ATI Radeon HD2900PRO , HD2900GT
2 3
dzinks63 ::
:)) Na obzorju se svitajo nove kartice srednjega razreda ATI Radeon HD2900PRO in HD2900GT
V prodajo naj bi prišle oktobra (hvalijo se, da celo prej) ,
cena pa naj nebi bila višja od 220$, pri nas cca 220€. Radeon HD 2900 Pro and GT
g. Oden ::
Zakaj imam občutek, da ne bosta bogve kaj?
dzinks63 ::
:)) Saj nista namenjeni za špico. To bodo kar spodobne kartice srednjega razreda in naj bi zamenjali dosedanjo uspešno serijo X1950PRO.
  • spremenil: dzinks63 ()
phenom ::
no sej tud cena ne bo nevem kaj.
sam je zanimiva oznaka gt, tega ne vidiš pogosto pri radeončkih.
  • spremenilo: phenom ()
dzinks63 ::
:)) Tudi nvidia ne spi. 12. novembra pridejo nove kartice.
V srednjem razredu na G98 jedru, katere bodo sedaj 256 bitne.
Tako, da bo prava borba med ATI in Nvidio.
G92 et G98 en 65 nm le 12 novembre ! , Nvidia's G98 is a mainstream chip
phenom ::
ja sej komi čakam, da pride nova serija vn. k itak je čs da menjam grafično kartico in to bom naredu z 9800gtx, k baje da bo mel gtx 1024mb rama, 512 bitno vodilo in še veliko drugih bonbončkov, kar bo nvidio postavl daleč daleč pred radeonom.
92 will be released in November 2007 timeframe in the form of "GeForce 9800" series.
"G92" GeForce 9800 GTX specs.
- 65nm process technology at TSMC.
- Over one billion transistors.
- Second Generation Unified Shader Architecture.
- Double precsion support (FP64).
- GPGPU native.
- Over one TeraFLOPS of shader processing power.
- MADD+ADD configuration for the shader untis (2+1 FLOPS=3 FLOPS per ALU)
- Fully Scalar design.
- 512-bit memory interface.
- 1024MB GDDR4 graphics memory.
- DirectX 10.1 support.
- OpenGL 3.0 Support.
- eDRAM die for "FREE 4xAA".
- built in Audio Chip.
- built in tesselation unit (in the graphics core"
- Improved AA and AF quality levels
Pros.
65nm process will allow for better yields and better power consumption. power consumption will be lower than that of a GeForce 8800 GTX.
GeForce 9800 GTX will be over two times faster than a GeForce 8800 Ultra in real world games and applcations.
Release date : November 2007. There will be TWO products at launch: The flagship GeForce 9800 GTX and the second fastest GeForce 9800 GTS.
price for the GeForce 9800 GTX will be 549-649 USD.
price for the GeForce 9800 GTS will be 399-449 USD.
MEDENA ::
price for the GeForce 9800 GTX will be 549-649 USD. 550 - 650€ + 10%
price for the GeForce 9800 GTS will be 399-449 USD. 400-450€ + 10%
>:D
kobilica ::
Ma dej no so tovarne cist znorele,100 jurjev tastarih?
Koliko bo pa kaj stalo pri sosedih? Avtrija,Italija?
Senitel ::
Ma dejte že nehat bit čist navadne ovce ob teh blebetanjih z interneta... Vas lansko leto in ugibanja o G80 niso nič izučila?
phenom ::
ja sej tko na opisu vse zgleda hudo, sam me mal skrbi ta novica k je na prvi strani foruma. da kao naj bi bla serija 9800 samo za srednji razred po zmogljivosti, tudi gtx al kaj. sam to je mal čudno, ker sodeč po teh specifikacijah, če so resnične seveda bi morala ta grafična 9800gtx bit daleč najhitrejša od vseh danes znanih.
phenom ::
sam se mi zdi da so to cilal na serijo 9800 gts, ker una bo res srednji razred, gtx pa nikakor, vsaj do zdej nikol ni bla pri nvidii nova serija gtxov klasificirana kot srednji razred, tko da menim da se vseen za nakup splača kupt 9800 gtx. bomo pač počakal in vidl.
DJ MartiNi ::
Pravi naslednik x1950pro bo HD 2950Pro.
Ryzen 7 7800X3D/MSI B850 Edge Ti Wifi/2x16GB G.Skill Ripjaws S5 6000/RX 7900 XT
Ryzen 7 5700X/ASRock B550 PG Velocita/2x16GB G.Skill Ripjaws V 3600/RX 5700 XT
AMD FX-8350/ASRock 970 Extreme4/2x4GB Kingston HyperX Beast 2400/R9 270X
billgates ::
Sam da bo le cena tudi podobna...
