Forum » Pomoč in nasveti » Skype se noče vpisati
nUUb ::
Ima še kdo probleme? Zaenkrat potrjeno z treh strani z različnih PCjev, ISPjev. Kdo ve kaj je šlo narobe?
i7 2600k@4.8GHz - nV 760 - 850 EVO 250GB - 4TB FreeNAS
ASUS 1920x1080@144Hz
nUUb ::
opa potem res nismo edini...prvič da ne dela skype
nUUb ::
Cca 4 leta? Prej pa MSN...nažalost
StratOS ::
Meni tud ne .... :(
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
StratOS ::
Status Update
Skype downtime today
Earlier today, we noticed that the number of people online on Skype was falling, which wasn't typical or expected, so we began to investigate.
Skype isn't a network like a conventional phone or IM network - instead, it relies on millions of individual connections between computers and phones to keep things up and running. Some of these computers are what we call 'supernodes' - they act a bit like phone directories for Skype. If you want to talk to someone, and your Skype app can't find them immediately (for example, because they're connecting from a different location or from a different device) your computer or phone will first try to find a supernode to figure out how to reach them.
Under normal circumstances, there are a large number of supernodes available. Unfortunately, today, many of them were taken offline by a problem affecting some versions of Skype. As Skype relies on being able to maintain contact with supernodes, it may appear offline for some of you.
What are we doing to help? Our engineers are creating new 'mega-supernodes' as fast as they can, which should gradually return things to normal. This may take a few hours, and we sincerely apologise for the disruption to your conversations. Some features, like group video calling, may take longer to return to normal.
Enterprise products including Skype Connect and Skype Manager continue to function normally. Customers using the enterprise version of Skype for Windows may still experience delays signing in.
Stay tuned to @skype on Twitter for the latest updates on the situation - and many thanks for your continued patience in the meantime.
| » | Skripal (strani: 1 2 3 )Oddelek: Loža | 43214 (28963) | Pac-Man |
| » | Nov članek: "All your firmware are belong to us" (strani: 1 2 3 )Oddelek: Novice / Nova vsebina | 20359 (17199) | arrigo |
| » | Google Talk (strani: 1 2 3 )Oddelek: Novice / Omrežja / internet | 18476 (12299) | slitkx |
| » | Pomoč pri MySQL in PHP...Oddelek: Programiranje | 2407 (2275) | darh |
