Forum » Izdelava spletišč » dreamweaver css poravnava
pino ::
Ne rata mi postavit na sredino strani tale menu. Nebu je css sedaj je poravnan na levo jaz bi pa rad, da je na sredini. Tudi ce dodam kak Item da se postavi na sredino.
Mi lahko kdo vrze uc in pove kak se to naredi.
Hvala
CSS:
@charset "UTF-8";
/* SpryMenuBarVertical.css - Revision: Spry Preview Release 1.4 */
/* Copyright (c) 2006. Adobe Systems Incorporated. All rights reserved. */
LAYOUT INFORMATION: describes box model, positioning, z-order
/* The outermost container of the Menu Bar, a fixed width box with no margin or padding */
ul.MenuBarVertical
margin: 0;
padding: 0;
list-style-type: none;
font-size: 100%;
cursor: default;
width: 8em;
/* Set the active Menu Bar with this class, currently setting z-index to accomodate IE rendering bug: http://therealcrisp.xs4all.nl/meuk/IE-z... */
ul.MenuBarActive
z-index: 1000;
/* Menu item containers, position children relative to this container and are same fixed width as parent */
ul.MenuBarVertical li
margin: 0;
padding: 0;
font-size: 100%;
position: relative;
text-align: left;
cursor: pointer;
width: 8em;
/* Submenus should appear slightly overlapping to the right (95%) and up (-5%) with a higher z-index, but they are initially off the left side of the screen (-1000em) */
ul.MenuBarVertical ul
margin: -5% 0 0 95%;
padding: 0;
font-size: 100%;
position: absolute;
z-index: 1020;
cursor: default;
width: 8.2em;
left: -1000em;
top: 0;
/* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to 0 so it comes onto the screen */
ul.MenuBarVertical ul.MenuBarSubmenuVisible
left: 0;
/* Menu item containers are same fixed width as parent */
ul.MenuBarVertical ul li
width: 8.2em;
DESIGN INFORMATION: describes color scheme, borders, fonts
/* Outermost menu container has borders on all sides */
ul.MenuBarVertical
border: 1px solid #CCC;
/* Submenu containers have borders on all sides */
/* Menu items are a light gray block with padding and no text decoration */
ul.MenuBarVertical a
display: block;
cursor: pointer;
background-color: #EEE;
padding: 0.5em 0.75em;
color: #333;
text-decoration: none;
/* Menu items that have mouse over or focus have a blue background and white text */
ul.MenuBarVertical a:hover, ul.MenuBarVertical a:focus
background-color: #33C;
color: #FFF;
/* Menu items that are open with submenus are set to MenuBarItemHover with a blue background and white text */
ul.MenuBarVertical a.MenuBarItemHover, ul.MenuBarVertical a.MenuBarItemSubmenuHover, ul.MenuBarVertical a.MenuBarSubmenuVisible
color: #FFF;
SUBMENU INDICATION: styles if there is a submenu under a given menu item
/* Menu items that have a submenu have the class designation MenuBarItemSubmenu and are set to use a background image positioned on the far left (95%) and centered vertically (50%) */
background-image: url(SpryMenuBarRight.gif);
background-repeat: no-repeat;
background-position: 95% 50%;
/* Menu items that are open with submenus have the class designation MenuBarItemSubmenuHover and are set to use a "hover" background image positioned on the far left (95%) and centered vertically (50%) */
background-image: url(SpryMenuBarRightHover.gif);
BROWSER HACKS: the hacks below should not be changed unless you are an expert
/* HACK FOR IE: to make sure the sub menus show above form controls, we underlay each submenu with an iframe */
ul.MenuBarVertical iframe
position: absolute;
z-index: 1010;
/* HACK FOR IE: to stabilize appearance of menu items; the slash in float is to keep IE 5.0 from parsing */
@media screen, projection
ul.MenuBarVertical li.MenuBarItemIE
display: inline;
f\loat: left;
background: #FFF;
Hvala
CSS:
@charset "UTF-8";
ul.MenuBarVertical
margin: 0;
padding: 0;
font-size: 100%;
cursor: default;
width: 8em;
ul.MenuBarActive
z-index: 1000;
margin: 0;
padding: 0;
font-size: 100%;
position: relative;
text-align: left;
cursor: pointer;
width: 8em;
padding: 0;
font-size: 100%;
position: absolute;
z-index: 1020;
cursor: default;
width: 8.2em;
left: -1000em;
top: 0;
left: 0;
width: 8.2em;
ul.MenuBarVertical
display: block;
cursor: pointer;
color: #333;
color: #FFF;
color: #FFF;
position: absolute;
z-index: 1010;
display: inline;
f\loat: left;
background: #FFF;
LP Pino
Badboy_ ::
sicer nevem kateri element hočeš poravnati tukaj vendar ponvadi:
naredi svoje.
