Forum » Loža » Kakšna bitja so to???
borinho ::
Tomi kolk časa jo pa poznaš?, kr mal še počaki, pa boš videl, nč novega- hudič samo pakiranje je drugo
Tomi ::
Da malo pomislim, slabe tri tedne. Upam, da ne bo imela kmalu kakšnih čudnih, če pa že, morje je polno rib, pravijo.
metrodusa.blogspot.com
Lucifer Tanatos ::
SUBJECT: Upgrading from GirlFriend 1.0 to Wife 1.0
Last year a friend of mine upgraded GirlFriend 1.0 to Wife 1.0 and found that it's a memory hog leaving very little system resources for other applications. He is only now noticing that Wife 1.0 is also spawning Child-Processes which are further consuming valuable resources.
No mention of this particular phenomena was included in the product brochure or documentation, though other users have informed him that this is to be expected due to the nature of the application.
Not only that, Wife 1.0 installs itself such that it is always launched at system initialization where it can monitor all other system activity. He is finding that some applications such as PokerNight 10.3, BeerBash 2.5 and PubNight 7.0 are no longer able to run in the system at all, crashing the system when selected (even though they always worked fine before).
At installation, Wife 1.0 provides no option as to the installation of undesired Plug-ins such as MotherInLaw 55.8 and BrotherInLaw Beta release. Also, system performance seems to diminish with each passing day.
Some features he'd like to see in the upcoming Wife 2.0:
A "Don't remind me again" button
Minimize button
An install shield feature that allows Wife 2.0 to be installed with the option to uninstall at anytime without the loss of cache and other system resources
An option to run the network driver in promiscuous mode which would allow the systems hardware probe feature to be much more useful
I myself decided to avoid all of the headaches associated with Wife 1.0 by sticking with GirlFriend 2.0. Even here, I found many problems. Apparently, you cannot install GirlFriend 2.0 on top of GirlFriend 1.0. You must uninstall GirlFriend 1.0 first. Other users say this is a long standing bug which I should have been aware of.
Apparently, the versions of GirlFriend have conflicts over shared use of the I/O port. You'd think they would have fixed such a stupid bug by now. To make matters worse, the uninstall program for GirlFriend 1.0 doesn't work very well, leaving undesirable traces of the application in the system. Another thing that's annoying - all versions of GirlFriend continually popup little messages about the advantage of upgrading to Wife 1.0.
*** BUG WARNING ***
Wife 1.0 has an undocumented bug. If you try to install Mistress 1.1 before uninstalling Wife 1.0, Wife 1.0 will delete MSMoney files before doing the uninstall itself. Then Mistress 1.1 will refuse to install claiming insufficient resources.
To pove vse
Minimize button
*** BUG WARNING ***
To pove vse
Les yeux sans visage
undefined ::
> Res pa je, da ljudje (beri: moški) nikoli ne bomo mogli popolnoma razumeti žensk.
Jaz tudi ne razumem dosti moških. V čem točno je razlika tukaj? Vse skup nepremišljene najstniške klamfarije.
Ljudje kot taki se pač ne razumemo, saj če bi se, ne bi bilo nobenih vojn, kajne? Najpogostejši problem pa je, ko ne poznamo samega sebe, kaj šele nekoga drugega. Čeprav je vedno biti lažje kritičen do drugih, kot pa do sebe, kajne?
Lucifer Tanatos ::
seveda je lazje bit kriticn do drugih, predvsem se mn sekiras, samo ne vzemat tega kar tle pisemo 100% resno, ker je vecina postov misljena v sali(saj mojih:)). V resnici smo vsi smotani, tko moski kot zenske(sam slednje bl
borinho ::
Ice man: tole je cist ena "lahka" debat, point niso prov globoke debate, sicer je to kar si napisal 100% res. Samo vsega pa ne jemat prevec zares. "Najstniška", jest nisem več najstnik-zamerim
Lucifer: se strinjam
trillian ::
borinho...
bi raje videl, da bi grizla in norela zaradi takih komentarjev na racun lastnega spola?
dvomim. :)))
love, trillian.
dvomim. :)))
love, trillian.
