T2 težave
T2 težave
1024 ::
Zdravo!
Od kar sem prešaltal na T2 imam strašne probleme z internetom. Prej sem imel siol in ni blo problemov. Enako hitra linija kot prej - 1mbit. T2 pravi da je vse ok, čeprav ni!
ping google.com -t
Pinging google.com [64.233.187.99] with 32 bytes of data:
Request timed out.
Reply from 64.233.187.99: bytes=32 time=946ms TTL=235
Reply from 64.233.187.99: bytes=32 time=978ms TTL=235
Request timed out.
Request timed out.
Reply from 64.233.187.99: bytes=32 time=858ms TTL=235
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 64.233.187.99: bytes=32 time=1052ms TTL=235
Reply from 64.233.187.99: bytes=32 time=1024ms TTL=235
Reply from 64.233.187.99: bytes=32 time=1039ms TTL=235
Reply from 64.233.187.99: bytes=32 time=1017ms TTL=235
Request timed out.
Request timed out.
Reply from 64.233.187.99: bytes=32 time=986ms TTL=235
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 64.233.187.99: bytes=32 time=870ms TTL=235
Request timed out.
Request timed out.
Reply from 64.233.187.99: bytes=32 time=844ms TTL=235
Reply from 64.233.187.99: bytes=32 time=887ms TTL=235
Reply from 64.233.187.99: bytes=32 time=912ms TTL=235
Reply from 64.233.187.99: bytes=32 time=972ms TTL=235
Reply from 64.233.187.99: bytes=32 time=992ms TTL=235
Reply from 64.233.187.99: bytes=32 time=1003ms TTL=235
Reply from 64.233.187.99: bytes=32 time=1011ms TTL=235
Reply from 64.233.187.99: bytes=32 time=1055ms TTL=235
Reply from 64.233.187.99: bytes=32 time=1034ms TTL=235
Request timed out.
Reply from 64.233.187.99: bytes=32 time=970ms TTL=235
Reply from 64.233.187.99: bytes=32 time=987ms TTL=235
Request timed out.
Reply from 64.233.187.99: bytes=32 time=696ms TTL=235
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 64.233.187.99: bytes=32 time=904ms TTL=235
Reply from 64.233.187.99: bytes=32 time=914ms TTL=235
Reply from 64.233.187.99: bytes=32 time=969ms TTL=235
Request timed out.
Reply from 64.233.187.99: bytes=32 time=829ms TTL=235
Reply from 64.233.187.99: bytes=32 time=676ms TTL=235
Reply from 64.233.187.99: bytes=32 time=715ms TTL=235
Request timed out.
Reply from 64.233.187.99: bytes=32 time=922ms TTL=235
Request timed out.
Reply from 64.233.187.99: bytes=32 time=1118ms TTL=235
Request timed out.
Request timed out.
Reply from 64.233.187.99: bytes=32 time=1012ms TTL=235
Request timed out.
Reply from 64.233.187.99: bytes=32 time=724ms TTL=235
Reply from 64.233.187.99: bytes=32 time=780ms TTL=235
Reply from 64.233.187.99: bytes=32 time=805ms TTL=235
Reply from 64.233.187.99: bytes=32 time=841ms TTL=235
Request timed out.
Reply from 64.233.187.99: bytes=32 time=1048ms TTL=235
Reply from 64.233.187.99: bytes=32 time=1043ms TTL=235
Request timed out.
Reply from 64.233.187.99: bytes=32 time=796ms TTL=235
Request timed out.
Reply from 64.233.187.99: bytes=32 time=998ms TTL=235
Reply from 64.233.187.99: bytes=32 time=1036ms TTL=235
Reply from 64.233.187.99: bytes=32 time=1010ms TTL=235
Reply from 64.233.187.99: bytes=32 time=1009ms TTL=235
Reply from 64.233.187.99: bytes=32 time=1065ms TTL=235
Request timed out.