margin: 0 auto;
naredi svoje.
Seth ::
sicer nisem prebral celega css-ja, ampak sem imel podobne probleme, ki sem jih rešil na za način
ali pa kot je Badboy predlagal
čeprav mi s to zadnjo verzijo včasih ne rata
Mogoče bo težil, da je align="center" outdated. Probaj, če tudi pri tebi to deluje.
<div align="center">neka vsebina</div>
<div style="margin:0 auto"><neka vsebina</div>
Seth
pino ::
Mal sem se matral, delal po nasvetih, pol pa zabrisal dreamweaver dol na novo nalozil pol je pa zagrabu. Hvala za pomoc
LP Pino
shadeX ::
en lep pozdrav.
da nebom odpiral nove teme bom kar tukaj vprašal in sicer. Lepo vas bi prosil, če mi pomagate za sledeč problem. in sicer, igrat sem se začel v dreamweaverju z željo, da bi naredil nekaj zase in tudi v kot prvo eno majhno stran. Ker s htmljem nimam kakšnih velikih izkušenj sem z interneta downloadal free css templates. bil sem kar navdušen, ker stran je praktično narejena, samo še spremeniti je treba besedilo in voila. pa imaš spletno stran :D.. uglavnem moj problem je sledeč. stran je praktično narejena, vendar me zajebavaa pri postavljanju ozadja ( background ) in sicer v photoshopu sem naredil pač lepo sliko in naslov. Nato ko shranim grem v dreamweaver , page properties in izberem ozadje. in to je to. stvar funkcionira DOKLER ne pomanjšam brskalnikovega okna. se pravi use besedilo se premika ko "manjšam in večam" moje brskalnikovo okno vendar moje ozadje se ne. tisti naslov ostane ravno tam kjer je in se ne prilagaja oknu. medtem pa besedilo se do neke mere ( če ne preveč zmanjšam okna ) seveda pazite to.
če uporabim"background position top center;" se celotna stvar premakne v en stolpec. na levi in desni strani pa ostane pač barva ozadja kakršna pač je nastavljena. seveda nato stvar deluje, in ko manjšam in večam okno se slika in naslov tudi prilagajata. vendar to mi ni všeč. oz nisem zadovoljen. rad bi naredil background na tak način kot je tukaj recimo.
http://eu.battle.net/wow/en/
vem da je to enostavno vprašanje za nekoga ki to zna. prosim vas če mi lepo odgovorite na vprašanje, upam pa tudi da sem bil dovolj razumljiv.
lep dan in najlepša hvala.
Tody ::
Tole si poglej
http://www.w3schools.com/css/css_positi...
in tole
http://www.w3schools.com/css/css_backgr...
in tole
| ! | Vse, kar ste si želeli vprašati o CSS, pa si niste upali. (strani: 1 2 3 4 … 23 24 25 26 )Oddelek: Izdelava spletišč | 390333 (7865) | filip007 |
| » | Kako narediti to stran "resposive"?Oddelek: Izdelava spletišč | 1461 (1352) | zzbil |
| » | Prikaz strani na različni resoluciji-JoomlaOddelek: Izdelava spletišč | 2488 (2216) | kr?en |
| » | meni razporejen po celotni dolžiniOddelek: Izdelava spletišč | 3232 (3100) | XzupanX |
| » | [CSS]Pozicioniranje footer divaOddelek: Izdelava spletišč | 3116 (3063) | amaze646 |
