Težave pri namestitvi XP
brdavs ::
Zdravo, pravkar nameščam XP na nov prenosnik.
Preden se setup prične, mi javi tole:
Evo, celoten text:
A problem has been detected and windows has been shut down to prevent demage to your computer.
If this is the first time you`ve seen this stop error screen, restart your computer. If this screen appears again, follow these steps:
Check for viruses on your computer. Remove any newly installed hard drives or hard drive controllers. Check your hard drive to make
sure it is properly configured and terminated. Run CHKDSK /F to check for hard drive corruption, and then restart your computer.
Pomoč?
st0jko ::
visto nalozi! :)
keks?
  • spremenil: st0jko ()
brdavs ::
jebeš visto
SasoS ::
izklopi ahci
brdavs ::
Kaj je to in kje naj to izklopim?
SasoS ::
V biosu pri nastavitvah sata kontrolerja. Škode ne bo nobene.
brdavs ::
Naštimam na IDE?? Kaj sploh je to?
boogie_xlr ::
DA! Na IDE naštimaj, pa instaliraj XP, pa pust kr na IDE, dokler ne boš meu sedmice.
brdavs ::
Evo, naštimano na ide... Mi je uspelo. Hvala.
Kaj sploh je to in kje je razlika med njima?
Problem z diskom : 0x0000007B error
82846 (1895) crayz43
problem
281388 (1099) mariio
Problem z nalaganjem XP sp2
51703 (1598) bluefish
Instalacija windowsow - problem
Oddelek: Operacijski sistemi
121991 (1595) misek
Nov računalnik, pa noče Windowsov naložiti- izpisuje napako
122240 (2049) Mavrik
