Forum » Konzole » Vse o Xbox 360
Vse o Xbox 360
Davodax ::
Imam ful problem. XBox mi noče potrdit DNS-ja ko se hočem povezat na net preko PC-ja (connection sharing)
HELP
HELP
nekje sn prebral da Japsterji crkujejo. je to res?
bo kaj?
destroyer2k ::
mtosev
Ja logično da crkujejo, saj vsaka stvar se pokvari. Drugače pa okoli 3-5% se pa pokvari ta verzija.
da prepogosto crkujejo. rrod naj bi bilo dosti na japsterjih. zato me zanima.
lowac ::
Meni pa ne in ne uspe povezat XBOX360 z prenosnikom (preko mreže seveda), da bi lahko sharal video.
Naredil sem že popolnoma vse mogoče in še vedno mi piše PC Not Listed.
Kao, da ga ne najde. Spomnim se pa, da mi je enkrat to že uspelo vendar 2-3x formatiranja OS nazaj...
Imam pa Windows XP Professional, Version 2002, Service Pack 3.
Poskusil sem z raznimi vodiči za reševanje tega problema in mi ni uspelo.
Npr:
This may fix you up.
Goto Control Panel => Administratve Tools => Services
Start SSDP Discovery Service
Start Universal Plug and Play Device Host Service
(To start up a service just double-click on it, set Startup Type to Automatic, and click on the Startup Button)
You should then find that WMP11 Media Sharing will turn on and discover your Xbox. Let us know how it goes.
Ok this is not an issue with a firewall, it took me 3 calls and about 12
transfers to get an answer. For phone help dial 1800-4MY-XBOX then get to
live console help and ask to speak to the hardware department. Describe
issue, most likely will get transferred a couple times till you end up back
at the hardware depart, let them know its a pc failed message. They can walk
you through it.
Its basically a DRM (data rights management) problem. Steps to fix are as
followed:
Click start, go to run
type services.msc
go to Windows Media Player Network Sharing Service
double click it and hit stop
then you will need to be able to see all hidden files and folders:
Open my computer window, and click on the tools tab at the top and select
folder options, and click the view tab
Scroll down make sure show hidden files and folders is shown
then scroll further down and uncheck hide protected operating system
files(recommended)
then you must delete the DRM files in Windows Media center folder:
Click on My Computer, choose your harddrive (usually C:) click on documents
and settings folder, then All Users Folder, and you should see DRM folder
Double click DRM folder
Control and a to select all the files, then shift delete (to skip sending to
the recycle bin), then hit yes, now close this window
Go back to run, type services.msc and highlight Windows Media Player Network
Sharing Services and right click and select start, this should fix the
problem varify you are still sharing the connection via windows media player,
library tab, share media option, and that it still sees your xbox,
restart xbox: go to media tab and select music, choose computer it should
now search and (yes finally) find your computer
Have a nice day
-Alex
Tale zadnji vodič (od Alex-a) sem mislim, da mi bo res rešil problem ampak ga ni.
Xbox se mi drugače čist normalno poveže na XBOX Live, tako da res nevem več v čem je problem...
ČE IMA KDO ŠE KAKRŠNO KOLI IDEJO, NAJ MI PROSIM NAPIŠE.
HVALA LEPA!
In vse je bilo tiho. :|
Npr:
you through it.
followed:
type services.msc
files(recommended)
Have a nice day
-Alex
HVALA LEPA!
- spremenil: lowac ()
lowac ::
:)) Js jih mam okrog 4000 pa še zj nevem zakaj mi glih koristijo
BoruT81 ::
Eno vprašanje imam.....lahko, da se je kje že o tem govorilo, vendar imam zelo malo časa, ker moram predati Xbox kot darilo......če mi lahko kdo pove postopek, kako posneti igro iz dvd-ja na disk (XBOX 360 premium)?