"The generation of random numbers is too important to be left to chance"
borinho ::
Ob takih komentarjih bi norela le skrajno neinteligentna bitja, tak biser kot si ti pa cist jasno da ne
(a ti dobr v rit lezem)
Lucifer Tanatos ::
mislm borinho, tle jih mormo sinfat ne pa hvalt
Drgac je pa ql da se ne sekiras trillian(ceprov smo s tem prihranjeni za marsikateri uzitek
borinho ::
BINGOOOO
mal ne morm iz svoje kože, zmer k je kšna ženska zraven se morm avtomatsko slinit
trillian ::
borinho.
vidis. tak odnos pricakuje tvoja draga od tebe.. kup komplimentov. sploh, ce je zoprna.
prihrani jih zanjo. hvalezna ti bo.
love, trilllian.
love, trilllian.
borinho ::
Trilian sej tist v uvodu ni bla moja draga, tut nism nikol trdu da je
, he he trenutno sem pr tem da je moja draga moja roka, ampak sem vseeno prjazn do nje, pa roki tut naklonim cel kup komplimentov
trillian ::
eh. vseeno. :))
lepo, da se obremenjujes z mnenjem vseh deklet. that just shows you care.
love, trillian.
love, trillian.
trillian ::
in kaj ti bo ostalo po dragi locitvi?
love, trillian.
love, trillian.
jao men zenske skos povzrocajo glavobole in visok pritisk.sej se bom kr najavu v NLP da me bodo pricakoval.
Lucifer Tanatos ::
no ja tok, delajo nas zicne, sam hkrati nas pa vcasih tut kr lepo razvajajo(sam to (pre)malkrat
- spremenilo: Lucifer Tanatos ()
borinho ::
V bistvu jest do zensk nisem zahteven, edina stvar je ki jo zahtevam(preden mam kej z njo) je preprost podpis na temle formularju
DEKLISKA POGODBA
Jaz, __________________ spodaj podpisana, sprejmem, da...
1) V malo verjetni situaciji, da mi ne pride, ko se pijan zvalis na
mene in me pumpas pet minut (vzdihajoc pri tem kot neki vecji astmatik),
bom
ljubeznivo odigrala orgazem. In to na zelo prepricljiv nacin, vzdihujoce
in
zavijajoce kot macka v februarju.
2) Ce mi Tvoja mati pokaze slike iz Tvojega otrostva ali one iz
tetinih porok, na katerih si urejeno pocesan, kot da so Te krave lizale,
ne bom
tega nikdar pokomentirala. Nikdar.
3) V popolnosti se strinjam, da je zenina primarna vloga, da je kriva.
V primeru, ko unicis del pohistva, skupnih stvari, ali Tvoj tim izgubi
tekmo, sprejmem, da - po neki zakomplicirani formuli, nerazumljivi za
zenske mozgane- to postane moja krivica. Tudi, ce nisem bila fizicno
prisotna.
4) Zmeraj, ko se bom pogovarjala s svojimi prijateljicami, jim bom
s strahospostovanjem razlagala, kaksen zrebec z "orodjem" nadnaravnih
dimenzij si v postelji.
5) Pripovedovala bom to enako tudi Tvojim prijateljem. Vedno.
6) Po seksu (o katerem se ne bom nikdar izrazala kot o "ljubljenju") ne
bom pricakovala, niti zahtevala, da me bozas ali kaksnih podbnih
bedastih neznosti. Ne bom dovolila tudi, da ti moji lasje zakrivajo tvoj
obraz..
7) Absolutno nikdar ne bom bila proti Tvojem penisu.
8) V postelji bom zmeraj voljna, da preizkusim vsako pozo, ki Ti
pride na pamet. Posebej tisto, kjer jaz vse delam.Ti samo lezis in
uzivas.
9) Nemilostljivo bom izprasala vse moje lepe prijateljice, da
izvem, ce katera od njih kaze vsaj najmanjso biseksualno usmerjenost..
