Kako popolnoma zbrisat stare driverje
kita103 ::
Imam radeona 8500 in catalyst driverje 7.76 oz. 2.3
Kako naj jih popolnona odstranim? Uninstal baje ni dovolj.
Kateri catalysti so najboljsi?
gkovac ::
možnost 1: register -> zbriši vse kar diši po ATI-ju (ampak na lastno odgovornost)
možnost 2: format C:\ :D :D :D :D
lp,
____________________________________________
"Left to themselves, things tend to go from bad to worse."
AngelOfDeath ::
ja edina možnost je format kot je že povedal >:D
Western ::
Pejd na Atiyovo stran, pa poglej kako vse skup odstranit!Sigurn piše!
Narcos Satanicos ::
uninstall ati driver
bootej u vga mode
search c: ati*.* zbris vse
reboot
instalirej nove driverje
reboot
tud ksne overclock programe je dobr izklopt
bruhanje ::
Ce so drajverji nalozeni pejt pod adapter --> properties ---> driver details... pol pa zbrisi vse fajle k so uporabljeni! ce ne gre direkt iz Windowsev pa v dosu zbris.
Osama ma vas rad!
JohnyB ::
Točn potek je tak:
1. Go into the Control Panel and under the ADD/REMOVE SOFTWARE icon uninstall the ATI MultiMedia software and/or the ATI DVD software.
2. Uninstall the ATI drivers also found in the Add/Remove section. Once removed, it will prompt you to reboot....do so.
3. When returning to windows, the NEW HARDWARE FOUND wizard will come up and will tell you that it has found a new VGA card and will prompt you for drivers. Hit CANCEL!
4. Now, go to START - SEARCH - FOR FILES OR FOLDERS and do a search for all files and folders using the filename ati*.* This search will normally give you 3 to 4 files found in your c:/windows directory and subdirectories (including the
Windows/System directory). Select these files and erase them. Now go to your Recycle Bin and Empty your bin.
5. Next...time to go to your Registry. Go to START -- RUN -- regedit
Here go to key HKEY_LOCAL_MACHINE -- SYSTEM -- ControlSet001 -- Control -- Video . Here there should be 4 entries. 3 of them are default Windows XP entries and the 4th one is put in by the ATI drivers. Expand each one by one until you see ATI entries. Once found, erase the entire key.
Now repeat the same step above for the ControlSet002 key and the CurrentControlSet Key. Normally, whenever you erase a key in the ControlSet001, XP automatically deletes it in the CurrentControlSet section too.
So if the ATI key is not found in the CurrentControlSet section, don't worry about it. Once all keys are deleted, proceed to the next step.
6. While still in the registry, go to the key HKEY_LOCAL_MACHINE -- SOFTWARE section. Here you should find an ATI Technologies key. Select it and delete it. In that same section, look for an Installed Options key. Expand it and there you should find another ATI Technologies key. Select it and erase it.
7. Still in the registry, go to HKEY_CURRENT_USER -- Software and there you should find another ATI technologies key. Select it and erase it. Once all this is done, close the registry. the registry is now clean.
8. Close all windows and reboot.
9. When in windows after the reboot the NEW HARDWARE FOUND WIZARD will pop up again. Cancel that. Now find the new ATI drivers that you have downloaded and extracted and run the SETUP file. Once complete, reboot and you are done. You may want to reinstall your ATI MMC software and DVD software if you use them.
DONE!
Dela 100%, sm že vse tastare driverje tko odstranu. S tem načinom res popucaš vse!
Apple iMac
kita103 ::
Fantje hvala vam ful :)) :)) :P
Windows 7 Installer (64-bit) - težave
Oddelek: Programska oprema
153703 (3093) fr!Xy
windows XP se mi nočejo zagnati (prilagam sliko ekrana)
255416 (4101) vbohinc
Remote desktop v XP SP3
142902 (1972) neres
Zvočna ne dela na XP-jih
51533 (1481) mitja01
CATALYST 3.6
168969 (8454) freejack
