Forum » Igre » Problem z zagonom iger RTCW in MOHAA
megane ::
Prijatelj ima problem z zagonom iger Return to Castle Wolfenstein in Medal of Honor... RTCW mu je po inštalaciji delovala normalno igral jo je več kot en teden nato pa mu je igra kar na lepem crknila. Medtem ko mu je MOHAA pa že po inštalacija izpisala spodaj navedene parametre v oknu.
Vsakič ko poskuša zagnati obe igri se mu na zaslonu pojavi okno z spodnjimi obrazložitvami. Igri ne more zagnati niti v načinu Safe Mode. Posodobila sva gonilnike v 28.32 , reinštalirali obe igri a ni pomagalo nič.
Ne vem kaj naj še narediva. Prosimo vas na kdo pomaga.
ps: sistem:
AMD DURON 1000
ABIT Siluro T400(GeForce 2MX 400)
Gygbyte VIA KT 266A
256MB DDR RAM
Windows 98 SE
RTCW
GLW_StartOpenGL() - could not load OpenGL subsystem
Wolf 1.0.0 win-x86 Nov 13 2001
----- FS_Startup -----
Current search path:
D:\Program Files\Games\Return to Castle Wolfenstein\main\sp_pak2.pk3 (232 files)
D:\Program Files\Games\Return to Castle Wolfenstein\main\sp_pak1.pk3 (1342 files)
D:\Program Files\Games\Return to Castle Wolfenstein\main\pak0.pk3 (4775 files)
D:\Program Files\Games\Return to Castle Wolfenstein/main
6349 files in pk3 files
execing default.cfg
couldn't exec language.cfg
execing wolfconfig.cfg
execing autoexec.cfg
Hunk_Clear: reset the hunk ok
...detecting CPU, found AMD w/ 3DNow!
Bypassing CD checks
----- Client Initialization -----
Cmd_AddCommand: map_restart already defined
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\SYSTEM\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using colorsbits of 32
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...23 PFDs found
...GLW_ChoosePFD failed
...GLW_ChoosePFD( 16, 24, 0 )
...23 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...using colorsbits of 16
...calling CDS: ok
...GLW_ChoosePFD( 16, 24, 8 )
...23 PFDs found
...23 PFDs found
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
RE_Shutdown( 1 )
Medal of Honor
--- Common Initialization ---
Medal of Honor Allied Assault 1.00 win-x86 Dec 6 2001
D:\Program Files\Games\EA GAMES\MOHAA\main\Pak5.pk3 (259 files)
D:\Program Files\Games\EA GAMES\MOHAA\main\Pak4.pk3 (593 files)
D:\Program Files\Games\EA GAMES\MOHAA\main\Pak3.pk3 (669 files)
D:\Program Files\Games\EA GAMES\MOHAA\main\Pak2.pk3 (4722 files)
D:\Program Files\Games\EA GAMES\MOHAA\main\Pak1.pk3 (772 files)
D:\Program Files\Games\EA GAMES\MOHAA\main\Pak0.pk3 (11175 files)
D:\Program Files\Games\EA GAMES\MOHAA/main
18190 files in pk3 files
execing default.cfg
execing menu.cfg
execing newconfig.cfg
Config: unnamedsoldier.cfg
couldn't exec configs/unnamedsoldier.cfg
couldn't exec localized.cfg
Unknown command "fov"
couldn't exec custom.cfg
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
------- Input Initialization Complete ------- 254
You are now setup for easy mode.
Called FadeSound with: 0.000000
----- R_Init -----
...initializing QGL
...calling CDS: ok
...GLW_ChoosePFD( 16, 16, 0 )
...23 PFDs found
...initializing QGL
ps: sistem:
AMD DURON 1000
Gygbyte VIA KT 266A
256MB DDR RAM
Windows 98 SE
RTCW
execing default.cfg
Bypassing CD checks
----- R_Init -----
...initializing QGL
...calling CDS: ok
...23 PFDs found
...23 PFDs found
...calling CDS: ok
...23 PFDs found
...23 PFDs found
...initializing QGL
RE_Shutdown( 1 )
Medal of Honor
execing default.cfg
execing menu.cfg
----- R_Init -----
...initializing QGL
...calling CDS: ok
...23 PFDs found
...initializing QGL
eland ::
Obe igri sta na openGL driverjih, probaj jih snet z neta. Da je delal prej zdej pa ne? Čudn. Poglej tudi nastavitve driverjev kakšne imaš. Mogoče imaš kaj disabled kar bi moral bit On.