Za odgovor bi bil res neizmerno hvaležen
Lep pozdrav
Lep pozdrav
sbap27 ::
Ce rabi kdo kaj iz Anglije naj napise kak spil,konzolo,ali kaj podobnega grem v nedeljo gor.
lowac ::
sbap27 kolk so pa kaj HDD (diski) za XBOX360 gor?
60GB al pa 120GB?
Ker js mam Arcade in bi rabil disk...
Pri nas so okrog 75€ -> 60GB diski -> http://www.bolha.com/oglas382474310/xbo...
Kolk so le tam?
60GB al pa 120GB?
Kolk so le tam?
Mavrik ::
A nismo rekli da pogovori o piratskih igrah in izogibanju banu ne bodo tolerirani?
T_F_7 ::
zakaj mi meče datum nazaj na 2005? naštimam datum na današnji dan in ko ugasnem konzolo in naslednjič vžgem je spet 2005???
sbap27 ::
nevem kejk je kaj lahko ti pa sporocim ko pridem do kaksne trgovine bom ti napiso na zs v ponedeljek al pa torek
- spremenil: sbap27 ()
metek ::
baje se da na compu narest particijo za xbox 360 samo 30 gig na you tube mislm da sm vidu na xp in visti
metek ::
če bi rad igral igre iz diska utakneš not original in jo s Y gumbom inštaliraš na disk samo je brez original dvd-ja ne boš mogu igrat (licenčna kopija)
laught ::
Ja igram ja sam ne vsega,pa me zanima zakaj je to sploh?ker ene igre ko sploh nimajo mpja se morjo updatat.
lowac ::
Mene pa zanima ker pogon je boljši, tišji, hitrejši itd.
Samsung ali Lite-On ?
Ker jaz imam sedaj samsung-a, lite-on pa shranjenega novega v omari..
A resno kdo kupuje po teh cenah?
http://www.playgame.biz/index.php?pojdi...
Ta izjava pa zmaga:
"Konzola ima 3 mesece polne garancije in je regijsko odklenjena,bere dual layer dvd!"
Kot da bi prodajalec avtomobilov napisal: "avto ima štiri kolesa".
EDIT: add.
Ta izjava pa zmaga:
EDIT: add.
- spremenil: c3p0 ()
Keyser Soze ::
Upajmo da ne. Ker edino tako se loči pleve od semena. Pustiš da propade in to je to.
Iskreno rečeno, ne pomnim časa, ko bi bil tale .biz cenovno ugoden. Zgolj grdo izkorišča "monopol" (katerega že dolgo ni več).
OM, F, G!
lowac ::
T F 7 men se tud zdi ja...
Na začetku sem imel še Liteon in se mi je zdel glasnejši kot sedaj ta Samsung katerega mam notr...
Ampak to je ze pol leta nazaj tako se nism čist spomnil..
Kul potem... tnx!
Kul potem... tnx!
Mavrik ::
A nisem že zdavnaj rekel da o odklenjenih konzolah tukaj ne bo?
T_F_7 ::
a ve kdo kje lahko tole dobim:
upam, da je prava slika, torej adapter(vezni element?) za zvok, na eni strani za vtaknit 2x RCA od konzolinega kabla, na drugi strani pa 'bananco' od zvočnikov???
Vprašau sem v ComShopu pa niso imeli. Kje se torej zadevica dobi???
- spremenil: T_F_7 ()
T_F_7 ::
V bigbangu in vseh dobro zalozenih trgovinah
za spremembo se ComShop ni izkazau za tako
Torej bo ta adapter zagotovo prenesel zvok iz konzole na zvočnike???
Ne vem namreč, če sem pravo stvar našel...???
T_F_7 ::
kabel je tisti, ki ga dobiš zraven konzole. zvočnike imam tele:
http://www.acesuppliers.com/Supplier_Co...
mislil sem da gre kabel namesto v pc v ta adapter z druge strani pa tista 2 od kabla od konzole. upam, da se razume, ne spoznam se na to neki preveč
Mavrik ::
O tem smo že tule večkrat pisali. Tega ne smeš iti iskat v trgovine z računalniki, ampak v trgovine z avdio opremo. Rabiš ženski 2x činč -- ženska banana adapter.
