harmony one
harmony one
zonzi ::
živjo! imam en problem, če mi zna kdo pomagat! za upravljanje svojega sistema uporabljam harmony one. nastavil sem si activity za gledanje movijev, da se mi prižge reciver yamaha rx-v3900, tv sony in htpc silverstone lc 16m. problem je v tem, ker reciver rabi ene 6 sekund, da vklopi vse svoje stvari. istočasno mi pa že prižge htpc in če ni reciver vse vklopil mi htpc zgleda nezazna, da je zvok preko hdmi-ja in mi avtomatcko prestavi na optični izhod in posledično mi zvok ne dela. tako, da moram ponovno resetirati htpc, da mi zvok spet deluje. vem moral bi nastavit delay switch on za htpc. to sem nastavil na 6 sekund in ni nič bolje še zmeraj se prižge istočasno z reciverjem. ali ima mogoče kdo kakšno rešitev?
OldSkul ::
sam tega nisem nikoli delal, sem pa malo poguglal in našel tole:
1. In the "Devices" screen, I selected "Settings" for the DVD player.
2. In the "Settings" screen, I selected "Re-do setup for this device."
3. I clicked through the setup screens using "Next" until I got to "Which command will Power On your device?" Here I selected "I don't have the original remote, but I know the command that is used:" and selected "None" from the popup menu.
4. The Harmony software asked me to confirm: "No command was selected. Would you like to continue?" (Yes)
5. I clicked through the rest of the setup screns using "Next" and finally "Done".
6. In the "Activities" screen, I selected "Settings" for the activity that uses the DVD player.
7. In the "Settings" screen, I selected "Review the settings for this Activity."
8. In the next screen (which shows the settings), I selected "Yes, but I want to add more control of devices and options for this Activity."
9. I clicked through the options screens using "Save" or "Next" until I got to the "Custom Actions" screen.
10. I added two actions for the DVD player when the activity starts: first, a few seconds delay; then the "PowerOn" command.
11. I finished the setup process by clicking "Save", "Next" or "Done" until I got back to the Activities screen, then updated my remote.
zonzi ::
problem je vtem k jst nastavim delay poweron na 6 sekund, samo to ni to!
Wireless kartica ne deluje na win 7
Oddelek: Omrežja in internet
152361 (2203) kratos
[android] vstavljanje slike
Oddelek: Programiranje
71674 (1571) messi
Ker program za Mercury TV TUNER
Oddelek: Programska oprema
51348 (1311) bmen
Asus A7S333 -> voltaža
91513 (1434) m.i.h.a.
Optimalne nastavitve za KT7a/KT7a RAID????
182320 (2117) BoO