Nato jih bom povabila k nama na vecerjo. Skrila jim bom kljuce od avta,
da
bodo morale prespati pri naju.
10) Ko bova sla narazen, ne Bom spala niti z enim od Tvojih prijateljev,
niti s katerim drugim, ki ga poznas. Ali ki bi ga lahko spoznal nekega
dne. V bistvu, ce kateri moski poskusa, kaj na meni, bom izjavila, da so
mi po tebi vsi moski nezanimivi.
11) Popolnoma sprejemam dejstvo, da so mehanski objekti, kot so
avto, racunalniske igre in daljinski upravljalniki nad skromnimi
mentalnimi mocmi zenske. Izpadla bi popolnoma neumna, ce bi
jih uporabljala in jih prepuscam Tebi po mili volji. Razen likalnika
in pomivalnega stroja, seveda.
Podpis: _____________________
Datum: _____________________
DEKLISKA POGODBA
bom
in
ne bom
prisotna.
obraz..
uzivas.
da
Lucifer Tanatos ::
Nej uganm, edina k te ni pre****** in je se podpisala hkrati je bla nepismena
trillian ::
borinho..
opazam, da si precejsen optimist.
love, trillian.
love, trillian.
ja sej ce hoces najdt kokr tok normalno zensko mors bit zelo velik optimist.
undefined ::
Si jo potem že dobil, al te ni dost optimista?
darh ::
difiniraj "normalno"
moja je.. pa čeprav se komu zdi da ni... veš...
Excuses are useless! Results are priceless!
gazda ::
Hudic, ampak fantje a nebi blo dolgcas ce nebi blo takih problemov z zenskami? Kje bi bla pa vsa strast....
gazda ::
kot je xbite rekel: "definiraj normalno"
Jest trdim da precej teh stvari kar ste rekli dolocajo normalno zensko
(s tem da so mogoce mal pretiravane
Sicer pa po mojem mnenju nasprotja najbolje privlacijo (or is it just me?).
Lucifer Tanatos ::
gazda se strinjam, nasprotja se najbl prvlacjo, no saj mene najbl zenske k majo lih nasprotno mnenje kot jst(vecji iziv, ce mas zensko k se v vsem strinja s tabo je ziv douhcajt, preverjeno
, ce mas kako k se ne je pa dost zanimivo, ce ti je douhcajt se lohka tko u izzy gres mal preperat z no, pol nakonc se pa pobotas(SCORE
) in je vse ql. Kaj vec si sploh lohka zelis
ne jest sploh nism optimist, ampak sm bl pesimist
Gandalfar ::
ma dekleta so ja fajn.. ce nc druzga ti ponavad omogocajo da vids stvari tud v drugi luci ^_^
undefined ::
Al pa tud brez luči.
undefined ::
Mal heca more bit, da ne bi blo kakšnih misinterpretacij ali da ne bi kdo resno vzel. Drugače se strinjam z Gandalfom.
borinho ::
Sej mislm da je 60% postov v tej temi heca tko da nič se bat, je bil tut tvoj post tko vzet
Daedalus ::
>Al pa tud brez luči
Brez luči ni tak zanimivo
[J.P.Sartre]
[J.P.Sartre]
Koci ::
Nekaj nasvetov da osrečiš žensko.
Da bo zenska s tabo srečna moraš biti:
1. prijatelj
2. druzabnik
3. ljubimec
4. brat
5. oce
6. ucitelj
7. vzgojitelj
8. kuhar
9. zidar
10. vodoinstalater
11. mehanik
12. dekorator notranjih prostorov
13. stilist
14. seksolog
15. ginekolog
16. psiholog
18. psihiater
19. terapevt
20. drzen
21. organiziran
22. dober oce
23. cist
24. simpaticen
25. atletski
26. ljubec
27. pozoren
28. kavalir
29. inteligenten
30. poln fantazije
31. kreativen
32. sladek
33. mocan
34. razumevajoc
35. toleranten
36. oprezen
37. ambiciozen
38. sposoben
39. korajzen
40. odlocen
41. zanesljiv
42. spostljiv
43. zagrizen
44. poln komplimentov
45. hoditi po nakupih z njo
46. ne delati problemov
47. zelo bogat
48. ne tezak
49. ne gledati drugih
Obenem mora moski paziti, da:
50. ni ljubosumen, kljub temu pa ne nezainteresiran
51. mora se razumeti s svojo druzino, ampak ne sme jim
namenjati prevec casa
52. da njej prostor, ampak se mora hkrati sekirati,
kam ona gre
Ob vsem tem je zelo pomembno:
53. ne pozabiti naslednjih datumov :
* obletnica (poroke, zaroke, prvega poljuba...)
