Forum » Kaj kupiti » Monitor
Monitor
Zeratrem ::
Kaj se mi bolj izplaca uzeti Samsung 19' 959NF za 85.000 SIT ali Samsung 19' 955 DF za 65.000 SIT... 20.000 SIT je kar lepa cifra za jo pristet h kaksni drugi komponenti, recimo graficni, tako, da me res zanima, ce se izplaca drazjega kupiti? Kaksne so realne razlike?
Dodgeviper ::
Ja jst sem tudi mal gledal monitorje pa se bom nekak vrjetnu odločil za Hyundaiev monitor.
Specifikacije monitorja pa so:
FLAT ravna katodna cev
Diagonala 19 (18.1 vidna)
Hor: 30-110 kHz,
Vert: 30-150 Hz
Točka 0,25/0,20 mm
1600*1200 - 85 Hz
1280 * 1024 - 100 Hz
1024 * 768 - 120 Hz
TCO 99
Cena 72k
ta cena se mi zdi kar vredi za ta monitor.
Hor: 30-110 kHz,
Vert: 30-150 Hz
Točka 0,25/0,20 mm
1600*1200 - 85 Hz
1024 * 768 - 120 Hz
TCO 99
Cena 72k
- spremenil: Dodgeviper ()
Dodgeviper ::
kakšne so pa specifikacije NF variante mislim osveževanje monitorja, velikost pike itd...
Glede slike pa res nevem dokler si ne ogledam ta monitor.
mato22 ::
Samsung 959NF:
CDT Size: 19” (18.0” viewable)
Face: Natural flat
Deflection: 90°
Pitch: 0.25mm (H)
Surface treatment: Multi-layer coating
Input Signal Video signal: RGB analogue
Sync signal: Separate H/V, composite
SOG (BNC)
Horizontal frequency: 30 - 110 kHz
Vertical frequency: 50 - 160 Hz
Pixel frequency: 290MHz
Signal connection: 15 pin D-Sub+BNC
Resolution Max (based on VESA GTFtiming): 1920 x 1440 @ 73Hz
1800 x 1440 @ 73Hz
1856 x 1392 @ 75Hz
1792 x 1344 @ 78Hz
1600 x 1200 @ 87Hz
1280 x 1024 @ 101Hz
1152 x 864 @ 118Hz
1024 x 768 @ 132Hz
800 x 600 @160Hz
640 x 480 @ 160Hz
Recommended: 1280 x 1024 @ 85Hz
1600 x 1200 @ 85Hz
Display Size Typical (mm): 352 x 264
Max (mm): 366 x 275
Mode Factory/user: 8/10 modes
Power Supply: AC90-264VAC, 50/60Hz
Consumption (nominal): 110W
Power management: 3W @ Off state
Regulation: EPA/Energy 2000/VESA DPMS
User Control Display Director™: Brightness, contrast, position, size, zoom
parallelogram, rotation, pincushion, trapezoid,,
pinbalance, linearity, purity, colour, moire, side pin corner,
pin balance corner, focus, convergence, degauss, recall,
video input level, sync. input type, D-sub/BNC, display
timing, languages, OSD lock/unlock, Highlight Zone
OSD Languages: Applied
Feature Plug & play: DDC 2B/2Bi/GTF
Highlight Zone: Yes
USB (Upstream+cable): Yes
PFC: Regional option
Regulation Safety & X-ray: UL, CSA, TUV, CB, NEMKO,
Korea EK, CCIB, PSB, NOM, GOST, CDRH, IRAM
EMC: FCC, CE, VCCI, C-tick, BSMI,
Mic, ICES
Environmental/ergonomics: TUV GS, MPR II, TCO99 (option)
Windows logo: Windows 98/2000/ME/XP
Set Size (WxHxD) (mm): 468 x 493 x 458
Weight (Kg) Set/packing: 25.30/29.30
Accessory Software kit: Install driver, manual
Natural Color™
MouScreen™
USBHub: Optional
Face: Natural flat
Deflection: 90°
Pitch: 0.25mm (H)
SOG (BNC)
1800 x 1440 @ 73Hz
1856 x 1392 @ 75Hz
1792 x 1344 @ 78Hz
1600 x 1200 @ 87Hz
1280 x 1024 @ 101Hz
1152 x 864 @ 118Hz
1024 x 768 @ 132Hz
800 x 600 @160Hz
640 x 480 @ 160Hz
1600 x 1200 @ 85Hz
Max (mm): 366 x 275
Highlight Zone: Yes
Mic, ICES
Natural Color™
MouScreen™
USBHub: Optional
Dodgeviper ::
Samsungov model ima nekaj prednosti sam nevem glih če so vredne teh dodatnih 13k.
Sicer ti priporočam da si ogledaš obe sliki če je možno probaš kako igro pa boš videl.
Jaz glede na to kar sem imel do sedaj, če primerjam z Hyundai-em ja slika pri tem fantastična.
Bolš nerabim!
Bolš nerabim!
boštjan ::
@zeratrem Samsung SyncMaster 959NF 19" za 75.990,00 SIT in ne 85k,tako za tistih 10k si lahko dodaten ram kupiš,če misliš DF inačico vzet
Dodgeviper ::
Ja še dobr da sem počakal ker se pol vsekakor splača samsungov model vzet.
Hvala Boštjan.
Hvala Boštjan.
jerry2000 ::
Morda kdo ve ali ima Samsung 959, Hyundai P910+, F910, Q910 možnost preklopa med D-SUB in BNC s posebno tipko, ne da bi bilo treba iti v OSD menu?
Morda kdo pozna razlike med temi tremi Hyundai monitorji?
Jerry
Jerry
Mirč ::
jaz uporabljam monitor hyundai q910 in sem z njim zelo zadovoljen (majhne zunanje mere napram samsungovim monitorjem)slika čista,kontrastna, lepe barve uporabljam ga 1 leto(oči me nikoli ne pečejo).Najboljše je uporabjat resolucijo 1280x1024(85Hz)recomended,so glih prav velike ikone.Jaz sem dal za njega 77k pred letom dni zdaj pa je 10k cenej.Vsekakor priporočam.
mirč
mirč
Mirč ::
razlike med f910+ in q910 je v tem da so mere(zunanje mislim) pri q910 dost manjse.Po velikosti zgleda q910 kot 17'' ima izredno malo široke robe okol ekrana,kar se pa tiče ostalih lastnosti teh 2 moniror pa so specifikacije enake.
jerry2000 ::
Potem je Q910 v bistvu boljši, čeprav ima 10 jurjev nižjo ceno pri Emisiji, samo ga ni za dobiti :-(
Mimogrede: Preklop med obema vhodoma pa je preko OSD samo ali ima tipko?
J
J
| » | koliko bi dobil za Monitor LG Flatron 915FT Plus?Oddelek: Kaj kupiti | 1825 (1759) | Utk |
| » | Dober CRT (Trini/Diamond -tron) ali LCD? (strani: 1 2 )Oddelek: Kaj kupiti | 7258 (6317) | iso2000 |
| » | Kateri 19'' CRT predlagateOddelek: Kaj kupiti | 2064 (1656) | ]_g_] |
| » | Kateri monitor?Oddelek: Kaj kupiti | 1949 (1800) | boštjan |
| » | Izbira MONITORJA 19"Oddelek: Kaj kupiti | 1171 (1094) | komanc |
