Forum » Problemi človeštva » Iran - odštevanje
Iran - odštevanje
Double_J ::
Video: Mitt Romney Warns Nukes Will Be Used If Obama Re-Elected
http://www.opposingviews.com/i/politics...
Dve šivanki...
ZaphodBB ::
Torej, če bo Obama izvoljen bo Iran kar uporabil atomsko orožje.
Jebeš, da ga morajo še najprej naredit, pa da z 3.5% u235 bolj švoh bombe delaš.
Ti si res debil.
Ti si res debil.
Double_J ::
Ko Romney precenjuje zadevo, deluje pomirjujoče. Ko Obama podcenjuje zadevo, pa ravno obratno.
20% tudi imajo. Kar v parih tednih obogatiš na 90%.
3.5% u235
Dve šivanki...
Mr Hilter ::
Ne morem si predstavljati kaj mora biti s človekom narobe, da navija za uporabo atomske bombe?
Double_J a to samo na internetu pumpaš, ali si upaš v živo med normalnimi ljudmi kaj takega izjaviti?
Ma saj ni treba odgovarjati, se mi zdi da že dobro vem.
amigo_no1 ::
Kdo koga ogroža ?
http://thebulletin.org/web-edition/feat...
In the single cascade at the pilot plant, Iran can produce about 1.3 kilograms of 20 percent enriched uranium every month, which is almost certainly more than what the reactor consumes during the same time period. If the reactor were operated at maximum power for approximately 100 days, as has historically been the operation time, the Tehran Research Reactor would consume almost 0.64 kilograms per average month of operation. Thus, in theory, one 164-machine cascade could produce more than twice what the research reactor consumes each month, which is consistent with comments made by Iran's representative to the IAEA.
- spremenilo: amigo_no1 ()
Karaya 52 ::
Americani imajo baze povsod po svetu, se spomnim ene na jugu Spanije. Mi smo polezavali na brisacah, vojaki so pa laufali gor pa dol po plazi, vsekakor raj za *****. Cudno da se Spanija kot njene sosede ne pocutijo ogrozene.
amigo_no1 ::
19 May 2010
Se priporočam za kake bolj nove podatke, kako lahko neka država pod "embargom" v parih tednih obogati uran na 90%.
1 proti 40 je rahla razlika ?
Karaya 52 ::
Eh, sj jih imajo vec. Pa v Italiji in Franciji, verjetno tudi na severu Afrike. Americani so prvo vojno kot za Anglezi fajtali Spance, ker so jim z merkanitilizmom srali po laissez faire-u. Tako Amera pripravis da v roke primer pusko.
Double_J ::
http://www.foreignpolicy.com/articles/2...
If Iran decides to produce weapons-grade uranium from 20 percent enriched uranium, it has already technically undertaken 90 percent of the enrichment effort required
Dve šivanki...
- spremenil: Double_J ()
Karaya 52> Tako Amera pripravis da v roke primer pusko.
Svašta. Kaj pa imajo ZDA z laissez-faire?
amigo_no1 ::
Preberi si malo komentarje spodaj od tvojega foreignpolicy.com članka... kot kaže je članek delanje slona iz muhe.
http://dyn.politico.com/printstory.cfm?...
IRAN MOVES CLOSER TO A BOMB
February 25, 2010
http://www.iranwatch.org/ourpubs/bullet...
Srbi bi rekli "samo što nije", sedaj smo 2 leti naprej in so še vedno pri 20%.
Tistih 90% je kot Nessi, vsi pravijo da obstaja, samo nihče je še ni videl.
But not only is there no evidence for any current nuclear weapons program in Iran, there's nothing in international law that prohibits Iran from gaining a nuclear weapons capability.
Iran, and other signatory non-nuclear weapons states of the Nuclear Nonproliferation Treaty, are only prohibited from manufacturing nuclear bombs or diverting fissionable material to weapons uses -- things Iran has not been accused of doing.
