Forum » Zvok in slika » lcd refresh rate
lcd refresh rate
darkz ::
MAm sledeči problemček...
Danes sm downloadu nove driverje (nvidia 6800)
in ko sm jih instaliru sm opazu da mam pod monitor refresh rate vse možnosti od 60-200hz ni vazno kasno resolucijo sem zbral...
opazil sem tudi v igrah da FPS negre vec kot 75!?
A ma kdo odgovor na to?
Hvala v naprej, LP
Hvala v naprej, LP
- spremenil: darkz ()
KoMar- ::
Kaj je vprašanje sploh? A zakaj ti kaže do 200 Hz? Pač napaka.
Max je tam okoli 75 Hz in sicer omejitev določata monitor in tip povezave. Recimo za DVI:
Example display modes (single link):
HDTV (1920 × 1080) @ 60 Hz with CVT-RB blanking (139 MHz)
UXGA (1600 × 1200) @ 60 Hz with GTF blanking (161 MHz)
WUXGA (1920 × 1200) @ 60 Hz with CVT-RB blanking (154 MHz)
SXGA (1280 × 1024) @ 85 Hz with GTF blanking (159 MHz)
WXGA+ (1440 x 900) @ 60 Hz (107 MHz)
WQUXGA (3840 × 2400) @ 17 Hz (164 MHz)
Example display modes (dual link):
QXGA (2048 × 1536) @ 75 Hz with GTF blanking (2 × 170 MHz)
HDTV (1920 × 1080) @ 85 Hz with GTF blanking (2 × 126 MHz)
WUXGA (1920 x 1200) @ 120 Hz with GTF (2 x 154 MHz)
WQXGA (2560 × 1600) @ 60 Hz with GTF blanking (2 × 174 MHz) (30-inch (762 mm) Apple, Dell, Gateway, HP, NEC, Quinux, and Samsung LCDs)
WQXGA (2560 × 1600) @ 60 Hz with CVT-RB blanking (2 × 135 MHz) (30-inch (762 mm) Apple, Dell, Gateway, HP, NEC, Quinux, and Samsung LCDs)
WQUXGA (3840 × 2400) @ 33 Hz with GTF blanking (2 × 159 MHz)
SomeOneNew ::
darkz ::
Ah problem rešen,
Imel sem priklopjen tv+lcd in kot zgleda mi je zamešalo vse skupej.
Izklučil sem kabel od tv-ja, restartal in dela ;)
| » | Igranje iger na 55inch TVOddelek: Igre | 3336 (2439) | Ghost007 |
| » | slaba slika monitorja (strani: 1 2 )Oddelek: Pomoč in nasveti | 9948 (9214) | musicfreak |
| » | AGP grafična, ki podpira 1680x1050Oddelek: Kaj kupiti | 1977 (1797) | cycoboodah |
| » | Ati radeon, Xorg in XvOddelek: Operacijski sistemi | 1856 (1728) | MasterMind |
| » | MonitorOddelek: Kaj kupiti | 1946 (1761) | jerry2000 |
