Forum » Zvok in slika » virtualdub
virtualdub
raso ::
prokleto ne morem z virtualdubom rezat avi datoteke pa imam nastavljene kodekle in mi pokaze
AVI:Variable birate (VBR) audio detected VBR audio in AVI is non-standard
And you may encounter sync errors up to 17862ms when attempting to extract
WAW ffiles or processing the audio in Direct Stream Copy mode. Full Processing
Mode is recommended to decompresses the audio. (birate:125,7 +- 18,7 kbps)
VirtualDub Error
No audio decompressor could be found to decompress audio format.
(source format tag:0055)
HVALA ZA POMOC
VirtualDub Error
HVALA ZA POMOC
podtalje ::
VBR audio glede na definiran standard ne paše v .avi datoteke in zato tudi ni podprt v VirtualDub-u.
Uporabi VirtualDubMod, ki je malenkostno spremenjen VirtualDub in podpira tudi VBR audio.
| » | Integrirani podnapisiOddelek: Zvok in slika | 10194 (7927) | dzinks63 |
| » | FilmOddelek: Programska oprema | 1743 (1451) | pivmik |
| » | Codec za Terminator3Oddelek: Pomoč in nasveti | 2140 (1758) | SasoS |
| » | Spajanje video filovOddelek: Zvok in slika | 1367 (1266) | rap3r |
| » | Z VirtualDub-om v Divx - kako?Oddelek: Programska oprema | 2072 (1992) | waters |
