unlocks good, the other one artifacts in windows.
Just the luck of the draw, no biggie.
HAWX 2 totally maxxed with tesselation ON, stock 890/1375 running on specs in my sig. my 6950 got 75 avg 133 max oc'd to 880/1375 as seen here. 79 avg and 142 max is a real proper difference, best comparison Ive got and it shows that these shaders are truly unlocked
Nigaaazz
5er--> ::
IvoJan je izjavil:
5er--> je izjavil:
Tukaj imaš seznam (proti dnu strani - test results). Zaenkrat še ni nedelujoče, če pa veš za koga, ki mu ne dela, naj sporoči, da bodo posodobili statistiko.
@Messiah: Imaš 2 biosa na razpolago, tako da ne bi smel biti problem stvar vrniti na tovarniško stanje. ;)
Edit: vidim, da je prva nedelujoča prijavljena. Se zgodi. ;)
  • spremenilo: 5er--> ()
Machiavelli ::
pa tud če jo flešneš je to prdec v morje obe kartici nista vredni več kot 260eur pa si govorte kar čte,navita 470 pa ju poje za malico ;)
Nigaaazz
IvoJan ::
Tisti odklenjeni shaderji pomagajo en ku***. Razlika je samo zaradi visjih clockov.
jazbec ::
da ne govorimo o gtx570
povozi obe za malco
tle maste test-http://www.hardwareheaven.com/reviews/1...
Machiavelli ::
Poleg tega če stabilno odkleneš 6950 boš imeu dejansko manjši OC potencial kot 6970 zaradi pomanjkanja 2h pinov...
Jazbec ti si končno negdo ki se strinja z menoj....
Moje mnenje 5870,6870/50 niso vredne več kot 250-270eur.
Poleg tega tessalacijski faktor na 6970/50 je "2x moč 5870" ampak še vedno več kot pou manj v primerjavi z gtx 400/500 ;)
pomnite da navita 470 (200-240eur)pride oz. prehiti stock gtx570.
Tak da je 6000 serija nateg.
Link :
Pozorno primerjajte 5870 z "Novo" 6970/50 ;)
kartice so clockane .
hawx ima dost tessalacije nova serija nobenega napredka,
Skrekani nvidia demoti alien triangeli pa mesto se na 6970 porazno odnese in sicer z polovičnimi frejmi.prav tako v tessmarku je enaka z staro serijo lol.zato ma amd neke boge Mecha dx9/10 demote ker njihov hardware ni tako močen..
Kar se pa fizik tiče da AMD ima neke sorte fiziko bullet preko directcomputa in sicer jo izkorišča 3dmark11,je pa to odprti jezik.
navijanje 6970 in 6950 pa res ni nekega benefita,poleg tega v vseh testih moraš amdju odbiti 2-7fpsa ker so defult nastavitve slabše in tu pridobi malo boosta..
če bi moru izbrati 6970/50 vs 470/570 470/570 bi bil odgovor.
Nigaaazz
jazbec ::
sm kupu gtx570 za 350 evrov
to leti tko, da se niti opisat ne da
navil sm jo z stock hladilnikom kaj bi blo da bi mel vodno
druge komponente so i7-930 navit na 4ghz za optimalno delovanje,asus sabertooth in corsair vengeance lc8 1600mhz
ne obžalujem, da sm jo kupu
Machiavelli ::
570 je zlat nakup tiha močna in ima kar dosti oc potenciala z opazno razliko.
tisto z odklepanjem šejderou je zavajanje ljudi,ker vsi vemo kak loterija je to...
Nigaaazz
jazbec ::
točno tako
cena je tam tam če gledamo gtx570 in hd6870
gtx570-->http://www.dinokomp.si/product_info.php...
hd6970-->http://www.dinokomp.si/product_info.php...
če pa vzamemo v pogled še hd6950
je malo bolj poceni
ma nvidia odtehta 60 evrov več
DOOM_er ::
e-penises off the scale
IvoJan ::
DOOM_er je izjavil:
še dobro da mojga ne vidiš :) sem tudi kupil GTX570 in to takrat ko so vsi pametovali da jo bo HD6950 ass rejpala :)
jazbec je izjavil:
D3m je izjavil:
:)) win!
Cicek1 ::
Kaj naj pol rajši uzamem GTXA al kaj? Ka pa menite tisti k mate ta nove radeone 6XXX serijo?