T_F_7 ::
ok, tnx. vem da smo pisali samo ni mi bilo jasno kaj morm iskat in kje se to dobi, zdej vem, bom šou u big bang v btc pogledat.
lowac ::
T F 7 kot vidim si iz Ljubljane.. pojdi raje v Techtrade (čist blizu hotela Lev).
Cenejše in kvalitetnejše boš dobil po moje v TT.
T_F_7 ::
študiram v lj, samo TT je bolj računalniška trgovina, tako da je manjša verjetnost, da tam dobim, morm prečekirat spletno stran, tnx.
T_F_7 ::
sm bil pravkar v Big Bangu, GA, ComShopu, Konradu in Tech Tradeu in nikjer nimajo 2x ženski činč - ženska banana adapter. Edino kar imajo je 2x ženski činč - moška banana adapter, sem iskal potem še obojestranski ženski banana adapter, da bi kombiniral oba skupaj, vendar nimajo niti tega. Kje bi se še dalo dobit to čudo??? Morda kje preko spleta???
Mavrik ::
Jaz sem tak adapter dobil sicer pri zvočnikih, drugače pa sem še enega naredil tako, da sem dobo 2x moški činč -- ženska banana adapter ter potem dva ženski činč - ženski činč adapterja. To mi je dejansko uspelo oboje v BB dobiti.
T_F_7 ::
hmmm iz 3 si naredu enega, samo problem je dobiti te ženske adapterje, povsod so mi rekli da imajo samo moške, že 2x moški činč -- ženska banana je težko dobit kaj šele ženski činč - ženski činč...
T_F_7 ::
kaj pa prek pcja se da zadevo zrihtat? sm razmišljau, da bi šlo iz konzole v ohišje in iz ohišja v zvočnike, potem bi rabil samo 2x ženski činč - moška banana adapter za iz konzole v ohišje. Je to izvedljivo???
ps: zaenkrat sem našel tole: http://www.nakupovanje.net/BANDRIDGE-RC... iščem še tistega ta drugega, upam da ga bom kje dobil...
Mavrik ::
Tisto se ti ne splača, preveč komplikacij ter izgube kvalitete. Raje pojdi težit v audio trgovine naj ti ta kabel naročijo ker to ni nobena umetnost.
T_F_7 ::
ne verjamem, da mi bojo naročili adapter ali kabel, ki je vreden zgolj nekaj €
nikjer ne najdem 3,5mm ženski adapter ali kabel, neverjetno. činč ženski se dobi, banana ženski pa ni šanse.
kaj ta varjanta preko pcja je pol izvedljiva? rajši to kot pa brez zvoka.
kaj iz konzole kabel v adapter in adapter dam v vhod za mikrofon na pcju in zvočnike v vhod za zvočnike? ali sem povedau eno veliko glupost?
fosil ::
Pojdi pogledat v trgovino HTE
Načelno so sicer specializirani za elektroniko ampak majo čuda enih konektorjev. V primerjavi z njimi so techtrade, big bang in podobni pravi amaterji.
Tako je!
lowac ::
T_F_7 :: včeraj, 14:51:17
citiraj
Tam boš ziher dobil, verjem. Prej kot kjer koli drugje kjer si bil..
citiraj
| » | [XBOX 360] Nasveti (strani: 1 2 3 4 … 17 18 19 20 )Oddelek: Konzole | 227824 (104997) | radovednik |
| » | [Xbox 360] Nasveti za nakup (strani: 1 2 )Oddelek: Konzole | 11771 (9135) | GLAVNI |
| » | XboX 360 Premium ali XboxX 360 Elite? (strani: 1 2 )Oddelek: Konzole | 9586 (8066) | Dr_Andy |
| » | Xbox 360 premium nasveti (strani: 1 2 )Oddelek: Konzole | 8935 (6637) | brecoboy |
| » | Nakup Xboxa 360Oddelek: Konzole | 3499 (2474) | fosil |
