Radeon HD 6870?
Radeon HD 6870?
3 / 20
Machiavelli ::
Hey probaj dolimat tele čez
http://support.amd.com/la/kbarticles/Pa...
V kolikor zgornji link nedeluje pa na tegale
http://www.tcmagazine.com/tcm/downloads...
Nigaaazz
Clubraider ::
zoom@
Vse možne varjante sem probal, pa nič ni obrodilo sadov.
Imam pa Matično ploščo Gigabyte GA-MA790X-UD3P, AM2/AM2+/AM3
Največja finta je v tem, ko crossfire izlopim in igram na eno grafično kartico vse deluje tak kot treba in se tudi FPS-ji ujemajo z testi na strani guru3d...
ko pa crossfire vklopim, pa drastično padejo, tudi če spreminjam nastavitve v sami igri...
Moj sistem:
Ohišje Chieftec DF-01B + 5 x Ventilator za ohišje Xilence TR 120 mm (COO-XPF120.TR)
1 x Slot ventilator za hlajenje računalnika
1 x Hladilnik Zalman ZM-NB47J Northbridge
1 x CPU Hladilnik Arctic Cooling Freezer 64 Pro
2 x Napajalnik ENEGRON 750W
Procesor AMD Phenom II X6 1055T 2,8 GHz, AM3 @ :) Overclock to 3,36 GHz
Matična plošča Gigabyte GA-MA790X-UD3P, AM2/AM2+/AM3
3 x 2GB of ram CEON 800 Mhz DDR2 + Hladilnik za RAM akasa AK-171-BL
2 x Grafična kartica Sapphire Radeon HD 6870, 1 GB, PCI-E CrossFireX
Trdi disk 640GB+500GB WD Caviar Green
Miška Pleomax SPM-4600
Tipkovnica Logitech Deluxe 250 USB, črna :) Gamepad Speedlink 360 Style
Monitor LCD 24" Dell U2410 - Resolution 1920x1200
Windows 7 Ultimate x64
Machiavelli ::
probaj eno po eno kartico v prvo režo,nato probaj eno po eno v drugo režo...lahko da je kaj do reže samo dvomim....
En tip ma podoben blem z 2x 6850
The reason I ask is that I currently upgraded from CF4870s to CF6850s and I am having horrible fram rates and performance within the Frostbite engine. I've read many different reviews and it seems the review sites are pulling great numbers on their BFBC2 & MOH benchmarks. With CF enabled in either game I get about 40% worse performance than a single 6850. I should be getting about 85-90% increase. All my other games work correctly in CF and I average 56-60fps in unigine benchmark @ 1920x1080with CF enabled.
Si probu na novo formaterati pa vse na novo dat gor?
Nigaaazz
Clubraider ::
Zdai sem razmišljal, da če bi bilo kaj bilo z režo narobe, pol mi niti crossfire nebi zaznalo.
Kar, pa me še najbolj bega pa je to, da pri igri Batlefield BC2 dela perfektno v crossfire načinu.
Je možno, da bi v BIOSU mogel kaj narihtat...nevem kaj izklopit ali vklopit...
Kolega mi je govoro, da bi naj neko voltažo ali nekaj probo povečati....samo na nobenem forumu nisem tega zaznal, da bi kdo to delal..
In tudi AFTERBURNER mi kaže da obe dve grafični delata enako %.
Clubraider ::
Misliš, da bi to pomagalo???
Bojim se da bom zastojn to delal...
Pa nevem, kaj bi to spremenilo, če bi formatiral rač.??
Machiavelli ::
v biosu nimaš kaj povečat ali karkol....pci ex 2.0 ima dosti voltaže+voltaža napajalca....edino kar mi ni kul je toti energon...750w ampak je pasivni torej je izkoristek cca 480w..ampak bi moralo zadostvovati za stock zadeve...sploh ker imaš 2x napajalc..
Pač jast sem imeu prej neko drugo kartico in sem uninstall in vse pa sem imeu zelo bogi performanc 12K 3d vantage...nato sem na novo vse inštaleru in v vantage spraznu cache in lejga 15,5K ...
če imaš kak stari disk probaj na njega začasno na novo inštalirati pa probaj...
Nigaaazz
Clubraider ::
Jooj, če bi vedel, da bo res pomagalo bi takoj formatiral...samo sem malo skeptičen...
Ja en napajalnik imam samo za obe grafični tako da imata zadosti energije....
Kaj ti tak konkretno misliš....bi znova formatiral in naložil w7??
Machiavelli ::
Probat ni greh ,če imaš kak disk viška ali kak stari disk probaj na njemu...
Nigaaazz
Clubraider ::
Bom še to tudi probal, kaj čem drugega...
Rezervnega diska nimam, bom z totim probal...da se res prepričam, če pa nebo delalo, pa njiju menjam za katero drugo.
Samo full imam občutek, da nebo delalo...
Bom poročal, kak bo.
Clubraider ::
Pogovarjal sem se z enim in mi je dejal, da imam procesor preslab, da bi lahko podatkovno obe dve grafični zaposlil...
