Forum » Zvok in slika » Vprašanje HD-DVD/Blu-Ray Stream Extractor in Arcsoft
kmetek ::
Uporabljam HD-DVD/Blu-Ray Stream Extractor New eac3to GUI: HD-DVD/Blu-Ray Stream Extractor
da extractam zvok DTS in ga konvertira v AC35.1
in mi javi
"The libav DTS decoder doesn't decode the back channels. WHAT THIS MEANS?"
libav can only do DTS 5.1 everything else gets dropped... like the back channel.
if you wanna use the full track you need/should use the Arcsoft decoder.
sedaj imam ta file arcsoft decoder, pa ne vem kam dati fajl....nekaj piše o tem....
making the ArcSoft DTS decoder work in eac3to:
Sometimes the ArcSoft DTS decoder doesn't work even after you've installed the full retail software. This can usually be fixed by manually adding the ArcSoft "Bin" folder (e.g. "C:\Program Files\Common Files\ArcSoft\Bin") to your environment path. If you don't know how to do this, google "environment path".
in mi javi
| » | photoshop alternativaOddelek: Programska oprema | 1627 (1386) | gregor |
| » | tv tuner-gigabyte GT P8000Oddelek: Kaj kupiti | 6354 (5173) | karneki |
| » | Kvaliteta visoke ločjivosti s ploščka DVD (strani: 1 2 )Oddelek: Novice / Grafične kartice | 8844 (6161) | _Enterprise_ |
| » | Predvajanje HD-DVD videa na računalnikuOddelek: Zvok in slika | 1879 (1564) | Revenant |
| » | efekt 'rdece oci' - kako - s katerim programom popraviti digitalno fotografijoOddelek: Zvok in slika | 1695 (1630) | andrej |