Cicek1 ::
Kaj pa tale grafična?
http://www.zagrabi.si/artikel/31625/
jazbec ::
potem se ti bolj splača gtx460
vzami gtx470 če imaš dena pa gtx570
jo dobiš na dinokomp za 340 evrov
Cicek1 ::
Tam nekje do 300 evrov gledam, več pa ne ker ni tok denarja...
Pomoje bom kr tole vzel kaj pravte?
http://www.ceneje.si/racunalnistvo/komp...
  • spremenil: Cicek1 ()
Machiavelli ::
gtx570 320eur ju3 dobim hahahah
Nigaaazz
jazbec ::
kje si jo dobu za 320
ki jo sošolc kupuje
je pršu k pameti in prodal hd6950 staro 2 dni, da bo kupu gtx570:D
Machiavelli ::
Tujina...več zs xD
Nigaaazz
galu ::
jazbec je izjavil:
Če ti misliš da je on prišel k pameti, potem res upam da je tvoj IQ vsaj malo višji od decemberskih temperatur...
GTX570 je boljša od HD6950 in HD6970, to nihče ne zanika, AMPAK glede na to da je razlika med odklenjeno HD6950 in GTX570 minimalno 60e, performance pa je (sodim po techpowerup testih) praktično enak GTX570. V enih igrah je pač AMD boljši v drugih pa Nvidia. Če igraš 24/7 physix igre je čisto logično da boš dal tistih 60e zraven pa kupil GTX570. Če pa igraš ostalih 95% iger, pa je AMD HD6950 (katera se odklene) IMHO boljši nakup, glede na ceno.
edit: grammar
Tako to gre.
  • spremenil: galu ()
Machiavelli ::
Pozabljaš na drivere!! + gtx je 2-4x močnejša v tessalaciji kar pomeni da boš lahko komot igrau špile čez 2leti ;)
Nigaaazz
jazbec ::
on se je sam izrazuda se je zafrknu in da nakup obžaluje
zdej pa samo čaka, da kupi gtx570
PujsaPepa ::
Machiavelli je izjavil:
Mah, fantje so po flashanju BIOSa ventilator pustil na default vrednostih od neMOD-ane 6950 in jim je začelo srat. Seveda je treba vent povečat, in potem lahko daš še PowerTune na +20% pa piči kot mora. Če pa pustiš vent na default, pa seveda ne bo dosegal, in bo kartico "dynamic TDP management" blokiral v hitrosti.
PujsaPepa ::
Link :
kartice so clockane.
Serija sploh 6xxx ni nateg napram 5xxx. Dobil si 3D podporo in končno pošlihtan CrossFire, tako da ko daš dve AMDjke skupaj v CF res dobiš 100% več, kar prej v seriji 5xxx nisi, pri Nvidijenem SLI pa TO SI dosegal, in tako sta se proizvajalca po mojem mnenju izenačila.... dokler ne pride AMD z 6990 ven, ki če jim ne bo treba zaradi pregrevanja ali prevelike Wattaže manjšat clocka, bo gladko prehitela 580GTX (saj to že zdaj po nekaterih testih 6950 CF naredi - 6990 pa ne bo nič drugega kot 2x 6950)... živi bili, pa videli... in pa če se to zgodi, bo Nvidia enostavno samo RAM povečala na 5xx seriji na 2GB in bo tudi v visjih resolucijah konkurenčna - a to jim bo še malo povečalo ceno kartice... torej živi bili, pa videli :)
  • spremenilo: PujsaPepa ()
galu ::
SLI ima 100% scaling? E dej dej, ti pa že blodiš v enem svojem svetu..:))
HD6950 odklenjena gre čisto lepo še naviti za 50MHz brez kakšnega koli večanja obrtljajev venta.
Tako to gre.
japol ::
Jst mam zlo slabe izkušnje z geeforcom in to vse od starih 4200, 4400, pa do 8800gtx,... in današnjih, od pc pa za laptope in glede na amd (ati) se grejejo za znort, če je ventilator na grafi, ga je nujno treba čistit, ker začne rulit da je za znort, v laptopih bi lahk na tipkovnici "jajca peku", ne morš tipkat, glasne so k hudič, zard vročine se nalepke in plastika krivi,... da ne govorim k je isto grafo delalo več firm, pa ena se je zgrizla totalno, druga pa delala brez problemou,...pr geeforcu je bla "znanost" poštimat driverje za grafo za laptope, precej boljše je blo pr amd, zdej pa itak ma to amd na svoji strani ločeno. Jst sm za amd, na laptopih sploh ne slišiš ventilatorjev, pa poglej kolk majo rež in vetilatorjev in kakšne, če maš ati al pa amd. Pa posluš zvok... milina.
