kako film, ki se predvaja v brskalnuki prenesti na disk
2
slovencl ::
Kako lahko filmček (npr. ta), ki se predvaja v brskalniku, prenesem na disk?
dzinks63 ::
:)) Imeti moraš nameščen Firefox in nato namestiš unplug zeleno ribico v zgornjem desnem kotu ekrana in potem s to ribico posnameš filmček na disk
poweroff ::
VideoDownloader plugin za Firefox si poglej.
sudo poweroff
PaX_MaN ::
Meni nista delala ne VideoDownloader, ne unplug :\ . Zato pa dela DownloadHelper :D
dj cotto ::
Ali obstaja tudi kakšen plug-in za Opero?
StratOS ::
simple HTTP analiza in voila *.flv je tukaj 140 MB - Direkten Download Seveda pa bo stvar zgleda veljala le za moj coockie :D
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
  • spremenila: StratOS ()
Yohan del Sud ::
Dejansko se ti vsak film ki ga gledaš v brskalniku zapiše nekam na disk. Ponavadi ima končnico flv. Res pa je, da ga nekateri viri (youtube) zamsakirajo in skrijejo, da ga težje ripneš.
www.strancar.com
amigo_no1 ::
Greš v page source , najdeš
..."movie" value="http://www.dailymotion.com/swf/1QaUXesy......
skopiraš naslov v nov tab:
Naslov se spremeni v nekaj takega
http://www.dailymotion.com/flash/flvpla...
&url=http%3A%2F%2Fwww.dailymotion.com%2Fget%2F13%2F320x24...
flv%2F1077758.flv%3Fkey%3D7e1234512345123451234512345123451212345&playLogURL=
http%3A%2F%2Flogger.dailymotion.com%2Fvideo%2Faccess%2Fxn3lq%3Fsession_id%3D
%26blog_key%3D1QaUXesySs3BY4wnc%26referer%3D%26key%3D2odwaio1ae1hmu699jfazg0
&previewURL=http%3A%2F%2Fstatic-03.dailymotion.com%2Fdyn%2Fpreview%2F320x240
%2F1077758.jpg%3F20061114092710&autoStart=0&playerURL=http%3A%2F%2F
www.dailymotion.com%2Fvideo%2Fxn3lq_myt...
&estatClient=players_dm&estatSection=blog
Greš na http://www.dnsstuff.com/ -> in skopiraš celoten zmazek v URL DEOBFUSCATOR
in pogledaš rezultat v
Step 4 ->
http://www.dailymotion.com/get/13/320x2...
key=7e1234512345123451234512345123451212345
&playLogURL=http://logg
(besedilo v boldu je link za D/L - samo za tvoj IP)
slovencl ::
Kako pa narediš to pri avdio/video arhivu RTV slovenija. Ko klikneš ta arhiv, se ti odpre okno, kjer sploh ne moreš izbrati, da ti pokaže sorce te strani, pa tudi zelene ribice ni več na robu okna.
Ko sem dal desni gumb na okno, in izbral UnPlug, mi je nekaj pokazalo, samo nič od tega ni bil posnetek (radia GAGA).
bbobst ::
Ja.Mene tudi zanima za Radio Ga-Ga iz RTV-ja.