February 25, 2010
Double_J ::
http://www.iranwatch.org/ourpubs/articl...
Vsi podatki, ki koga zanimajo so navedeni tule. Pač ne upajo na 90% kar naenkrat, ker bi bili zbombandirani.
Kar je potrebno za bombo pa tudi testirajo, samo sedaj čistijo...
Dve šivanki...
pecorin ::
Double_J:
res je offtopic, ampak, ker se mi zdi, da te je zamisel o unicenju irana malo prevec obsedla, ti svetujem, da si kdaj pa kdaj reces "eh fuck it..."
Sherwin Nuland
Sherwin Nuland
Mr Hilter ::
V primeru da Izrael res uporabi nuklearno orožje bo še zanimivo kaj se bo pričelo dogajati z židi po svetu. Napovedujem da bojo raznorazni antisemitski krožki (recimo jim npr. ican) rastli kot gobe po dežju?
Double_J ::
pecorin
Zmanjkalo argumentov, ko sem postregel s točnimi podatki? Se mi je zdelo.
Dve šivanki...
Mr Hilter ::
pecorin
Zmanjkalo argumentov, ko sem postregel s točnimi podatki? Se mi je zdelo.![]()
Taki 'dokazi' kot so jih imeli za biološko orožje v Iraku in podzemne rove polne zlata Osame...?
Kje pa si ti postregel s točnimi podatki, podatki...? Kje so poročila inšpekcij, izpovedi vohunov...?
amigo_no1 ::
pecorin
Tvoje domneve so napačne, kar sem ti lepo pokazal iz članka "samo što nije".
Crying wolf about an Iranian nuclear bomb
17 JANUARY 2012
http://thebulletin.org/web-edition/op-e...
Crying wolf. As strategic analysts Anthony Cordesman and Khalil al-Rodhan remind us, in the 1990s, high-level American and Israeli policymakers repeatedly warned of an Iranian bomb by the year 2000. When that did not come to pass, policymakers warned of an Iranian bomb by the year 2005. Then they said it would happen by 2010. Now the talk puts Iran's nuclear debut in the 2013-2015 time frame, if not sooner.
The story of the boy who cried wolf comes to mind.
Kje so potem vse te famozne bombe ?
Kdo jih bo bombandiral in zakaj ?
Kje je stran http://israelwatch.org ?
Qrc, nič ne bo, ne priznavajo IAEA in niso podpisalo NPT-ja.
Double_J ::
Saj teh podatkov Iran ne zanika, ki so napisani. Celo potrdili jih bodo ter rekli, da pač ne bogatijo na 90%.
Samo verjemi, da si ne želiš imeti niti na tone 20% urana vsepovsod. To potem zelo hitro lahko na kakšnem skrivnem mestu obogatiš na 90%, ko svet ni pozoren.
Dve šivanki...
amigo_no1 ::
Eh šit, Židom in Amerom se bo še zmešalo:
Fearful of a nuclear Iran? The real WMD nightmare is Syria
Double_J ::
Ob takih izjavah si želim, da bi Double_J prebival v Nemčiji.
Obama bi iskal konsenz mednarodne skupnosti, glede hrošča.
Dve šivanki...
Ti torej praviš, da je konsenz mednarodne skupnosti nepotrebna neumnost, ko gre za uporabo smrtonosne sile zoper civilno prebivalstvo suverene države?
Double_J ::
Lahko bi debatirali ali so tisti ljudje v jedrskih objektih civilisti. Jaz bi jim resno predlagal, da ne hodijo več v te objekte na posel.
Dve šivanki...
Double_J> Lahko bi debatirali ali so tisti ljudje v jedrskih objektih civilisti. Jaz bi jim resno predlagal, da ne hodijo več v te objekte na posel.