GrimReaper ::
Se prav je to končno pravi mid-range, Pro naj bi se približal 8800GTS 320MB, GT pa naj bi bla boljša od vseh kartic prejšnje generacije.
To bodo šle za med.
GrimReaper ::
Se je že začelo:
ATI Radeon HD 2900 Pro Pre-Orders Accepted, Specs Unclear.
Radeon HD 2900 Pro priced
GeCube Radeon HD 2900 Pro, 512MB GDDR3
Sapphire Radeon HD 2900 Pro, 512MB GDDR3
Sapphire Radeon HD 2900 Pro, 1024MB GDDR3
Novice o HIS HD 2900Pro so pa popolni bullshit, XT z zmanjšanimi frekvencami za 250€, lol.
HIS HD 2900Pro 512MB
Če bo pri nas 512MB verzija 250€, je takoj moja.
MEDENA ::
samo sanjamo lahko o 250€ pri nas >:D
LjubimPeezde ::
Kaj ti si jasnovidec ali imaš insiderske informacije?
Kar vsakmu wannabeju tut ni za verjet vsak stavek:)
dukenukem ::
klik here,evo hisovo makinco :D se pravi malo naviješ,pa maš 2900xt :))
Klemzz ::
po ferkvenci ja, drgač pa ne.
dzinks63 ::
:)) Kolikor vidim , bi naj bi imele te HD2900pro celo 512 bitno vodilo, čeprav je bilo napovedano 256bit. Če pa bo tole res , potem bo to ubijalska kartica za cca 220-250€. Bila bi naj samo DOWN clockana XT. In z malo overclocka imaš zopet XT.
ATI Radeon HD 2900 Pro,
The card will have full 320 stream processing units and as it seems even a 512 bit memory interface.
The major difference will be the clocks frequencies. The GPU will run at 600 MHz (the HD 2900 XT has 740 MHz) and the Ram will work at 1600 MHz (1650 MHz on the HD 2900 XT). There even are rumors saying the HD 2900 Pro 1GB will use GDDR4 instead of GDDR3. But this is still unsure.
* Powered by Radeon® HD 2900Pro GPU
* Superscalar unified shader architecture
* 320 stream processing units
* 512-bit 8-channel memory interface
* Comprehensive DirectX® 10 support
* Integrated CrossFire™
* Built-in HDMI and 5.1 surround audio
* Dynamic geometry acceleration
* Game physics processing capability
HD 2900PRO 512MB GDDR3 512Bit DX10
Klemzz ::
če bo res 512bit bo res pocen :))
OChack ::
res bo res, baje d abo 1giga verzija mela gddr4..........sliš se dobr če bo res 270e
Int€l inside, IDIOT Outside
phenom ::
zelo mamljivo, sam pravo uprašanje je kako se bo obnesla v testih.
T-Majo ::
Js bom takoj uzel hd2900pro 1gb ddr4 če bo za 270€. Sicer mormo prvo teste vidim. Računam pa na funtech...da bodo spet kakšno akcijo dali ven. >:D
OZZY ::
Še 2 tedna pa bojo..
Go with the flow.
AapocalypseE ::
T-Majo, boš še moral prištet zraven kakih 100€ >:D
OZZY ::
sam dvomim da bo 512-bitna....glede na to, da naj bi kartica sicer že obstajala kot firegl v7600....čeprav ma r600 gor naj bi se le ta z ''memory controller unlinked'' imenoval tud r630.. Kok je na tem bomo vidli.
Go with the flow.
T-Majo ::
HKC 580W 140mm fan verzija bi mogu bit dost ne??? Že tak bo to dost po žepu udarlo, vem da so radeoni bolj požrešnih od geforcev.
Zakaj bi bla potem grafična 370€? Če je napovedana za 270€ s tem, da bi se tu prodajala okrog 310-320€?
  • spremenil: T-Majo ()
LjubimPeezde ::
Prrihaja tudi HD2950XT:)
8800gtx killer za nižjo ceno, to je sedaj vprašanje:)
AapocalypseE ::
KLIK KLIK mene bolj zanima kako bo z 9800GTX/GTS. GTX bi naj bla 2x boljša od 8800Ultra, ampak bo verjetno zelo draga, tako da me zelo zanima kako bo z 9800GTS.
AapocalypseE ::
Kopiram iz OC-laba:
V javnost so pricurljale prve slike grafične kartice HD2950.