StratOS ::
Radio Ga-Ga
Hja, gre namreč za java script funkcija search_play():
	function search_play(elm)
		var plink = 'http://www.rtvslo.si/modload.php?&c_mod=rplayer&id=';
		elm = elm+"";
		if (elm.substring(0,3)!="ava") {
			plink += 'ava2.';
		window.open(plink+elm,'player','toolbar=0,scrollbars=0,location=0,
status=1,statusbar=1,menubar=0,resizable=0,width=650,height=610');
za glasovni posnetek iz 23.03.2007 velja : javascript:search_play(3035901);
torej je link : http://www.rtvslo.si/modload.php?&c_mod=rplayer&id=ava2.3035901
Z malo HTTP analize dobimo asx mms link :
<asx version = "3.0">
<entry>
  <ref href="mms://helix10.rtvslo.si/59/4/RadioGAGAx200703231149x100000x1x1x.WMA"/>
</entry>
</asx>
tipičen mms streaming prenos iz :
ne_kdo ::
lep pozdrav
a je kak drugi način da se prenese posnetek oz film ko se predvaja v brskalniku na disk. jaz na ta način ko je tukajle napisan ne znam :)
mogoče mi lahko kdo kaj pomaga al pa če je kakšen drug program potreben
hvala že v naprej
StratOS ::
No, pa gremo še enkrat :
Radio Ga Ga link
DL-jali bomo zvočni zapis z dne 30.3.2007
Preglejmo source strani :
Izsek :
<script type="text/javascript" src="http://img.rtvslo.si/modules/themes/rtv-v3/js/fixheight2.js?1.2001"></script>
	<script type="text/javascript" language="javascript">
		elm = elm+"";
			plink += 'ava2.';
		window.open(plink+elm,'player','toolbar=0,scrollbars=0,location=0,status=1,
	</script>
</head>
<body onload="if (parent.adjustIFrameSize) parent.adjustIFrameSize(window);">
<div style="display: none; left: 540px; top: 294px;" id="popDiv">Floater</div>
vidimo, da se ob predvajanju zvočne datoteke izvede funkcija javascript:search_play(3167462);
torej :
Če izberemo media player v novem linku (kopija url-ja) in boljšo kvaliteto je link do vsebine sledeč, preko funkcije :
http://www.rtvslo.si/modload.php?&c_mod=rplayer&id=ava2.3167462
Ker je predvajanje iz lokacije Properties - Location na Media playerju ( desni klik )( http://www.rtvslo.si/media.php?id=3167462&mt=wm&mq=hi&wm=true&rm=false ) povezan z predhodno nastavljenim coockijem, če pregledamo source !!!
Iz zgornjega linka dobimo asx fajl z vsebino, ki jo iščemo
Ali pa :
Potrebujemo torej kakšen HTTP analyzer - HTTP Analyzer
Preverimo in preglejmo link z pomočjo analyzerja http://www.rtvslo.si/modload.php?&c_mod=rplayer&id=ava2.3167462
filtriramo linke z tipom video/x-ms-asf in dobimo :
Vsebino tega linka ( seveda je pogojen z coockijem, ki se je prej nastavil ) je :
Pregledamo Content ali Stream tab HTTP analyzerja in dobimo sledeče :
<entry>
  <ref href="mms://helix10.rtvslo.si/74/65/RadioGAGAx200703301158x100000x1x1x.WMA"/>
</entry>
</asx>
Torej lahko preneesmo avdio kot WMA z raznimi MMS prestrezniki ali pa kar preko temp fajla.
Ta MMS pa ni coockie related :
lp, upam da sem kaj pomagal.
trek@s ::
Helow
Ker je ravno ta tema - kako "izluščiti" koristen naslov iz 24ur.com
Npr. ta video: http://24ur.com/naslovnica/novice/slovenija/20070330_3093666_16177057.php
Da dobim url, ga skopiram v program Stream Down in mi potem posname video datoteko na disk?
  • spremenil: trek@s ()
jan01 ::
Na 24ur je pa na easy. Rabiš le addon za firefox unplug-klikneš ne zeleno ribo in loadaš...
trek@s ::
tenkju! 8-)
ne_kdo ::
bi bil kdo tak dober pa bi napisal tocni postopek kak s toto ribico film shranit na disk ker jaz ne znam pa da je nevem kaj :)
hvala za prijaznost
jan01 ::
z unplugom res preprosto:
Klikneš en filmček(recimo na youtubo), da bi ga predvajal, potem pa le klikneš ikono(zeleno ribo) zgoraj desno(oz kjerkoli si tisto ikono dal) v firefoxu im že imaš direkten download link...
ne_kdo ::
sem ugotovil zdaj ja. hvala
sem nasel tudi celotno verzijo reply converterja :))
  • spremenil: ne_kdo ()
mmaestro ::
Kako zadnjo piramido iz te strani: http://www.rtvslo.si/piramida/arhiv.php ??
S pomočjo http analyzerja sem dobil ven ta naslov: http://helix10.rtvslo.si/ramgen/57/30/P... Kako pa naj zdaj to shranim na disk v kakšnem avi formatu ali čem podobnem?
