Forum » Omrežja in internet » Internet dela pocas ko zelva tetraplegik ... kablasi?!?
OrlyTM ::
Mislm, tole je pa ze rahlo tu mac ...
ze par dni mi net dela spet ko bolan srat
evo:
[quote] Pinging hestija.siol.net [193.189.160.170] with 32 bytes of data:
Request timed out.
Reply from 193.189.160.170: bytes=32 time=2003ms TTL=122
Reply from 193.189.160.170: bytes=32 time=2010ms TTL=122
Reply from 193.189.160.170: bytes=32 time=2486ms TTL=122
Reply from 193.189.160.170: bytes=32 time=2359ms TTL=122
Reply from 193.189.160.170: bytes=32 time=2667ms TTL=122
Reply from 193.189.160.170: bytes=32 time=2289ms TTL=122
Reply from 193.189.160.170: bytes=32 time=2094ms TTL=122
Reply from 193.189.160.170: bytes=32 time=2650ms TTL=122
Reply from 193.189.160.170: bytes=32 time=2412ms TTL=122
Reply from 193.189.160.170: bytes=32 time=1888ms TTL=122
Reply from 193.189.160.170: bytes=32 time=2228ms TTL=122
Reply from 193.189.160.170: bytes=32 time=2410ms TTL=122
Reply from 193.189.160.170: bytes=32 time=2579ms TTL=122
Reply from 193.189.160.170: bytes=32 time=2199ms TTL=122
Reply from 193.189.160.170: bytes=32 time=2755ms TTL=122
Reply from 193.189.160.170: bytes=32 time=2606ms TTL=122
Reply from 193.189.160.170: bytes=32 time=1786ms TTL=122
Reply from 193.189.160.170: bytes=32 time=2139ms TTL=122
Reply from 193.189.160.170: bytes=32 time=1366ms TTL=122
Ping statistics for 193.189.160.170:
Packets: Sent = 20, Received = 19, Lost = 1 (5% loss),
Approximate round trip times in milli-seconds:
Minimum = 1366ms, Maximum = 2755ms, Average = 2259ms [/quote]
[quote] Pinging poluks.s5.net [195.246.0.225] with 32 bytes of data:
Reply from 195.246.0.2: Destination net unreachable.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 195.246.0.225:
Packets: Sent = 20, Received = 16, Lost = 4 (20% loss),
Minimum = 0ms, Maximum = 0ms, Average = 0ms [/quote]
in
[quote] Pinging [url=http://www.g-kabel.si]www.g-kabel.si[/u... [193.189.173.125] with 32 bytes of data:
Reply from 193.189.173.125: bytes=32 time=2285ms TTL=57
Reply from 193.189.173.125: bytes=32 time=1843ms TTL=57
Reply from 193.189.173.125: bytes=32 time=1637ms TTL=57
Reply from 193.189.173.125: bytes=32 time=2006ms TTL=57
Reply from 193.189.173.125: bytes=32 time=1905ms TTL=57
Reply from 193.189.173.125: bytes=32 time=2480ms TTL=57
Reply from 193.189.173.125: bytes=32 time=2875ms TTL=57
Reply from 193.189.173.125: bytes=32 time=3056ms TTL=57
Reply from 193.189.173.125: bytes=32 time=2013ms TTL=57
Reply from 193.189.173.125: bytes=32 time=2491ms TTL=57
Reply from 193.189.173.125: bytes=32 time=2184ms TTL=57
Reply from 193.189.173.125: bytes=32 time=2540ms TTL=57
Reply from 193.189.173.125: bytes=32 time=2882ms TTL=57
Reply from 193.189.173.125: bytes=32 time=3358ms TTL=57
Reply from 193.189.173.125: bytes=32 time=2612ms TTL=57
Reply from 193.189.173.125: bytes=32 time=3025ms TTL=57
Reply from 193.189.173.125: bytes=32 time=2584ms TTL=57
Reply from 193.189.173.125: bytes=32 time=2939ms TTL=57
Reply from 193.189.173.125: bytes=32 time=2581ms TTL=57
Reply from 193.189.173.125: bytes=32 time=2996ms TTL=57
Ping statistics for 193.189.173.125:
Packets: Sent = 20, Received = 20, Lost = 0 (0% loss),
Minimum = 1637ms, Maximum = 3358ms, Average = 2514ms [/quote]
mislm, tole ni smesno vec spljoh
a to vam tut dogaja, al sam men?!?! prkloplen sm pa prek s5.net na g-kablu ...
a ADSL dela?
OrlyTM
evo:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
in
a ADSL dela?
OrlyTM
<b>Fear is in The Eye Of The Beholder. Don't let it be You!</b>
Matty ::
orly... ne vem kdaj so se zaceli problemi, vendar v nedeljo zvecer je se delal siol (preko g-kabla) odlicno...
(s tem da sem en mesec nazaj parkrat popenil, ko je kazalo IPconflicte cirka 2 tedna, oni pa niso nic ustimali)
OrlyTM ::
a pol zele tut teb ne dela, a ti dela bp?
OrlyTM
OrlyTM
Matty ::
ta trenutek nimam pojma, ker sem v sluzbi... je pa definitivno delalo vceraj, cez vikend... pravzaprav zadnje 2-3 tedne dela totalno brez problema...
