Forum » Pomoč in nasveti » Problem z nalaganjem XP sp2
Avantime ::
Pozdravljeni
Kupil sem nov prenosnik, problem se pojavi pri nalaganju windows xp sp2, ko pač boot-a cd in setup loada file se čez čas stvar ustavi in napiše tole.
A problem has been detected and windows has been shut down to prevent damage to your computer.
If this is the first time you've seent this Stop error screen, restart your computer. If this screen appears again, follow these steps:
Check for viruses on your computer. Remove any newly installed hard drives or hard drive controllers. Check your hard drive to make sure it is properly configured and terminated. Run CHKDSK /F to check for hard drive corruption, and then restart your computer.
Technical information:
*** STOP: 0x0000007B (0xF78D2524, 0XC0000034c 0x00000000, 0x00000000)
Prosim za pomoč.
Že vnaprej najlepša hvala.
Prosim za pomoč.
goranzaric ::
Uporabi Windowse z Service pack 3 integriranimi ali pa si jih integriraj sam z programom Nlite
OZZY ::
V biosu prestavi sata controler iz ahci na ide...ali pa integriraj te drajverje v svojo inštalacijo.
Go with the flow.
bluefish ::
Seveda je sploh fino, da je direkten link, do katerega itak ni dostopa. In najbrž se gre za kak XP, ki ima vključene vse popravke in za darilo še malo dodatne nesnage.
| » | Problem z diskom : 0x0000007B errorOddelek: Pomoč in nasveti | 2861 (1910) | crayz43 |
| » | operacijski sistemOddelek: Operacijski sistemi | 1396 (1280) | mtosev |
| » | Instalacija windowsow - problemOddelek: Operacijski sistemi | 1999 (1603) | misek |
| ⊘ | Nov računalnik, pa noče Windowsov naložiti- izpisuje napakoOddelek: Operacijski sistemi | 2248 (2057) | Mavrik |
| » | zelo zelo velik problemOddelek: Operacijski sistemi | 2207 (1795) | schranzek |