Kaj mi preostane...nevem
Verjetno njiju zamenjam za GTX 580 ali pa RADEON HD 6970...
galu ::
Haha, idiot.
Tako to gre.
Machiavelli ::
Procesor je več kot dovolj moćen LoL
Močn Bottleneck bi bil kakšen x2 x3 Procesor pod 2.8Ghz....
In tudi tam bi delovalo kar se da vredu..
x6 na 3.3Ghz pa lih ni bottleneck...
GTX580 se mi zdi bolje kot 2x 6870 na drugi roki pa 6970 bo ceneje in skor enako močna kot gtx580...
Ti probaj na novo vse namestit v kolikor nebo pomagalo pa..uzami drugo kartico...
Nigaaazz
ncc2000 ::
procesor je čist ok tko da to ziher ni tu problem
zmanjšaj za probo eno izmed particij, ustvaro novo in nanjo naloži čist sistem, osnovna jajca, driverje za grafo in par špilov... dobro urco boš zagonu... ker če isti softweare dela na enakem hardwearu drugje, potem je treba dopustiti možnost, da je na tvojih winsih kaj zapacano
IvoJan ::
x6 na 3,3 še lep čas ne bo bottleneck ker še x4 niso čisto izkoričeni :) počakat boš moral na boljše driverje ker imajo nove serije na začetku vedno težave z driverji, ampak jih zrihtajo čez čas.
Machiavelli ::
Za vse lastnike 5xxx serije in 6xxx serije
Najnovejši Hotfix 10.10e
Se dolima k orginal 10.10.
AMD Catalyst 10.10e Hotfix Features:
The AMD Catalyst Control Center now features the new AMD Catalyst AI user interface options on the ATI Radeon™ HD 5000 Series (the new AMD Catalyst AI options were previously only available for the AMD Radeon 6800 Series)"
Fixed cases where Morphological Anti-Aliasing (MLAA) was not being correctly applied to games (very intermittently)
OpenGL 4.1 beta support
Support for the new Morphological Anti-Aliasing feature
Dead Rising 2 - Crossfire profile (Resolves negative scaling)
Crossfire Performance Improvement for:
Metro 2033
F1 2011 - (Direct X9 version)
Fallout New Vegas
Performance optimizations for systems with an AMD Radeon HD 6870 and AMD Radeon HD 6850 series of graphics products installed
Aliens versus Predator performance enhancements
Star Craft 2 performance enhancements
OpenGL performance enhancements - gains can be seen in Prey, Quake Wars: Enemy Territories, and Heaven v2
Support for additional Stereo 3D-capable displays:
Viewsonic V3D241wm-LED
3D Projectors
XP / Vista / 7 (32bit & 64bit)
Link Offical:
Link Copy:
Link to my Server:
http://amd.pajo50.operaunite.com/file_s...
Nigaaazz
galu ::
Sem dobu HD5850, z garancijo v slo za 105e... :P
How cool am I?:D
Tako to gre.
Machiavelli ::
Lepo to DaChampR :) Misliš 150eur?
Nigaaazz
galu ::
105:)
Oz, če smo natančnejši, z PPT 112e..
Tako to gre.
  • spremenil: galu ()
Machiavelli ::
aha..lpo to :D
Nigaaazz
jan01 ::
@Clubraider
Zanič napajalnik? Kako 2x?
IvoJan ::
samo je dobil sapphire v.2 ki jo je skoraj nemogoče navit :)
Machiavelli ::
jan01 je izjavil:
@Clubraider
Baje ima vezano tak da ko užge enega da se tudi drugi prižge en napaja kartice eden pa sisem...vsaj mislim da ma tako?
Energon pa res ni nek napajalc...je komaj folgu mi z 4870x2...
Nigaaazz
galu ::
IvoJan je izjavil:
Meni leti na 930Mhz GPU, ter 1240 memory, to pa ni niti tko ful slabo... :)
Tako to gre.
Machiavelli ::
Kakor vem se je edino od Asus referenčna lepo navijala 1000/4800"efektivno"....5850.
Ostale referenčne 5850 so pa šle v povprečju tam 960/1250...
Itak kej uber nemoreš iztisnit iz teh kartic,naravne fizike zakona nedovolijo xD
Nigaaazz
IvoJan ::
galu je izjavil:
IvoJan je izjavil:
zame to sploh ni overclock :) 5850 mora letet na 1ghz core :)
  • spremenil: IvoJan ()
Machiavelli ::
nekako takole 5970 nato gtx580 nato 6870CF 6970 pa bo tam tam kot 5970 za 340-360eur(6970) 380-450eur (5970) 450-530eur (580) 460-530eur (6990)
6990 pa bo zopet najhitrejša samo izide drugo leto...
6970 sodeč po temle grafu nebo močnejša od 5970 in sodeč po razporedi cena/moč...
