Kako izklopit tale error
#000000 ::
Warning: Dell's Disk Monitoring System has detected that drive 0 on the
Primary EIDE controller is operating outside normal specifications. It is
advisable to immediately backup your data and replace your hard disk drive
by calling your support desk or Dell Computer Corporation.
Alert! Cover was previously removed.
Strike the F1 key to continue, F2 to run setup utility.
Disk je nek maxtor, in ga če stisnem F1 zboota brez problema, in tud mašina dela dalje brez kakih napak. Zanima me samo kako ugasnit/izklopit ta alert tko kot error ?? LP
edit: ajaj gre za dell optiplex GX100
  • spremenilo: #000000 ()
iščem pomoč WIN
131454 (1290) marc100
Prehod iz Win2000 na Win XP
Oddelek: Operacijski sistemi
362554 (1879) chrush
Dell Recovery
81714 (1567) hotacid
Instalacija windowsow - problem
121996 (1600) misek
Najbolj neumno vprašanje? (strani: 1 2 )
549022 (7930) Mike