Reply from 64.233.187.99: bytes=32 time=838ms TTL=235
Reply from 64.233.187.99: bytes=32 time=861ms TTL=235
Reply from 64.233.187.99: bytes=32 time=885ms TTL=235
Reply from 64.233.187.99: bytes=32 time=924ms TTL=235
Reply from 64.233.187.99: bytes=32 time=974ms TTL=235
Request timed out.
Reply from 64.233.187.99: bytes=32 time=674ms TTL=235
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 64.233.187.99: bytes=32 time=1089ms TTL=235
Reply from 64.233.187.99: bytes=32 time=1049ms TTL=235
Reply from 64.233.187.99: bytes=32 time=1022ms TTL=235
Request timed out.
Reply from 64.233.187.99: bytes=32 time=874ms TTL=235
Request timed out.
Request timed out.
Reply from 64.233.187.99: bytes=32 time=710ms TTL=235
Request timed out.
Reply from 64.233.187.99: bytes=32 time=920ms TTL=235
Reply from 64.233.187.99: bytes=32 time=950ms TTL=235
Reply from 64.233.187.99: bytes=32 time=989ms TTL=235
Reply from 64.233.187.99: bytes=32 time=1029ms TTL=235
Reply from 64.233.187.99: bytes=32 time=1018ms TTL=235
Request timed out.
Reply from 64.233.187.99: bytes=32 time=740ms TTL=235
Request timed out.
Reply from 64.233.187.99: bytes=32 time=155ms TTL=235 !!!!!!!!!!! za trenutek normalno
Reply from 64.233.187.99: bytes=32 time=160ms TTL=235
Reply from 64.233.187.99: bytes=32 time=156ms TTL=235
Reply from 64.233.187.99: bytes=32 time=163ms TTL=235
Reply from 64.233.187.99: bytes=32 time=154ms TTL=235
Reply from 64.233.187.99: bytes=32 time=168ms TTL=235
Reply from 64.233.187.99: bytes=32 time=726ms TTL=235
Reply from 64.233.187.99: bytes=32 time=1074ms TTL=235
Request timed out.
Reply from 64.233.187.99: bytes=32 time=1063ms TTL=235
Request timed out.
Reply from 64.233.187.99: bytes=32 time=738ms TTL=235
Reply from 64.233.187.99: bytes=32 time=777ms TTL=235
Reply from 64.233.187.99: bytes=32 time=816ms TTL=235
Reply from 64.233.187.99: bytes=32 time=840ms TTL=235
Reply from 64.233.187.99: bytes=32 time=879ms TTL=235
Request timed out.
Request timed out.
Ping statistics for 64.233.187.99:
Packets: Sent = 171, Received = 123, Lost = 48 (28% loss),
Approximate round trip times in milli-seconds:
Minimum = 154ms, Maximum = 1118ms, Average = 679ms
Control-C
^C
Fish knows everything.
c0dehunter ::
Torej je problem. Pošlji jim ta log.
Ali pa je z tvojim računalnikom nekaj narobe, oziroma ti je programska oprema nekaj zjeb4la.
I do not agree with what you have to say,
but I'll defend to the death your right to say it.
blackbfm ::
kabli, router, modem, operacijski sistem, kabel/wireless..vse to vpliva. Potem pa testiraj enega po enega da vidiš kje je problem. Mogoče je kakšna žička za zamenjat v omarci.
ERGY ::
Kaj ce bi prvo preden vrzes nekaj takega pogledal kaki mas ping do prvega noda.
markk1 ::
direktno na modem priklopi, če imaš slučajno zadaj router, če ne pa teži na HD2 da ti uredijo stvari.
Router zviša ping???
Oddelek: Omrežja in internet
382914 (2025) bzp
Razočaran nad T-2 in njihovim supportom =(
192750 (1720) Wox
Volja ADSL in Windows XP - problem
92420 (2154) janez5
WTF Google dol padu??
231901 (1146) AndrejS
Internet dela pocas ko zelva tetraplegik ... kablasi?!?
112357 (2179) OrlyTM
