Forum » Pomoč in nasveti » KDO MI NAJDE USER MANUAL ZA NOKIO 445M 21" ?!
AIDS ::
Lepo prosim vse ki vam je prevec dolgcajt in znate uporabljat WEB
, ce mi najdete User Manual za Monitor NOKIA 445M.
Hvala
Hvala
AIDS ::
Ma sem iskal z googlom pa nic nasel...pa sem mislu da mogoce kdo tle bolj obvlada in ce mu je prevec dolgcajt bi mi lahko uslugo naredu.
Rabm pa zato ker ne znam shranit nastavitev v monitorji. In se ene par stvari je noter k tud priblizn ne vem kaj naj bi ble. In zdej mam monitor cist razstelan.
Ne vem, bom probu kr na NOKIA pisat ce imajo se kak pdf file... :-)
Han ::
V tem primeru boš prej dobil odgovor, če boš pisal na ViewSonic, ki je pohopsal Nokiin oddelek monitorjev...
AIDS ::
Dear Valued Customer,
Thank you for contacting Nokia Display Products Technical Support.
We appreciate the opportunity to assist you. It is our hope that you
have a positive experience with our company. We will respond to your
request as soon as possible. If you would like to speak with a
Technical
Support Representative please call 800-483-7952 or 800-296-6542
between 7:00 AM and 7:00 PM CST.
Thank you for choosing Nokia Display Products.
Respectfully,
Technical Support
Technical
Respectfully,
Technical Support
AIDS ::
In sem dobil odgovor:
The Nokia 445M is an old model, and Nokia no longer manufactures PC
monitors; the user manual is not available.
The brightness setting problem you're experiencing is due in part of a
bad memory chip in the monitor internal circuitry.
| » | Deli za vozilaOddelek: Kaj kupiti | 2463 (2157) | Polanc |
| » | iPad 2 64GB WiFi + 3GOddelek: Pomoč in nasveti | 3358 (2735) | Goran's Blog |
| » | kateri router za cca 100 eur?Oddelek: Kaj kupiti | 4823 (3967) | gregor |
| » | Nadležno predenje diska!!Oddelek: Pomoč in nasveti | 2182 (1830) | ziciko |
| » | Logitech MouseWare bug (?)Oddelek: Pomoč in nasveti | 2595 (2191) | Swiwer |