BigSexy ::
če vse drugo zataji pa probaj tole ;) ...
Click Start / Run.
Type "win.ini" (without quotes) and press OK.
Search for a line that says "DVA=0" (without the quotes).
Add a semicolon (;) before the DVA (the line should now look like this: ";DVA=0" (without quotes))
Save and close the file
If you find this causes more problems, just take out the semicolon.
Mogoče bo pa delal ... ;)
Click Start / Run.
To Infinity And Beyond !
Jack69 ::
Ojla jaz imam RTCW, ki sem ga kupil v Big Bang/u in me zanima kako se vpise kode ker mi ne primejo na nikakrsen nacin dej povejmi kako naredim!!!!
Zakaj??? Začaj!!!
By: Jack
By: Jack
Area_51 ::
1. Na desktopu imaš bližnjico RTCW. Nanjo klikneš z desnim gumbom miške in klikneš na properites(Lastnosti)
2. Tam kjer piše location, greš do konca, nič ne brišeš.
3. Na koncu dodaš naslednje: +set sv_cheats 1
4. To je vse. Samo še OK klikni(vredu)
Upam pa, da veš kere so kode ina kako se jih vpiše.
Area 51
Area_51 ::
Area 51
A si slučajno spreminjal kakšne gonilnike od grafične ? Tu je tvoj problem.
Ker ti napiše da ne najde openGL subsystema. To pa je hardware ki bi podperal OpenGL , to pa je samo gonilnik v PM. Razen če imaš še kje drugje težave. Tu mislim na igre , s Quaqom imaš definitivno težave in ti mora isto napisati. Probaj UT ali kaj podobbnega , in ne pozabi nastaviti OpenGL ker podpera tudi directX aplak sklepam da bo isti problem.
jRk0 ::
pcgamera ni vec, tak da ne mores to primerjat:) pcformat pa je bolj kul od pcgamerja, joker je se bolj kul (se nasmejis malo) pol pa so se hrvaske revije ki so cenejse (naprimer vidi), pa so ta mesec naprimer opisali 60!!! graficnih kartic.
Jack69 ::
Oj ma italjanske revije so tudi ql ker dobis ful stvari in eno original igrico!!!
Zakaj??? Začaj!!!
By: Jack
By: Jack
Enzo77 ::
megane:probaj zbrisat vse dat. s koncnico *.cfg in pol probaj zagnat.
With a license to gib :)
lukslo ::
jst sem imel iste probleme pod WindowsXP z driverji 23.82 (al neki tazga), pol pa sem si dal gor 21.?? (mozno 21.82 al neki podobnega) pa dela vse OK
Flay ::
Ok could not open ... tisto kr si ti napisu
je ta problem de nimas mogoce zadnjih detonatorjev inštaliranih (driverjih za GF)
Ko bos instalirou te driverje ti more delat no saj men je
Pa še to na XP windowsih mi mohaa ne dela če kdo ve kaj narobe plz nej pove k sm probu use bios upgrade, novi detonatorji, reinstal, se enkat windowse gor itd.
| » | Wolfenstein - Enemy Territory (strani: 1 2 3 4 … 19 20 21 22 )Oddelek: Igre | 106203 (23211) | Gregor459 |
| » | Problem z nvidioOddelek: Pomoč in nasveti | 1901 (1649) | lanicorec |
| » | Gentoo install (strani: 1 2 )Oddelek: Operacijski sistemi | 6465 (5885) | HerrBaron |
| » | Medal of honor - patch!!!Oddelek: Igre | 3974 (3244) | Deathlike M Tito |
| » | Wolfenstein in XP???! :o(Oddelek: Pomoč in nasveti | 1488 (1390) | zrebec |
