Forum » Pomoč in nasveti » clustersi v Xp
clustersi v Xp
rimljan ::
spremeniti morem clusterse iz 512k na 4k,kje se to spremeni?
spremenil bom iz ntfs na fat 32 po sledečem postopku
You must firstly manually decompress all compressed objects on the partition. If you try this with Explorer you will find yourself looking for needles in the haystack The best way to achieve this is to follow the instructions at Powerquest (hidden in the site's depths, as is usual for all useful information from Powerquest) at <http://www.powerquest.com/support/primu... Here they suggest issuing the following command at the XP Command Prompt from the root folder of the partition in question: COMPACT /U /S /I /F *.*
c) Now Partition Magic should allow you to convert to FAT32.
d) Having got back to FAT32 you will probably find that you have a FAT32 cluster size of 512K (it will maintain the original NTFS cluster size). You must change it to 4K. (Advanced -> Resize clusters). If you don't do this then when converting back to NTFS, MS 'convert' will assume that you want to maintain your previous cluster size.
| » | kako razsiriti datoteko večjo od 4gb?Oddelek: Pomoč in nasveti | 1705 (1705) | Mr.B |
| » | Formatiranje diska v FAT32Oddelek: Strojna oprema | 4187 (4011) | Redorange |
| » | trdi disk hitachiOddelek: Strojna oprema | 2526 (2161) | kerrigh |
| » | Zakaj mi ne ponudi opcije formatiranja v FAT32 ?Oddelek: Pomoč in nasveti | 1563 (1484) | sinko999 |
| » | Clusters v Partition Magic?Oddelek: Pomoč in nasveti | 1579 (1504) | R@C@ |