* diplome
* njenega goda
* njenega rojstnega dne
* rojstnega dne njene najboljse prijateljice (ampak ne pokazati
prevelikega interesa v tem, samo omeniti pravi dan)
Na zalost tudi ce spostujete vsa navodila, ti ne
morem garantirat
100%, da bo ona res srecna,ker bi se lahko nenadoma
pocutila potopljena v zivljenje prevelike popolnosti,
ki jo dusi in bi zato utegnila zbezati s prvim
"izkoriscevalskim-butastim-kretenskim-osladnim-idiotom",
ki bi ga srecala...
Verjetno je zato Bog rekel: "Ljubi jo!", ampak nikoli
ni omenil "Razumi jo!".
In kako ženska osreci moskega:
1. pride gola...
2. prinese hrano in kaksno pivo
1. prijatelj
2. druzabnik
3. ljubimec
4. brat
5. oce
6. ucitelj
7. vzgojitelj
8. kuhar
9. zidar
10. vodoinstalater
11. mehanik
13. stilist
14. seksolog
15. ginekolog
16. psiholog
18. psihiater
19. terapevt
20. drzen
21. organiziran
22. dober oce
23. cist
24. simpaticen
25. atletski
26. ljubec
27. pozoren
28. kavalir
29. inteligenten
30. poln fantazije
31. kreativen
32. sladek
33. mocan
34. razumevajoc
35. toleranten
36. oprezen
37. ambiciozen
38. sposoben
39. korajzen
40. odlocen
41. zanesljiv
42. spostljiv
43. zagrizen
47. zelo bogat
48. ne tezak
kam ona gre
* diplome
* njenega goda
morem garantirat
ki bi ga srecala...
1. pride gola...
Panta rei!!
- spremenil: Koci ()
trillian ::
sploh se hitro zaletis v kaka zaprta vrata ali drevo....
love, trillian.
love, trillian.
Tomi ::
Ah, kaže, da sem prehitro pohvalil ono od prej.. Sedaj mi ni glede nje prav nič jasno.
undefined ::
Tomi, damn it. Postavi jo pred dejstvo - vprašaj jo kaj hoče. Al je še za, al ni več, naj enostavno lepo pove, da si na jasnem. Prej ko boš zvedel resnico, prej ti bo lažje.
Gandalfar ::
ce malo dlje vztrajas te mogoce se bolj vzljubi pa potem gre kar samo .. kaj pa tako?
drugace se lahko ustrasi..
sicer pa jzt krneki pisem kakor se mi zdi. O dekletih itaq nimam pojma ..
undefined ::
Hehe. Gandalfar, tudi možno, kaj pa jaz vem. Nazadnje bo najbolj vedel Tomi, kaj je prav.
| » | Prijateljstvo ali ljubezen? (strani: 1 2 )Oddelek: Loža | 9141 (6650) | CoolBits |
| ⊘ | Kakšna dekleta so vam všeč??? (strani: 1 2 3 4 … 8 9 10 11 )Oddelek: Loža | 60535 (12806) | Poldy |
| » | vesna v. godina vs. racunalnikOddelek: Loža | 2882 (2490) | iration |
| » | Osvajanje zensk (strani: 1 2 )Oddelek: Loža | 9867 (8483) | Yohan del Sud |
| » | dekleta na forumu? (strani: 1 2 )Oddelek: Loža | 6147 (5026) | Klemenn |
