Android - deljenje internetne povezave preko USB (pc -> telefon)
c0dehunter ::
Enako vprašanje sem že postavil na xda-developers, pa bom vseeno vprašal tukaj, pa bom kar prilepil vprašanje:
Hey,
I would like to use my PC internet connection on Magic (CyanogenMod, 2.1) via USB. I have found a good program to do this (PdaNet) and it works good.
But (), at the same time I would like to disable any other source of internet (3g, grps) on my phone so the only possible connection is through PC internet.
For this I have found another widget (Toggle Data), but after I activate it the PC connection doesn't work too.
Can anyone suggest me how to fix this?
Odgovori so lahko v slovenščini :))
I do not agree with what you have to say,
but I'll defend to the death your right to say it.
nigerijci še vedno harajo po bolhi
2410094 (9019) sarma832
Prodajam Renault Megane l 2003 in dobim zanimivo ponudbo
398547 (7077) Go-ahead
Spet nek afrsiki nateg?
413819 (2423) Tic
BAPCo razkrinkan
Oddelek: Novice / --Nerazporejeno--
52633 (2633) kuglvinkl
