Need Drivers ALL for laptop
Gutjerez ::
Prosim če mi kdo pomaga.
Imam tale laptop
Toshiba satellite L355D - S7901
In je naložena gor vista. Jaz pa želim naložiti xpje. pa ni blo zraven nobenega cdja z driveri in nix.
zato lepo prosim če mi lahko kdo najde vse drivere.
Ker za HP in dell ima svojo stran. toshiba pa nima takega principa.. zato nisem našo.
Nikoli ne obupaj, saj je tukaj slo-tech
zee ::
Se hecas?
Tvojega modela sicer eksplicitno ni, vendar pa izberi sorodnega (L350D).
zee
  • spremenilo: zee ()
Just-1n ::
Gutjerez ::
http://www.drivershq.com/Drivers/Toshib...
tu je samo za visto.
jaz rabim za windows XP
zato mi je pa tak hard prave najt :(
zee ::
Povezave do Toshibine strani z gonilniki, ki sem ti jo poslal, kakopak nisi niti pogledal.
zee
Just-1n ::
Gutjerez ::
sem sem pogledo. samo če ni mojega modela. torej kak naj vem da bo drugi model dober?
zee ::
zee
Just-1n ::
Your model belongs to the part-number family PSLE8U, which is the equivalent of the European family PSLE8E.
TEGA ZBER pa nauč se internet uporablat
Gutjerez ::
sedaj sem si downloado vse drivere za xp.
sedaj pa pričetek formatiranja. vstavim xp cd not. grem pod boot nastavim da je št 1 dvd rom št 3 pa hdd. pa lepo se prične windows setup.
samo pol kar naenkrat ko skoraj setup vse naloada mi vrže ven blue screan.
v njem pa piše tole:
A problem has been detected and windows has been shut down to prevent damage to your computer.
If this is the first time you've seen this stop error screen, restart your computer. If this screen appears again, folow these steps:
Check for viruses on your computer. Remove and newly installed hard drives or hard drive controllers. Check your hard drive to make sure it is properly configured and terminated. Run CHKDSK /F to check for hard drive corruption, and then restart your computer.
In zdaj kaj da storim.?
Gor je pa prednaložena vista
Infinity ::
ali v biosu naštimej sata native mode na disable al pa slipstreamej sata driver v xp inštalacijo z nLite-om
Just-1n ::
pa visto rukn dol, nared nove particije za disk... format....
Gutjerez ::
sem dau sada native mode na compatibility. pa zdaj že formatira.
Hvala ti
Just-1n :: danes, 12:19:41
visto sprve želim dol. ker to za mene ni windows. sploh pa ne ta ki je že prednaložen.
mjk ::
Kako lahko nekdo zagovarja XP pred visto na 64bitni novi mašini mi je še vedno uganka.
pač uporabljite 10 let star os :)
P.s.: to da proizvajalci 32bitne viste prednalagajo pa je tako ali tako bedarija.
Gutjerez ::
stvar navade.
Sem imeu xp 32 bitne in 64 bitne. sem meu visto 32 bitno pa 64 bitno
in igram dosti igric zato se lahko vista skrije pred xpjem.
xpji na moji mašini delajo 3x hitreje kot vista 64 bit pa lahko kdor koli kaj pove jaz ne odstopam od xpja.
jan01 ::
@witboy007
Je v laptopu atijeva grafična. Na toshibini strani imajo ponavadi zelo zastarele gonilnke. Zloadej novejše iz atijeve strani
problem
281387 (1098) mariio
Instalacija windowsow - problem
Oddelek: Operacijski sistemi
121989 (1593) misek
Nov računalnik, pa noče Windowsov naložiti- izpisuje napako
122239 (2048) Mavrik
Freedos in windows xp
193019 (2654) kanja
Instalacija XP ne najde diska
416616 (5479) fredyjetle
