Forum » Sedem umetnosti » problemi pri divxih
problemi pri divxih
fictionel ::
tkole je...:
z gordian-knotom sm naredu movie file in pa posebej mp3 (nekak ni ratal da bi blo oboje skupi)
zj mi pa plis povejte kuko nj dam to dvoje skupi!
fictionel ::
a res tle nben nima pojma????
se mi res cudn zdi... kdr kol postavm ksn topic mam najvec 2-3odgovore...
borchi ::
ne vem če lahko v virtualdubu odpreš mp3, v nandubu lahko sigurno. torej odpri video in mp3 ( audio --> (vbr) mp3 audio ). oboje daš na direct stream copy in shraniš pod nekim novim xxx.avi.
l'jga
matevzm ::
Bojda obstaja VirtualDub, ki zna te zadeve zdruzevati. Bojda jih zna tudi Nandub, celo brez da bi pretvarjal header .mp3ja v .wav. In oboje je bilo ze precejkrat obdelano in pise na skoraj vsaki DivX strani. Lahko pa pogledas doom9.org, ce ni tam, potem je tezko najti.
fictionel ::
sj to sm zele pogruntov... vazn je sam (NANDUB), da das oboje direct stream copy... ce sm dau kr kol ducega ni delal
zj mam pa (že) drug problem... KUKO NJ RAZREZM DIVX NA DVA DELA?
pa s kermu progyem??? a??
tole se mi pa zdi mal bl zapleten...
sm smotan in pac hocm velko kvaliteto (pa tut ce bo pol na 2 cdjih
boha ::
pa sej ti je že nekdo dal link do doom9, tam najdeš vse možne audio/video guide-e!!!
ok, recimo, da se te usmilim. tu imaš paste iz virtualdub vodiča...
Load your movie VirtualDub. Select Video, then Select Range:
There's no way to make sure how large the resulting file will get so you basically have to guess. If your whole movie is 1300MB cut at about half of the total length (divide the length by 2, then enter that value in the Length field... I prefer to operate by frames but you can of course use Time if you prefer). You can select a length by offset (an start offset of 1000 would mean the video would start at frame 1000, an end offset of 2000 means that your video will end at frame 2000) or by length in number of frames/milliseconds. The latter is obviously easier to use, but it will only work for the first part. So select Start offset 0, Length as desired, then press ok and save the movie. Verify that the size is what you wanted, if not go back and select another length. For the 2nd part of your movie, copy the End offset that's currently being indicated in the corresponding text field to the start offset text field, set a length again (if you're splitting to 3 or more parts) or set End offset 0 (meaning the file will include everything from Start offset till the end. Make also sure that you split by a keyframe, not just any frame - otherwise you might lose some frames and it'll be impossible the remerge the files if needed.
Attention: Make sure that you've set both Video and Audio to Direct Stream Copy. Generally when you start VirtualDub audio is already set to Direct Stream Copy but Video is not. If you don't change this it takes hours and it'll decompress and recompress the whole movie - not a smart thing to do.
The slider can be used to go from one position to another quickly. The buttons marked (1) can be used to go forward/backward frame by frame, the buttons marked (2) can be used to go forward/backward by keyframe.
Alternatively you can use the navigation controls to select the range directly. During these operations it's important that whenever you move the slider you press down the Shift button on your keyboard which will make sure that your positions are at a keyframe. Move the slider to the desired starting position, then press the Home button on your keyboard. Then move the slider to the desired end position and press the End button on your keyboard. Then save the movie (F7). Now press Home again which will make the current position the start position and move your slider again (while pressing down Shift, of course). Repeat the process until you have splitted the AVI into however parts you may want.
fictionel ::
boha... hvala... ampak bl mau razumem...
zato nocm it na dooma
sj mi je ratal... u nandubu sm dal da shran u dveh fajlih (tapru nj bo 660 mb) pa je ratal odlično! hehe :D
se neki me zanima:
- zakva mi noce u bsplayerju predvajat podnapisov... za noben film! zj sm 2 probov: taxi2 pa matrico... pa nc ne dela...
za taxi mam taprave podnapise - sam tut ce ne bi bli bi mogl delat. Ane?
[dodano later]
dela sam, ce mam podnapise k so oznaceni s casom... ce so oznaceni z frejmi ne dela! zakaj?
mam najnovejso verzijo bsplayerja pa winxp...
edin ce zarad windowsow ne dela?
se neki me zanima:
[dodano later]
- spremenil: fictionel ()
| » | Ne predvaja novega audio CDOddelek: Pomoč in nasveti | 2616 (2572) | Tea Time |
| » | [DivXviD] filmi na Divx predvajalnikih brez problemovOddelek: Zvok in slika | 23741 (10742) | bbbb |
| » | usklajevanje zvoka in slikeOddelek: Zvok in slika | 4069 (3843) | CaqKa |
| » | "Miška" na notesniku (Compaq) je zelo samosvoja !Oddelek: Strojna oprema | 2240 (2147) | Cokolesnik |
| » | Pomoc pri deljenju datotek-eOddelek: Pomoč in nasveti | 1128 (1066) | Cokolesnik |