Ne, ne bi mogli debatirat o tem. Tudi miljon mrtvih iraških civilistov ni vojakovm, za njihovo smrt je pa odgovoren tip, ki se je pokakal na konsenz (in bi, kar se mene tiče, moral sedet v zaporu, poleg britanskega kolega).
Double_J ::
Ne mešaj konsenza, z nedodelanim načrtom...
Za konsenz se je seveda treba truditi, v končni fazi pa moraš naprej s toliko konseza, kot ga je pač možno doseči.
Dve šivanki...
ZaphodBB ::
Milošević je mel poln konsenz, da se pobije turke. Your point? Da je slabo splaniral genocid? V Haag z Bibijem, Bushem, Cheneyem, Rovom in še kom.
Jah, nek polovični konsenz in dober načrt sta tisto, ko mi polveriziramo 'one druge', zločin in grožnja pa sta, ko 'oni drugi' to počnejo nam. Licemerje par excellence. Ne vem zakaj se Double_J toliko trudi z opravičevanjem, mar bi lepo povedal po resnici, da želi videti, da bi pobili vse muslimane ali po možnosti vse ne-bele rase, potem npr. vse nečiste belce, potem npr. vse nekristjane itn.
Juliusa Streicherja so po 2. sv. vojni obesili v Nurembergu, čeprav ni osebno storil ali podpisal en sam umor človeka. Obsojen je bil samo in izključno zaradi spodbujanja sovraštva, saj je s tem postal soodgovoren za masovne zločine. Američani pozabljajo kako so se tedaj vedli in kako zgleda, ko hudiča spustiš z verige.
Pšenični ::
Sodelujem tud na nekem vojaškem tujem forumu, tam pravijo, da je večji tehnološki problem prskočt iz iz 4% na 20% kot pol na 90%, pri obogatenju urana. Tko tle so že zunej. Pa lah žideki upravičeno delajo paniko.
Predvideva se da ima Iran nekaj (več) majnših skrivnih lokacij, za katere ne ve nihče. In tam čarajo svojih 90%. Tko da tud tle so že zunej.
Torej v tem kontekstu, ne pričakujem da bo Iran sam stopnjeval intenziteto spopadov, ampak bo lepo na več majnših lokacijah spedenal zadevo do konca.
Po bombandiranju bo pač lah počel kar ga bo volja, ko se bojo Žideki tolkli po prsih, kaj da so vse podrli. Iran mora le pravočasno ustavit cenrifuge, da mu jih treslaji ne poškodujejo....zraven pa ne bodo prišli.
Tko da zna Iran pridet do bombe........pol ko bo jo enkrat imel, ga ne bojo več bombandirali.
Tko da, je v bistvu napad na Iran neproduktiven. Če ne pride do zamenjave oblasti. V tem primeru, A-bomba bo. Bo verjetno v vsakem primeru. Razen če Iran poglihajo.
http://www.b92.net/biz/vesti/svet.php?y...
Iran se sicer pospešeno pripravlja na vojno.
- spremenilo: Pšenični ()
IcEk` ::
Aircraft Carrier Enterprise Sets Off On Final Journey - Direction Iran
Today at noon Eastern, the storied aircraft carrier Enterprise, aka CVN-65, left its home port of Naval Station Norfolk one final time for its final voyage with a heading: Arabian Sea, aka Iran. There in a week it will join CVN 72 Lincoln and CVN 70 Vinson, as well as LHD 8 Makin Island, all of which are supporting any potential escalation of "hostilities" in the Persian Gulf region.
http://www.zerohedge.com/news/aircraft-...
Double_J ::
http://www.reuters.com/article/2012/03/...
http://isis-online.org/isis-reports/det...
Pa smo jih našli...
Pa smo jih našli...
Dve šivanki...
Double_J ::
@Double_J: kaj ste našli?
Satellite Image of Building Which Contains a High Explosive Test Chamber at the Parchin Site in Iran
Dve šivanki...
