XBOX unhackable box?Ja baje!
Clemento ::
Nekje sem prebral da je ena skupina razbila zaščito za XBOX in relasala 21spilov!Sweet!!:)) Fak ju Bill!klik ce ne verjamete!
z X power naprej!!!:P
*Epox 8rda+, XP2600+@stock speed, TT Silent Boost, AS5, Ati AH3650
*Abit NF7-S, XP2500+@2425Mhz, 1.85V(220x11), TT Volcano 12, AS5, Rage128PRO
  • spremenil: Clemento ()
andrej ::
da ni to se en internetni nateg. Na strani pise, da so spile dali na navadni CD-R. hja right. In potem svizec na CD-R da vec kot 4 GB podatkov in zavije...:P
ChiefThunder ::
ja, sej so jih zazipal... :)
... po liniji najmanjšega odpora. ;)
||_^_|| ::
Evo:
X-BOX backups released (?)
Saturday, 4 May 2002
There has been rumours about it and finally here it is. Several XBox games have been ripped and released into the undergroup scene. A group called ProjectX claims they will play in developer Xbox's only for now until someone releases modchips...
As the released .nfo file said:
"...We tested this game on a developer XBOX, and it works. Since there is no mod chip yet, we have no idea if this release will work on retail XBOXes when/if a mod comes out. However, now that there is a release, a modchip developer will be inclined to get our releases to work, so we think a future mod will work with this release.
If a game is small enough to be burned to a CD, you can burn it to either a CD or DVD, at your option, using the same ISO file. The Xbox does not use media checks like the PS2.
When burning to a CD, if your CD burning program has an option, choose "MODE1/2048", exactly as if you were burning a PC CD-ROM. We recommend PrimoDVD for burning Xbox for both CD and DVD, but all CD writing software besides Clone CD should work fine.From our experience, the retail Xbox can only read DVD-RW's and CD-RW's, so if you want to be sure that these will work with a future mod, we recommend burning them to Rewritable discs. We have heard reports of the retail Xbox reading some types of DVD-R discs, but we have been unable to verify this..."
tuki
Clemento ::
Zakaj pa ne?
Clemento ::
Heheheheh!!!49 iger je ze zunaj!!!
poglejte na wwwi.isonews.com!!!!!!
Pa tudi evropski hwckweji;) so ze zaceli
relesat pal igre!Cas za nabavo?:P
Kaj pomeni ˇmountej
63276 (3212) Kami
Novi IBM-ov superračunalnik
267454 (6482) Monster
Resne težave s Win XP!!?
222361 (1846) alyF
Whitler (strani: 1 2 3 )
Oddelek: Operacijski sistemi
10910088 (8530) zetko
