[Excel] Gnezdenje več� kot 9 IF stavkov s pomočjo VB kode
adinfinito ::
Torej, zagate so postale ko nisem mogel gnezdit dalje IF stavkov:
=IF(AND(ROWS(A$2:A2)<=$T$9;$R$9="OK");INDEX(INDIRECT("'"&$O$9&"'!$A$6:$H$250");SMALL(IF(NOT(INDIRECT ("'"&$O$9&"'!$H$6:$H$250")="");ROW(INDIRECT("'"&$O$9&"'!$H$6:$H$250"))-ROW(INDIRECT("'"&$O$9&"'!$H$6"))+1);(ROWS(A$2:A2)));1);
IF(AND(ROWS(A$2:A2)<=$T$10;$R$10="OK");INDEX(INDIRECT("'"&$O$10&"'!$A$6:$H$250");SMALL(IF(NOT(INDIRECT("'"&$O$10&"'!$H$6:$H$250")="");ROW(INDIRECT("'"&$O$10&"'!$H$6:$H$250"))-ROW(INDIRECT("'"&$O$10&"'!$H$6"))+1);(ROWS(A$2:A2)-$T$9));1);
IF(AND(ROWS(A$2:A2)<=$T$11;$R$11="OK");INDEX(INDIRECT("'"&$O$11&"'!$A$6:$H$250");SMALL(IF(NOT(INDIRECT("'"&$O$11&"'!$H$6:$H$250")="");ROW(INDIRECT("'"&$O$11&"'!$H$6:$H$250"))-ROW(INDIRECT("'"&$O$11&"'!$H$6"))+1);(ROWS(A$2:A2)-$T$10));1);
Mislim, da boste hitro ugotovili vzorec. Tole zadevo moram gnezdit še najmanj 25 krat, ampak ne gre več kot 3 (oz 6).
Kakšne so ideje za dokončanje tega? Mogoče preko VBA?
Any ideas on how I could get it accomplished? Maybe through VBA?
Upam, da je kdo na tem forumu, ki lahko to "cracka" :)
iggy ::
če moraš tako gnezdit, nekaj delaš narobe
Hey, you're fat!
FlashM ::
hehe, totally agree with that :-)
Simple solutions are usually best!
adinfinito ::
Ni kaj, hitri ste.
Demonstracija problema:
Z listov A B in C hočem imeti postavke ki so označene z x. Te postavke se združijo v listu List z kodo.
List z kodo    SheetA x         Sheet B              Sheet C x           ......
Sheet A R2            Row 1            Row 1                Row 1 x
Sheet A R5            Row 2 x          Row 2                Row 2
Sheet C R1            Row 3            Row 3                Row 3 x
Sheet C R3            Row 4            Row 4                Row 4 x
Sheet C R4            Row 5 x          Row 5                Row 5
Zadeva mora bit dinamična. Če se doda novi list z kategorijami ki jih hočem mora ta prit noter v enoten seznam.
Koda ki sem jo prej prilepil
=IF(AND(ROWS(A$2:A2)<=$T$9;$R$9="OK");INDEX(INDIRECT("'"&$O$9&"'!$A$6:$H$250");SMALL(IF(NOT(INDIRECT("'"&$O$9&"'!$H$6:$H$250")="");ROW(INDIRECT("'"&$O$9&"'!$H$6:$H$250"))-ROW(INDIRECT("'"&$O$9&"'!$H$6"))+1);(ROWS(A$2:A2)));1);
IF(AND(ROWS(A$2:A2)<=$T$11;$R$11="OK");INDEX(INDIRECT("'"&$O$11&"'!$A$6:$H$250");SMALL(IF(NOT(INDIRECT("'"&$O$11&"'!$H$6:$H$250")="");ROW(INDIRECT("'"&$O$11&"'!$H$6:$H$250"))-ROW(INDIRECT("'"&$O$11&"'!$H$6"))+1);(ROWS(A$2:A2)-$T$10));1);"")))
se nadaljuje v spodnji celici tako:
=IF(AND(ROWS(A$2:A3)<=$T$9;$R$9="OK");INDEX(INDIRECT("'"&$O$9&"'!$A$6:$H$250");SMALL(IF(NOT(INDIRECT("'"&$O$9&"'!$H$6:$H$250")="");ROW(INDIRECT("'"&$O$9&"'!$H$6:$H$250"))-ROW(INDIRECT("'"&$O$9&"'!$H$6"))+1);(ROWS(A$2:A3)));1);
IF(AND(ROWS(A$2:A3)<=$T$10;$R$10="OK");INDEX(INDIRECT("'"&$O$10&"'!$A$6:$H$250");SMALL(IF(NOT(INDIRECT("'"&$O$10&"'!$H$6:$H$250")="");ROW(INDIRECT("'"&$O$10&"'!$H$6:$H$250"))-ROW(INDIRECT("'"&$O$10&"'!$H$6"))+1);(ROWS(A$2:A3)-$T$9));1);
IF(AND(ROWS(A$2:A3)<=$T$11;$R$11="OK");INDEX(INDIRECT("'"&$O$11&"'!$A$6:$H$250");SMALL(IF(NOT(INDIRECT("'"&$O$11&"'!$H$6:$H$250")="");ROW(INDIRECT("'"&$O$11&"'!$H$6:$H$250"))-ROW(INDIRECT("'"&$O$11&"'!$H$6"))+1);(ROWS(A$2:A3)-$T$10));1);"")))
[URL="http://i46.tinypic.com/2nl7h9e.jpg"]htt...
Če bi kdo znal rešit moj problem mu lahko tudi dam celoten Excel.
dfajt ::
Zdaj pa, če prav razumem problem.
Imaš nekaj listov (npr. A, B, C, ...) in list, kamor pišeš rezultate.
Če je v vrstici na listu A (B, C, ...) napisan X, potem številko vrstice napišeš med rezultate.
Narediš dve for zanki: eno po listih (A - zadnji list), drugo po vrsticah v tem listu.
Če je v vrstici napisan X, potem vsebino (številko ali kar pač) vrstice vpiši na list z rezultati.
Pri rezultatih povečaj vrstico za ena.
kompleksna števila
Oddelek: Šola
132481 (2159) FrRoSt
Pomoč pri kvadratni f-ji
Oddelek: Šola
101917 (1633) ne_vem
Ekstremalni problem
Oddelek: Šola
152330 (2001) fifika
Excel - datum
72687 (2617) iMark
IP - > numeric???
Oddelek: Omrežja in internet
241805 (1563) deviced
