trdi disk
trdi disk
logarcina ::
torej sm kupu nov komp..
hočm inštalirat windowse xp pa mi napiše sledeče:
problem has been detected and windows has been shut down down..blabla
check for viruses on your computer,remove any newly installed hard driver or hard drive controllers.check your hard drive to make sure it is properly configrated and terminated.
run CHKDSK /F to check for hard drive corruption,and then restart your computer.
pa pol še neki techninal information..
uglavnem,komp je nov,in sicr ta:
http://www.mimovrste.com/artikel/275015...
kdo ve kaj je problem?
huek111 ::
Daj v biosu SATA Native Mode disable
logarcina ::
hm...mam "SATA mode selection..pa mam pol AHCI pa IDE na izbiro... kero zdaj?:D
ej najlepša ti hvala!:D
Need Drivers ALL for laptop
151933 (1407) jan01
Težave pri namestitvi XP
81156 (1087) brdavs
Problem z nalaganjem XP sp2
51712 (1607) bluefish
Instalacija windowsow - problem
Oddelek: Operacijski sistemi
121999 (1603) misek
Nov računalnik, pa noče Windowsov naložiti- izpisuje napako
122248 (2057) Mavrik