  • spremenil: mmaestro ()
poweroff ::
V AVI formatu ne bo šlo, lahko pa v RM in potem pač pogledaš z RealPlayerjem.
sudo poweroff
mmaestro ::
Ja in kako dobim dol v RM?
StratOS ::
na povezavi http://www.rtvslo.si/piramida/arhiv.php imaš več linkov, gremo na 27.03.2007
iz sourcea :
<td class="tabela_arhiv_bottom" align="right"><p class="p_arhiv">27.03.2007</td>
<td class="tabela_arhiv_bottom" align="right"><p class="p_arhiv"><a href="javascript:void window.open('/modload.php?&c_mod=rplayer&id=http://www.rtvslo.si/media.php?id=3115728',
location=0,status=1,statusbar=1,menubar=0,resizable=0,width=650,height=610');"><img src="http://img.rtvslo.si/modules/content/rnews/icons/kamera.gif" alt="" border="0"/></a>&nbsp;&nbsp;&nbsp;</td></tr>
Da dobimo z toolbarji gremo na http://www.rtvslo.si/modload.php?&c_mod=rplayer&id=http://www.rtvslo.si/media.php?id=3115728, izberemo lahko MP ali RM - High ali Low kvaliteto.
Za high in MP dobimo :
http://www.rtvslo.si/media.php?id=3115728&mt=wm&mq=hi&wm=true&rm=false
Iz streama/contenta vidimo linkanje asx-a :
<entry>
  <ref href="mms://helix10.rtvslo.si/57/31/Piramidax200703272121x450000x384x288x.WMV"/>
</entry>
</asx>
za RM :
http://helix10.rtvslo.si/ramgen/57/32/Piramidax200703272122x450000x400x300x.RM da link na
rtsp://193.77.198.67:554/57/32/Piramidax200703272122x450000x400x300x.RM?cloakport=80,554 katerega lahko odpreš preko RealPlayerja.
Za temp fajle ti tudi HTTP analyzer pove kje se nahajajo.
amigo_no1 ::
V google napiši: RealPlayer alternative
Kaj je RM ?
http://filext.com/detaillist.php?extdet...
mmaestro ::
Hvala.
Zufer ::
Ali se kakorkoli da ripati posnetke na 24ur.com brez Firefoxa in dodatkov?
Potrebujem tole Športna scena . Če je kdo tako prijazen, da razloži postopek, bom blazno vesel.
  • spremenilo: Zufer ()
SeekK ::
Tale tema mi je že zelo pomagala pri nekaterih stvareh, sploh pri jemanju videa z rtvslo.
Samo mam pa zdej problem pri jemanju videa s 24.ur. Očitno so nekaj spreminjali od takrat ko se je tale topic začel,
ker mi ne delujeta ne tista ribica, ne download helper (edino če jst česa ne znam, samo z youtube recimo vzamem z lahkoto z obemi orodji).
Tko da če bi kdo znal kaj svetovat kako s 24 ur vzet video dol, bi lepo prosu za nasvet.
  • spremenil: SeekK ()
StratOS ::
Hja, zadevco so eno kr dobro zakomplicirali.
slovencl ::
Kako pa bri prenesel filmčke s tele spletne strani? UnPlug ne najde nič.
poweroff ::
Sploh ne razumem v čem je problem.
Kliknem na prvi film - "#1 Plastic face plate", odpre se pop-up. Pritisnem ctrl-U - v Firefoxu to prikaže izvorno kodo spletne strani, in takoj na začetku je tole:
AC_FL_RunContent(
"flv", "file=http://www.cmslaser.com/videos/video-fi...
"src", "flvplayer",
Potem lepo rečeš:
wget http://www.cmslaser.com/videos/video-fi...
In voila - datoteka je že pri tebi na disku.
Kje je točno problem?
sudo poweroff
R33D3M33R ::
Na 24ur.com uporabljajo swfobject
slovencl ::
Najbrž je bil problem, ker zgoraj ni bilo prikazanih menijev, datoteka, urejanje, ...
SeekK ::
Torej, če prav razumem, se zdej s 24ur ne da filmčka potegnit dol direktno?
