Forum » Pomoč in nasveti » Logitech G11 problem
reptilia ::
imam en majčken problem z navedeno tipkovnico... oz. prijatelj jih ima...
ne delajo mu vse tipke oz. natančneje tipke za preskok glasb pa play, stop pa za glasnost... ima najnovejše driverje sp2 itditd.... pozna kdo ta problem?
Forgive your enemies, but never forget their names.
Chewie ::
Try this. Make sure you installed the latest drivers from Logitech
:arrow: http://www.logitech.com/index.cfm/do...ontentid=10824
and the MS Service Pack 2
Then go to start -> execute and lauch services.msc and check, if the Hid Input Service at "Startup Type" is set to Automatic and the Service is "Started".
If it's not and you try to start it and get an error like "Code 2....", one
registry key is missing. I've exported my key and tested it with a friend, who had this
prob and it worked.
Open regedit and go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\HidServ\Parameters
Create an EXPANDABLE string value called ServiceDll with the value %SystemRoot%\System32\hidserv.dll
Now it should work.
Works fine!
prob and it worked.
Now it should work.
Works fine!
| » | Windows 7 Installer (64-bit) - težaveOddelek: Programska oprema | 3726 (3116) | fr!Xy |
| » | windows XP se mi nočejo zagnati (prilagam sliko ekrana)Oddelek: Pomoč in nasveti | 5428 (4113) | vbohinc |
| » | 100%Cpe + ostaloOddelek: Pomoč in nasveti | 2824 (2494) | postar_si |
| » | Logitech MouseWare bug (?)Oddelek: Pomoč in nasveti | 2611 (2207) | Swiwer |
| » | Kako popolnoma zbrisat stare driverjeOddelek: Pomoč in nasveti | 1410 (1263) | kita103 |
