Forum » Igre » gta sanandreas teratoriji v San fiero in LV
Rony-e ::
Letiš 20-30 minut JV in skočiš v vodo in se potopiš in se pokažejo novi teratoriji ki jih je 178
billgates ::
O čem govoriš? Pri gta san andreas se usedeš v letalo pa letaš pol ure JV pa maš kr neke teritorije?
billgates ::
Ja model a si probal al kaj? Pa še zdaj ne vem zakaj je to v kaj kupiti?Men osebno se to polurno letenje zdi glupo, rajš v gantonu povozim tistih par ljudi ki jih hočm pa konc
Rony-e ::
Must fly/boat out till you reach corner (it seems that any corner will do) of map (15 to 20 min real time)
-The longer you stay out, the more territories you get
-Shemal and AT400 auto level out and thus are the best choice
-The max number of terrirories gotten thru this glitch stands at 178
-You don't have to die to get it to work
-You don't have to have completed the final missions where gang wars come back to get it to work
-It still works if you have gotten 100% of the territories
Tips to get it to work:
-Use the Shemal
-Fatten up if you plan to stay out for more than an hour (remember: 11 meals per 6 hours or you will barf)
-It only takes 20 min or so to get to the edge and back, so flying back won't take you 2 hours if you have been out for 2 hours
On Capturing new Territories:
-Ignore Triads (blue Vagos), they show up all over the map but killing them won't get a war
-Kill only Vagos and Ballas to start wars
-New territores gotten thru this glitch only have one, easy to kill wave
-Yank gang members out of cars in no ped areas to start wars
No, just kidding. Everything you need to know is in this post, as far as I know.
Maybe we could use this, or another post as a template and keep updating it and posting it when new things are found out.
-Use the Shemal
zcetrt ::
In zakaj bi si človek sploh želel "one wave easy to kill"? Ah... Mogoče za tiste, ki padejo v depresijo, ko nabereje 50 podkev, 50 školjk, 50 snapshotov in premalajo vse grafite... Potem pa se podre svet, ker nimajo več kaj početi.
edit: Kaj kupiti? Kakšno knjigo recimo. Ali pa bicikel.
4.
- spremenil: zcetrt ()
| » | nigerijci še vedno harajo po bolhiOddelek: Loža | 10091 (9016) | sarma832 |
| » | Nov članek: "All your firmware are belong to us" (strani: 1 2 3 )Oddelek: Novice / Nova vsebina | 20217 (17057) | arrigo |
| » | Vici na temo ponosnih AmeričanovOddelek: Loža | 4975 (4229) | spader |
| » | GTA3 DodoOddelek: Igre | 3587 (3114) | burekar |