Pingov nisem sprobaval, je pa delalo spodobno hitro... (npr. download s serverja www.anzecokl.com okoli 100Kb/s)
OrlyTM ::
a kdo ve cifro, na kero klices za tezave z s5.net connectionom prek g-kabla? ...
nism se nikol klicov, na njihovmu sajtu pa tut ni nc najdet ...
na g-kablu pa itq delajo sam do 3h :( al ze kej vec?
OrlyTM
OrlyTM
eee ::
kes it Orly ;)
no ker si ravno ti in si načel meni sorodno temo, si me prisilil, da se po nekaj letih zopet logiram v tale ZbiralnikVprašanj(tm)
ja, meni je delal 1 mesec super, včeraj 7.aprila okoli enih zjutrej pa je začel morit...
Packets: Sent = 100, Received = 71, Lost = 29 (29% loss),
Minimum = 6ms, Maximum = 847ms, Average = 141ms
gre predvsem za prekinjanje hitrosti, šopa, šopa, potlej jo pa nekej zabije skoraj na nulo in to dela še zdej...
o pingu pa sploh ne bom govoril
jap...tut men net bl slabo dela zadne par dni...sigurn ma Siol ksne prste umes (zato da cism vec folka naserje za adsl 4 sit)
isp je telemach.
isp je telemach.
Azrael ::
Orly, kaj bi rekel, meni tudi dela tako v intervalih, včasih hitro, potem pa bolj počasi, se lepo vidi pri DL, ko sem pingal g-kabel.si je bil rezultat od 67 ms do 1127 ms, povprečje 717 ms, pri drugih straneh ni posebne razlike.
ISP Perftech S5net, okolica Bleda.
Mogoče je tale številka ( Vir)
080 3236
PODPORA UPORABNIKOM
PERFTECH D.O.O., BLED
LP, Azrael
080 3236
PODPORA UPORABNIKOM
LP, Azrael
Nekoč je bil Slo-tech.
Sydk ::
Ja tole kar se dogaja že nekej časa je ena velika nategancija, itak, samo da nas zbašejo na adsl, tut sam sm na s5.netu preko tega g-kabla
mene zanima kake imate kej prenose, kake 2 mesca nazaj sem imel se 100kb/s max DL, zdej imam nekej casa samo se 60kb/s, kar je dost mal!¨
se spomnim nekaj let nazaj je slo prek 400kb/s
a je to normaln da gre s samo 60?
OrlyTM ::
no, pa ste se le oglasl :) ...
torej nism sam ... sm ze vse zivo cekiral ... demet :) .. dc++ in torrent mi sicer nabijata pinge ampak kadar net dela OK, ni tok opazno spljoh, vcasih ga pa zabije, da mam filing, ko bi spet 14400 furov :grrr:
Azrael car ... bom kuj jutr klicov kaj dogaja
Sydk: jah ... zadnjic sm neki brsku kako zgleda rec pr prftechu in se mi zdi, da sm nek zasledu, da mamo max link 756kbit ... to je kr neki
frend ma na telemachu poln megabit, cesar pr s5.net sploh ni v opciji ... hvaljo se z novmi modemi (tak siv thompson) k nej bi vlekl 27mega ... pa kaj k**** ti nuca tak modem, ce ti ga zaprejo na 756k ?!? ...
krneki ... se mal ga bojo tkole sral, bomo se res presaltal na adsl ... pingi so itq boljsi, pa tut 8mbit link mi precej disi ...
dejte mal se vi poklicat, ce misljo kej pipe odpret al kaj ... jst bi gladko bil prpravlen placat vec, za konkretn link!
ORlyTM
ORlyTM
eee ::
dobro jutro orly...
no enivej men se je stanje normaliziralo včeraj ob ene 00.00. kar pomeni, da se mi je to dogajal 24 ur...
zej zopet dela ql, pingi so spet ibr ql, s prenosi se ne bom hvalu (orly saj sem ti jih enkat že pokazal ;))...
nevem, jest sem bil dolgo časa zagovornik adsla in siola, češ, kar plačaš dobiš...
vendar pa živim v kraju kjer daleč naokoli nima noben kabelskega neta in jaz poberem ves bandwidth (čeprov je kao zaklenjen) tako da sem več kot zadovoljen s telemahom...
upam, da bodo počasi celovito upgrejdali njihovo infrastrukturo, kajti čene jih bo VDSL povozil...
OrlyTM ::
NO ... morm rect, da se je tut men mal stanje normaliziralo ... pingi so sicer se vedno bolj bogi, ko mam vklopljen DC++ in TorrentStorm ... sam inet je precej bolj odziven ... se da cist normalno surfat ... prej pak ne ...
zgleda so mel res eno sranje.
OrlyTM
OrlyTM
| » | Visoki pingi Siol ADSL 1024/256 (strani: 1 2 3 )Oddelek: Omrežja in internet | 20727 (17306) | Alexius Heristalski |
| » | Preveliki pingi (strani: 1 2 )Oddelek: Omrežja in internet | 12249 (11656) | [L4M3RZ] - TinLaDeN |
| » | Samomor?Oddelek: Omrežja in internet | 2524 (2271) | Hux |
| » | Pingi in ADSLOddelek: Omrežja in internet | 4647 (4009) | matter |
| » | ADSL vs kabelOddelek: Omrežja in internet | 3200 (2419) | Jinxy |
