Forum » Programiranje » [c] napake pri castanju
napsy ::
Pišem en program kjer en thread poda drugemu preku asinhrone čakalne vrste strukturo. Sta pa dve podobni strukturi. Druga ima na začetku kazalec na prvo, tako da če bi želel dostopati samo do elementov prve, naj bi samo castal. In to tudi naredim, saj drugi thread, ki sprejme strukturo v obliki prve (torej castano), dobi napačne vrednosti. Zakaj?
Če program poženem, dobim:
./test
s1 ptr = 134676568
s1 ptr = 4
In je jasno vidno, da je prvi izpis vrednosti a napačen, saj bi moral biti 2.
#include <gtk/gtk.h>
GAsyncQueue *queue;
struct s1 {
int a, b, c;
struct s2 {
struct s1 *s1_ptr;
int d, e, f;
int ptr_funk1(struct s1 *ptr)
ptr->a = 4;
gpointer funk1(gpointer data)
struct s1 *ptr_s1 = g_malloc(sizeof(*ptr_s1));
struct s2 *ptr = g_malloc(sizeof(*ptr));
ptr_s1->a = 2;
ptr->s1_ptr = ptr_s1;
ptr->d = ptr->e = 8;
g_async_queue_push(queue, (struct s1 *)ptr);
return NULL;
gpointer funk2(gpointer data)
struct s1 *ptr;
ptr = (struct s1 *)g_async_queue_pop(queue);
g_print("s1 ptr = %d\n", ptr->a);
ptr_funk1(ptr);
return NULL;
int main(int argc, char **argv)
GThread *thread1, *thread2;
g_thread_init(NULL);
gtk_init(&argc, &argv);
queue = g_async_queue_new();
thread1 = g_thread_create(funk1, NULL, FALSE, NULL);
thread2 = g_thread_create(funk2, NULL, FALSE, NULL);
gtk_main();
return 0;
./test
s1 ptr = 134676568
s1 ptr = 4
"If you die, you die. But when you live you live. There is no time to waste."
- spremenil: napsy ()
napsy ::
Ok rešu problem z dvojnim kazalcem.
| » | "Dinamicna" sprememba razreda v C++Oddelek: Programiranje | 2528 (1920) | Spura |
| » | [C] Razbitje stringa s pomočjo indeksovOddelek: Programiranje | 1111 (989) | Shinobi |
| » | [C#] unmanaged->managed codeOddelek: Programiranje | 2558 (2433) | Zzzzzzz |
| » | spet problem v Cju ... kazalciOddelek: Programiranje | 1345 (1259) | hatch |
| » | Collision detectionOddelek: Programiranje | 2726 (2478) | Senitel |