Prpravlajo se, da bodo naš dnar zagonil za še en ogromen masaker, potem pa naš dnar zagonil za "demokratizacijo", "obnovo" in kar je še takih reči.
Rezultat bo pa še manj stabilen bližnji vzhod in še nižji dolar in evro.
Mr Hilter ::
@Double_J: škoda da niso ponoči slikali, bi se videlo kako vse zeleno žari?
@jype: Afriko si pozabil. Tudi njih bo treba osvobajati!
Kaj se lahko pa v Sloveniji pripeti, da nas bi morala America osvobajati?
Zheegec ::
Pa smo jih našli...
Kaj še ena vojna na osnovi PowerPoint prezentacije? Nismo to že dali skozi?
Janez Janša, 29.04.2014
V bistvu lahko rečemo da imajo vsaj dobre ceste
Double_J ::
August 13, 2004
Figure 4. July 28, 2011 commercial satellite image of the same compound at Parchin.
Misliš da ne stoji več? Pa sej še ni bilo napada...
Dve šivanki...
Sej še vedno vse stoji, torej napada še ni bilo. Morda te moti to, da je drugi zoom.
Fantje pejte tankat, pa še kakšno zalogo naredite : Iran's banks to be blocked from global banking system : http://www.bbc.co.uk/news/business-1739...
Dobri so ti amerji, kako bodo EU poseksali.
Nissan GTR ::
upam, da kmalu preidemo v postcionistične čase, da se amerika dokončno gospodarsko sesuje sama vase in da bo prva velesila Kitajska... Potem bodo cionisti veliko težje netili vojne po svetu...
- predlagal izbris: Miha_T ()
krneki0001 ::
Ne si želet kitajcev. Kar se tega tiče so ameri boljši, ker vsaj kej lahko rečeš, če se ne strinjaš (sej upoštevajo te itak ne), če pa boš kitajcu kej rekel, bo pa tanke nate spustil. Če so jih lahko nad svoje ljudi, jih bodo še mnogo lažje nad nas.
Mr Hilter ::
Feels bad man
Ne samo da se to dogaja, ampak tudi da folk naseda zakaj se to dogaja.
How can we win, when the fools can be kings?
donfilipo ::
Kitajskih tankov se ni za bat. Zaenkrat. In res je, veliko zasluge za to je na strani NATA:)
Pa tudi sicer je tako, da ko bo res na vsakem vogalu kitajska štacuna s zmajčki in papirčki, in kitajsko naselje, četrt in še geto..no potem pa....
Do takrat nas bodo pa futrali ko morske prašičke in mi krafl na novo kupovali vsake 2 leti...kar pomeni da smo v relativno ugodni fazi cinoekspanzije
Še kakih 10-20let. Potem piši propalo
Tale SWIFT block je pa vsekakor znak, da nekdo resno preizkuša druge metode poraziti tiranstvo. Kar je positivo.
Negativo je to, da če kaj prav vem, to islamske tirane samo pospeši v njihovih zlobnih načrtih, kar pomeni da je tudi tu pot že načrtana, in da razen: 'napol narejenega kričanja trop šimpanzov ne bo ukrenil nič drugače, kot mu veleva nagon
In times of Universal Deceit, telling the truth
becomes revolutionary act. Orwell
IcEk` ::
Jaz si ne znam predstavljat pri vsem vojaškem aparatu in bombah vseh vrst, da bi Kitajska nadvladala ZDA in EU. Prej bo totalna vojna in zelo grde posledice, kot da bi se jim podredili, kaj šele da bi dopustili da nas maltretirajo ipd.. Mislim.. kaksni kitajski tanki nad našim prebivalstvom?? Kdo bi to mirno gledal?
Saj Ameri z izjemo nekaterih držav vse ostale matretirajo gospodarsko in ne vojaško. Bojo kitajci kar kopirali njihov stil, jaz mislim da je to velik napredek, da velesila vpliva na ostali svet na drug način kakor vojna.
