WD My Book World Edition 1 TB "STAND-BY"???
uros86 ::
Pred kratkim sem kupil mrežni disk WD My Book World Edition 1 TB (WDH1NC10000E).
Ter me zanima kje in kako ga nastavim, da bi mi disk ob NE uporabi prešev v stanje STAND-BY torej v stanje mirovanja???
Hvala vsem za pomoč!!!!
sirotka ::
Moj se sam.
Drugač pa:
In the meantime I talked to the german WD support. The person said either the controller-device of the MBWE is brocken or there are network service running. The MBWE responds to any network traffic, why it doesnt go to standy as long traffic is occuring. The support told to use a package sniffer to find LAN clients oder services that cause the traffic.
My first solution (after hours of editing the preferences) is, to go into the advanced Mode and Restore Configuration-Restore Factory Default. It works, but all data are deleted. (but I know then, everything with the hardware is ok)
After that, I saved the configuration-file after every change of preferences.
Then it works fine for 10 days, I transfered data to the drive and the same problem.
Second solution - the itunes-server looks every 5 Minutes (default) for new music. grrrrr so change for "once a day". And think about the Twonkey-Server, too. Try a restart.
And the third solution is a ftp-push-server, which has a problem with my server (only this one, no one else). This server tried to connect the ftp-server of the MBWE2 every 10 Minutes...
Če pa nič ne pomaga, so ga enmu tipu menal in je potem delalo.
Wireless kartica ne deluje na win 7
Oddelek: Omrežja in internet
152346 (2188) kratos
Nov članek: "All your firmware are belong to us" (strani: 1 2 3 )
Oddelek: Novice / Nova vsebina
13820186 (17026) arrigo
connecting own dialling router to siol adsl
92747 (2643) enis
Program za web server?
92858 (2717) Hojne