Pomnimo da gtx580 je enaka oz hitrejša od 5970 v igrah je 5970 malo boljša in nekako povežeš z grafom in po logiki če 6970 nebo niti enako hitra kot 5970..potem bo gtx580 najhitrejša enojederna grafa..
Bo pa 6970 velik naskok iz 5870 za isti denar to pa ja....
Nigaaazz
galu ::
IvoJan je izjavil:
galu je izjavil:
IvoJan je izjavil:
To na luftu ne letijo na auto ventu.
Tako to gre.
Machiavelli ::
Sam sem imeu 5850 sapphire referenčno in sem jo flešu na asus...
980/1260 1.3v sem bil takrat dosegu....
Nigaaazz
galu ::
Kolko pa na stock V in auto fan?
Tako to gre.
Machiavelli ::
Stock je bilo
960/1260
Ob naviti pa sem ventilator temu primerno naštelu :)
Nigaaazz
galu ::
No, slabih 50MHz še ti vedno fali... 1GHz grejo res redki primerki!
Tako to gre.
Machiavelli ::
eh itak nimam une grafe več.... kar se tiče navijanja je tak lahko se zgodi da dobiš slabšo znamko ceneje in se kartica uber navija...ni pa rečeno za Radeon linijo bi jih postaviu nekako takole
sicer je več možnosti da si sledijo po navijanju tako..ni pa rečeno..
1.Asus
2.MSI
3.XFX
4.HIS
5.Gigabyte
6.Sapphire
7.PowerColor
8.3D Club
Nigaaazz
kmetek ::
galu je izjavil:
How cool am I?:D
kera budala pa je prodal tako poceni?
TOP ::
To se tud jaz sprašujem,verjetno je bil pod uplivom opojnih substanc :))
IvoJan ::
tisti tip ki sem mu jo jst manj kot 1 mesec nazaj za 200EUR prodal xD
TOP ::
HAahahahahahhah taje pa dobra potle je pa tale tip res mal čuden.Upam da ne bere tega foruma,ker potle bo znoru
galu ::
Mislim da bere..:D
Tako to gre.
Machiavelli ::
xD
Nigaaazz
IvoJan ::
kdo mu je kriv lol. nej bere. bo vsaj vedel kako močno se je zajebal xD
49106 ::
Niti ni tak nateg, kartica več kot 150EUR ni vredna.
TOP ::
Mi se pogovarjamo o 105e ne o 150e to je 45e razlike.
49106 ::
mogoče se mu je mudilo?
IvoJan ::
zato jo je pa 3 tedne prej od mene kupil za 200 aa?? XD
TechBeats ::
Clubraider je izjavil:
zoom@
Moj sistem:
pomoje je problem prešvoh napajalnik, ker je kr ena xy firma sploh pa za 2 grafe..
poglej kle
http://www.overclock.net/power-supplies...
AciD TriP
  • spremenilo: TechBeats ()
jRk0 ::
btw, zakaj pa 3x2gb? ne bi rajsi dual channel laufal?:)
IvoJan ::
pa kva noben od vas ne dojame da ma clovek 2 napajalnika?? In cetudi je noname bo eno 6870 poganjal brez problema.
TOP ::
Fora je v tem,da s tem nima napajalnik prav nič,tukaj je nekaj drugega narobe.Probaj še kakšen drugi špil,ki bolj zahteven pa vklopi glajenje robov in vse kar se da pa potle testiraj.Jaz sem včiraj probal CF5850 in je delov BP.V enih igrah je mala razlika,medtem ko v grafično bolj zahtevnih pa ogromna.Aja pa gonilnike maš 10,10 pa hotffixs si inštaliral.Ker jaz ko sem inštaliral hotfixs sem opazu ogromno razliko v F1 recimo.
  • spremenil: TOP ()
TechBeats ::
IvoJan je izjavil:
zgleda ti ne dojemaš!
jst sm reku da za 2 je najbrš prešvoh, z eno je pa kul kokr je tud sam povedu.
In če je XY in kaže 800w še ne pomen, da je kul kot en 650W priznane firme. Ti kr gon LC powerje nej ti sede lol.
AciD TriP
IvoJan ::
tut če je noname je zmožen poganjat 6870 ki ni neki ekstra požrešna kartica.
očitno nimaš pojma o napajalnikih in si samo eden izmed idiotov ki mislijo da je LC power crap.
galu ::
1x HD6870 + LC800w = OK
2x HD6870 + LC800w = Houston, we have problem.
Tako to gre.
3 / 20
Katero grafično kartico kupiti 6870 ali 6950? (strani: 1 2 3 4 )
17341431 (37862) galu
Radeon 6950 se odklene (strani: 1 2 3 )
11838787 (33226) Jst
Nvidia vs AMD,Gtx 470/570 vs 6970/50HD+Novice (strani: 1 2 3 4 5 6 7 8 )
363102016 (96331) bluefish
Nova Radeona sta tukaj
4622428 (21115) PrimozR
GeForce GTX 580 v sliki in številkah (strani: 1 2 )
6623470 (21343) Senitel