Mi preostane še kaj drugega, kot da pač predvajam in posnamem s programom tipa Snag It?
bluefish ::
na rtvslo se je očitno spremenil način objave videov.
Lahko kdo pomaga pri Piramidi 10.3. ?
sprasujem ::
Dej tole na vlc
mms://helix10.rtvslo.si/15/18/Piramidax200903102111x450000x384x288x.wmv
bluefish ::
Žal ne odpre. Deluje pa brez težav na posnetku, ki ga je že dolgo nazaj linkal StratOS.
sprasujem ::
Sem sprobu.Odpre. Sam pr tem linku pazi da ni na koncu kakšen presledek. Ker se je tud men to zgodil!
bluefish ::
ja, sedaj odpre. Očitno res nisem bil pozoren na presledek.
Mimogrede. Je to WMV HQ ali LQ?
  • spremenil: bluefish ()
sprasujem ::
Ne vem. Men sam Totem player na ubuntuju prek firefoxa pokaže ta link ko grem na določeno oddajo. 384x288 niravno HQ
bluefish ::
sprašujem namreč zaradi tega, ker se mi zdi, da je LQ, vsaj glede na primerjavo tistega, kar vidim direkt v browserju. HQ pa v smislu kvalitete posnetka.
sprasujem ::
na rtvslo sem zbral visoko kvaliteto. Nizka ima 240*180*16. Flash player 10 ima kao
vgrajen p2p pa zato mogoče bolje zgleda.
ajitam ::
Pozdravljeni
res bi rabil vaso pomoc. kot sem bral ta post sem ugotovil da je rtvslo najverjetneje spremenil predvajanje filmov.
potreboval bi ta posnetek: http://www.rtvslo.si/play/odhod-otroka-...
najlepsa hvala
bluefish ::
OK, tnx.
StratOS ::
mms://helix10.rtvslo.si/37/64/Odhodotrokaoddomax200903111904x450000x384x288x.wmv
ajitam ::
ne bom niti spraseval kako..... samo .... hvala
StratOS ::
Hja, če hočeš lahko povem, gre namreč za WM playlisto, le ta se nahaja pa na :
http://www.rtvslo.si/media.php?id=30073...
Izak ::
Zna kdo pomagat kako povlečt novico iz 24ur.com?
Hvala.
StratOS ::
Novica http://24ur.com/novice/svet/slovenija-p...
Pregledaš js in object stringe:
	<script language="JavaScript1.1" type="text/javascript">
		//user track variables
		var section_id = "3";
		var article_id = "3163174";
		var gallery_id = "3163198";
		var media_id = "60272976";
		var article_date = "20090404";
		var app_lang = "slo";
		var show_banners = "1";
		var allow_refresh = "0";
	</script>
in objekt :
<object width="420" height="376"><param name="movie" value="http://24ur.com/static/slo/shared/app/MediaCenter.swf"></param><param name="allowfullscreen" value="true"></param><param name="flashVars" value="media_id=60272976&ad_file=noad&autostart=false"><embed src="http://24ur.com/static/slo/shared/app/MediaCenter.swf" type="application/x-shockwave-flash" allowfullscreen="true" width="420" height="376" flashvars="media_id=60272976&ad_file=noad&autostart=false"></embed></param></object>
Razrešiš in voila :
http://streamflv1.24ur.com/24ur.com/200...
svejk ::
no in kako downloadat tole: http://tvslo.si/predvajaj/alternativa-s...
amigo_no1 ::
GetASFStream
vpiši naslov:
mms://helix10.rtvslo.si/65/4/AlternativaSobotnopopoldnex201001091659x450000x384x288x.wmv
kako točno sem že pisal v tekj temi:
Oddaje z rtvslo.si
Poglej si tudi linke spodaj "Vredno ogleda ..."
2
Download video (flash) iz rtvslo (strani: 1 2 )
9760680 (23090) Pizzicato
Kako presnamem video prispevek z RTVSlo portala?
Oddelek: Zvok in slika
2512629 (8323) Naabo
rtv - download posnetkov
4314834 (8091) Valvoline
Poslušanje Intrnetnega radija
72578 (2443) k4vz0024
download odmevov z rtv.slo
114446 (4144) sprasujem