Cicek1 ::
Fantje jst sm tole gledu, k se mi zdi da je kr poceni glede na druge trgovine, tle u futech je 266 evrov, vsepovsod drugje pa krepko čez 300 evrov!!!
Machiavelli ::
Informacija,6950 po odklepu na nekaterih modelih naj nebi ventilator deloval z prilagojenimi obrati posledično pregrevanje kartice,odklepanje tudi lahko povzroči nestabilnost kartice in artifakte zaradi previsokih frekvenc.
Nigaaazz
galu ::
Kolko pa je max temp za 69xx?
Tako to gre.
Machiavelli ::
110c mislim de
Nigaaazz
Cicek1 ::
Nevem al naj uzamem tole: http://www.dinokomp.si/product_info.php...
Al tole: http://www.funtech.si/si/vsi-oddelki/ko...
Zdej trenutno mam radeona 4870 pa sm full zadovoln z njim, zdej je pa useen cajt da ga zamenjam, mogoče bi tut zarad tega rajš uzel RADEONA.....
IvoJan ::
ce izbiras med 6950 in 470 definitivno raje 6950.
  • spremenil: IvoJan ()
Cicek1 ::
IvoJan je izjavil:
Razloži zakaj, ala bi rajš kej druzga kupu'
IvoJan ::
ker je za isti denar močnejša?? pa še odkleneš jo na 6970.
Cicek1 ::
Jah tole za odklent je tko tko jst ne vem če bi glih upou to delat, pravjo da lahko postane nestabilna...
Še neki ti tkBurek, a ti men svetuješ radeona samo zato ker ga maš ti, al zarad česa druzga? Čaki ti maš 5850 u crossfire ane?
A ma gdo GTXA 470 pa naj pove kako dela?
Pa nevem a je 6950 pr Dinokomp.si najcenejša?
49106 ::
Radeoni so že itak sami po sebi manj stabilni, že zaradi driverjev.
Nvidiina 4x0/5x0 serija dela tako kot mora, edino problem je poraba pri gtx 470/480
Glede r6950@6970 pa predlagam, da nekdo naredi kakšen stress test npr. 4-6 ur igranja.
Puste benchmarke, saj šoferje prilagajajo tako, da deluje kar se da najbolje. Moj največji padec doslej je bil iz FX 5900 na R9600XT... Primerjava med karticama
No tedaj sem še aktivno igral COD2. R9600xt je bil povsem primerljiv a ko je nekdo odvrgel dimno bombo, so se začeli diapozitivi, in takrat je fx 5900 pokazal svoj obraz. Čeprav je bila to najbolj kurzana grafična tistih časov, ni nikoli zatajila. Malenkost, ki pa je zame več kot le malenkost :D
Machiavelli ::
gtx 470 je malo ceneje in skor vsaka gre 100% 100-150mhz oc če ne več,in dobiš komot rang 6970/570,je malo več toplote vendar je tudi tessalacijsko zelo močna.6950 je dražja mogoče se celo stabilno "odklene". če ti ni do eyefinitija 470,če ti je pa 6950. Pač kakorkoli obrneš 470 ponudi več za manj denarja,gledano 220-260rang.
6950 pa ima vsaj pri nas zelo smešno ceno 270-300eur.
Če bi izbiral med 6950/70 pa 570 bi izbral 570.
Če pa med 470 pa 6950 pa malce premisleka 470 ima kar prednost.
Nigaaazz
jizzer ::
Jaz sem šeč oz NV na prvega ATi-ja v življenju pa mi je precej žal, ampak nvidia v času ko sem jaz to kupoval ni mela nobene pametne. Zato ti priporočam x70 GTX :)
2 3 4
Radeon 6950 se odklene (strani: 1 2 3 )
11839037 (33476) Jst
Radeon HD 6870? (strani: 1 2 3 4 … 17 18 19 20 )
983172094 (155062) D3m
Nvidia vs AMD,Gtx 470/570 vs 6970/50HD+Novice (strani: 1 2 3 4 5 6 7 8 )
363102503 (96818) bluefish
Katero grafično kupiti
286047 (5464) mihco
Kako AMD6950 postane 6970 s flashanjem in premaga 570GTX ? (strani: 1 2 )
Oddelek: Navijanje
5513448 (12721) 49106
