Forum » Pomoč in nasveti » Ne odpre mi Wolfensteina
Koci ::
Ko probam odpret Wolfensteina mi napiše: could not load OpenGL subsystem; pol pa še :
olf 1.0.0 win-x86 Nov 13 2001
----- FS_Startup -----
Current search path:
C:\PROGRA~1\RETURN~1\main\sp_pak2.pk3 (232 files)
C:\PROGRA~1\RETURN~1\main\sp_pak1.pk3 (1342 files)
C:\PROGRA~1\RETURN~1\main\pak0.pk3 (4775 files)
C:\PROGRA~1\RETURN~1/main
6349 files in pk3 files
execing default.cfg
couldn't exec language.cfg
execing wolfconfig.cfg
execing autoexec.cfg
Hunk_Clear: reset the hunk ok
...detecting CPU, found AMD w/ 3DNow!
Bypassing CD checks
----- Client Initialization -----
Cmd_AddCommand: map_restart already defined
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\System32\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using colorsbits of 32
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...35 PFDs found
...GLW_ChoosePFD failed
...GLW_ChoosePFD( 32, 24, 0 )
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...using colorsbits of 16
...calling CDS: ok
...GLW_ChoosePFD( 16, 24, 8 )
...35 PFDs found
...GLW_ChoosePFD( 16, 24, 0 )
...35 PFDs found
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLW_StartOpenGL() - could not load OpenGL subsystem
Mogoče kdo ve kaj je narobe?
execing default.cfg
Bypassing CD checks
----- R_Init -----
...initializing QGL
...calling CDS: ok
...35 PFDs found
...35 PFDs found
...calling CDS: ok
...35 PFDs found
...35 PFDs found
...initializing QGL
RE_Shutdown( 1 )
Panta rei!!
GaPe ::
Daj uporab iskanje, ker je bilo na ta problem odprtih že veliko tem.
Don't steal! The government hates competition.
Dj-Prah ::
Posnami si opengl.Mas ga na kakem softwere powerju ali jokerju.Ce ga bos snel z interneta ti zavzema 60mb.
| » | Wolfenstein - Enemy Territory (strani: 1 2 3 4 … 19 20 21 22 )Oddelek: Igre | 106050 (23058) | Gregor459 |
| » | Problem z nvidioOddelek: Pomoč in nasveti | 1896 (1644) | lanicorec |
| » | Problem z zagonom iger RTCW in MOHAAOddelek: Igre | 3107 (2791) | Flay |
| » | Medal of Honor in merzno igranje?Oddelek: Igre | 1295 (1157) | mitopuzo |
| » | Wolfenstein in XP???! :o(Oddelek: Pomoč in nasveti | 1483 (1385) | zrebec |