Na jedru RV670 bosta dve izpeljanki; polnokrvna HD2950 XT in okrnjena HD2950 Pro. Prva bo imela 512MB GDDR4 (1.2GHz) in hitrost grafičnega srčka 825MHz. Druga bo imela 512/256MB GDDR3 (900MHz) in hitrost jedra 750MHz.
Iz slik je razvidna tudi prednost/novost jedra RV670 -izdelanega v 55nm proizvodnem procesu, saj ima grafična samo en PCI-e napajalni priključek. Najveretneje gre nekaj tudi na račun novega grafičnega vodila PCI-e revizije 2.0, ki je sposoben dovesti 150W energije. Hladilni sistem (vsaj izgleda tako) bo zavzel "le" eno razširitveno režo -slot.
SLIKA
hribovc ::
HD2900Pro je kot zgleda 256 bitna. 512MB Sapphire Radeon HD2900Pro
GrimReaper ::
Zdej se že ve da bo 512-bitna, sam je pa problem da bodo zelo omejene količine, pa požrešna je kartica, slab AA performans.
Napajalnik bo itak treba menjat tut za 8800GTS, tko da kar se mene tiče, bo odločala predvsem cena. Na naslednje kartice pa ne mislim čakat, prve naslednje generacije bodo šele novembra, oz. začetek 2008 od ATIja.
Radeon HD 2900 Pro will be short lived
Radeon HD 2900 Pro / HD 2900 GT
Še iz uradnih strani da ne bo nadaljne zmede glede 256/512-bit, tut na Geizhals imajo vse trgovine napisano 512-bit:
GECUBE
HIS
GrimReaper ::
dzinks63 ::
:)) Saj to je bilo za pričakovat. Če je samo down clockana XT, potem je jasno da je na stock počasnejša od XT, ko pa jo naviješ je pa celo hitrejša oziroma enako hitra kot XT navita. Ker pa bo očutno cenejša od XT, bo pa to best buy v višjem cenovnem razredu za nekaj časa. Samo pravijo da bo omejena količina , tako da se bo treba kar zagrebst kdor jo bo hotel imet.
Klemzz ::
so jo pa mal navil :\ jst XTja gonm na 850/1000 s stock.
OChack ::
u 3d mark clo naščije GTS 640 MB >:D
MEDENA ::
če verjameš testom.
LjubimPeezde ::
zakaj se pa ne bi verjelo?
ker imaš ti Nvidio in ti sedaj ne paše.
Pejt se naspat raje ZzZzZz:)
To je/bo pač pest buy v višjem razredu definitivno pa će se ti na glavo postaviš
MEDENA ::
ne ne verjamem dokler ne vidim pred sabo in nisem zaspan ter imel sem ati pa mi ni všeč.
ko bo cena v slo 300€ ne bo bestbuy.>:D
DJ MartiNi ::
Cena težko verjamem, da bi bila 300€. Upam da bo nižja pa ne za malo. :))
MEDENA ::
V Angliji je cca 250€, me zanima kok je v Nemčiji ali Austriji.
dzinks63 ::
:)) Cene so ene par postov višje, drugače pa : heise.de/preisvergleich od 225€ naprej
dukenukem ::
dejstvo je, da more bit občutno cenejši ,kot gts 320:D samo spet naši trgovci, pa njihove marže ,pismo ;((
MEDENA ::
marže nimajo tukaj nobene vloge, uvozne cene so višje...
slo uvoznik naroči 20-50kosov, avstrijski 100-500, nemški 500-1000+...
kdo dobi boljšo ceno?
Mirč ::
malo več že ko 20-50,malo si oglej skladišče nasih uvoznikov(diss,mikropis,elkotex,avter,alterna,...)
MEDENA ::
hipotetično sem dal primerjavo...
Mirč ::
gre za marzo
dukenukem ::
ekola test hisove 2900pro :D klik za test :)
zgleda, da je to nova makina za dan cekin :) :))
dzinks63 ::
:)) Bil je že čas, da se kaj novega, konkretnega, boljšega in cenejšega prikaže na obzorju. Sedaj kar slutim , da bodo padle cene 8800gts karticam.
2 3
Radeon 3870 VS GeForce 8800GT (strani: 1 2 3 )
1289923 (9010) JamesBond
potrebujem nasvete glede grafične kartice.
101232 (1232) LazyAss
Sapphire pokazal delček prihodnosti
Oddelek: Novice / Procesorji
446064 (3504) Shegevara
AMD kmalu z Radeonom HD 2900 Pro
415906 (4102) DJ MartiNi
7900gs ali 7950gt ali 8800gts ?
272293 (1983) jerry_p
