Forum » Pomoč in nasveti » Open GL
Open GL
Roxi ::
Mogoče bedno vprašanje, ampak zakaj men Wolfenstein napiše da ne najde gonilnikov . Mam Durona 1000 in Voodoo3 300. Mi je že prej delalo na Voodoo2 12Mb,zdaj sem pa vse zamenal (plata,CPU,Grafična) in zamenal gonilnike.
Druge igre delajo samo Wolfenstein in Quahe 3 pa ne. Zanima me če obstaja Open GL za Win XP.
:D :D :D
:D :D :D
Highlag ::
Voodoo3 mislim, da nima popolne podpore za openGL.
Podpira z nekim gonilnikom samo neke ukaze OGL-a. Pobrskaj po netu.
Malo si preberi Readme od wolfenštajna:
3Dfx Interactive
Windows XP - Voodoo cards may not be used on systems running Windows XP as no drivers for Voodoo cards exist for that operating system.
We have provided Wicked OpenGL drivers to enhance performance for 3Dfx Voodoo card users. (Wicked 3D Drivers COPYRIGHT (c) 1997,2001 Metabyte, Inc. All rights reserved.)
Voodoo 3 - For optimal performance, we recommend setting your screen resolution in game to 640x480. You may experience crashes or other performance issues at resolutions higher than 800x600. 32 bit color is not supported by this video card. Setting 'Color Depth' or 'Texture Quality' to 32 bit may produce unpredictable results as well.
3Dfx Interactive
- spremenil: Highlag ()
lukanium ::
Idi na stran:
http://www.voodoofiles.com/ (miloscina s strani nVidie za nas, uboge uporabnike 3dfx-ovih kartic)
kjer boš dobil najnovejši driver za vse vodooje, ki je narejen posebej za WinXP. Podpira tako Direct3D kot OpenGL.
Lahko pa greš pogledat še na naslov:
http://www.opengl.org/
| » | Iščem alternativo vudujuOddelek: Kaj kupiti | 2443 (2207) | Arthur |
| » | Voodoo 3 in Win XP in 3Dfx tools :)Oddelek: Pomoč in nasveti | 1664 (1503) | PRiMoZ- |
| ⊘ | Aalchemy (strani: 1 2 )Oddelek: Zvok in slika | 7930 (7168) | Senitel |
| » | voodoo 3 3500 & gledanje tvja na compu ?!Oddelek: Zvok in slika | 2186 (2045) | undefined |
| » | DirectX 8.0Oddelek: Novice / Grafične kartice | 3446 (3446) | undefined |
